Protecting Foam...
Protecting Foam...
Hello;
I've just made a fairly sharp-looking pair of wheel pants/landing gear for the GeeBee (pictures shortly, when I get near my camera again) using layers of Depron foam, sanded smooth. They look okay as they are, but the bare, sanded foam looks a little delicate, plus they could use a little spot filling here and there.
I could just paint them at this point, but can I use a light coating of thinned epoxy alone to harden the surface a little bit? These are very small, and I'm trying to keep things light (three grams each), so I don't want to use fiberglass.
Is there anything better than epoxy to coat them with?
Thanks much...
Dan.
Thanks much...
Dan.
My Feedback: (-1)
RE: Protecting Foam...
get some denatured alcohol and dilute the epoxy to a thin consistency and wipe this over the wheel paints with a cotton ball. your foam will now have 4-5 times the strength with minimum weight added. remember it will take longer to cure so be patient
