how to cover in sran wrap?
RE: how to cover in sran wrap?
You can use a 3M Super 77 spray applied with a Q-tip to the balsa or a thicker glue like [link=http://www.hobby-lobby.com/litespan.htm]Balsaloc[/link] and then wrap the plastic covering firmly around the frame.
Once the frame is wrapped and trimmed, use a light heat like a blow dryer or distanced heat gun to shrink the plastic wrap to a snug fit.
The key is to start out with as few wrinkles as possible since the plastic wrap has little shrinking properties and little tolerance for heat.
MO
a glue stick also works rather well. run the glue stick along all the edges and across the ribs you want the saran to stick to. lay the saran on as neat as possible and run your finger over where the saran is on the glue, if you can use something warm here it makes it stick better otherwise just run your finger back and forth several times to help warm the glue. trim with a razor blade, I shrink mine in front of a small heater controlling the heat by the distance you have the part from the heater. a blow drier or heat gun ussually has too much force to allow drum tight shrinking.
a plus to the glue stick is if you are not all ready using 3m-77 for something then you don't have to shell out 7 to 9 dollars for a can of it, and the glue stick doesn't get on everthing like the 77 does when you spray it.
hope this helps.
Jason
hope this helps.
Jason
KY
When you use the glue stick, make sure it does not get on your hands. If it does and you touch the saran wrap, you could pull it away from the plane, before it has time to dry. I had that problem and it is not a good idea to cover your wing when you are frustrated.
I have also heard that Elmers glue diluted with a little bit of water works well. But, whatever you use make sure you test it before you apply it to your wing.
Good luck
Good luck
