Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
Air Hogs Aero Ace!
Reply
Old 04-25-2007, 10:11 AM
  #4976
Green1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Air Hogs Aero Ace!
TR Good flying bud[8D]
Green1 is offline
Old 04-25-2007, 10:17 AM
  #4977
skunkworks2006
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WOOOO HOOOO!
Page 200 of the AA thread!
skunkworks2006 is offline
Old 04-25-2007, 10:20 AM
  #4978
Green1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lmao
Green1 is offline
Old 04-25-2007, 10:36 AM
  #4979
Parky50
Parky50's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: skunkworks2006
WOOOO HOOOO!
Man.... that's got to be a RECORD !!!
Parky50 is offline
Old 04-25-2007, 10:53 AM
  #4980
trroadster
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SO MUCH TO SAY.... SUCH A LITTLE PLANE
trroadster is offline
Old 04-25-2007, 03:07 PM
  #4981
jackson89
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok so i went to toys r' us and bought a red biplane, c channel. it was the only bipe left. it seems ok but when i add throttle it sounds like something is loose. any1 have a clue of what it may be or will it not affect the way it flies and i shouldn't worry much about it?
another thing. how can i take off the prop because i wanna fly both my jet and bipe and since im missing a prop on my jet ill use the bipe one for it once in a while
jackson89 is offline
Old 04-25-2007, 03:39 PM
  #4982
alset
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[/quote]
I am confused, because in the part where it is listing features, it mentions that one of the features is a lithium battery. I wonder what is really in there. How can they fit a NiMH battery big enough for a 10 minute flight into that space? I am also wondering whether the electronics are the same - could you use it with an ace controller. Even if the battery is no good, this may be a good option as a parts plane for repairs to AAs.
Cobbler
[/quote]
You are right - it does say Lipo at the bottom of the description. What I saw was the mention of the NiMH battery in
the middle of the description. That section is still confusing to me.
alset is offline
Old 04-25-2007, 03:51 PM
  #4983
andrewtexas123
andrewtexas123's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jackson, my props come right off if you give them a tug.
andrewtexas123 is offline
Old 04-25-2007, 04:11 PM
  #4984
jackson89
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hmm. i try doing that but its like ripping the motor out too
Old 04-25-2007, 04:16 PM
  #4985
trroadster
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use a pair of fine needle nose plyers to hold the shaft when pulling on the prop.
ORIGINAL: jackson89
Old 04-25-2007, 04:27 PM
  #4986
jackson89
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
o ok thanks. now i got it off.
so i kept testing out the bipe and when i give it throttle, the left prop seems to jump a bit but it didn't seem to be less powerful, it just jumps a bit as if its loose. idunno if its bad or not, maybe i should fly it and if it breaks then ill return it.
Old 04-25-2007, 05:29 PM
  #4987
FERNDALE AIR FORCE
FERNDALE AIR FORCE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jax, you might try a bit of oil. Also contact air hogs, they might send you a replacement jet. Tim
FERNDALE AIR FORCE is offline
Old 04-25-2007, 05:33 PM
  #4988
jackson89
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks. ill try the oil. as for the jet, i had it for more than 90 days and i dont have the receipt [:@]
Old 04-25-2007, 06:07 PM
  #4989
FERNDALE AIR FORCE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All, I got those batteries in a while back, 100 mah 12-20c and 135mah 12-20c. The battery size is different on the 100mahs, smaller and thinner, I'm putting a plane together around one and I'll let you know about it. I put the 135mah in my lighted plane and the plane flies really fast, much better than it did with the full river 100 mah. So I have high hopes for the 100mah battery. Tim
Old 04-25-2007, 11:41 PM
  #4990
micro_builder
micro_builder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how 'bout another aero ace LRF? i built this the other night, just got done with it tonight. it originally started with the funky two fin tail, but it had a tendency to stay in a nose dive once it entered one, always resulting in a crash. so, i just added a rudder and adjusted the angle of the horizontal fins (last pic).
the main wing is .020 cf rod, the tail feathers are .010 cf rod, covered with alumized mylar. the rest is just 1/16th inch balsa, some CA, and a little bit of wire insulation to hold and adjust the wing posts so i can adjust the incidence. the RX is from the AA, unmodified, the two motors and prop, as well as the 50mah lipo are from the piccoz heli. the wing is 10 inches by 5.5 inches, total weight of 6 grams.
out of all of the LRFs i've built i'd almost say this is one of the most well behaved, it flys nice and slow, turns on a dime and is very stable. the CG is quite far forward, which is why the angle of attack on the main wing is so high. when the power is on, it allows it to climb very steadily, when the throttle is cut, it just kind of parachutes down. the overall speed and control can be changed quite easily with just sliding the front wing post up or down.
i've got some video, but i'll wait till tomarrow when i can get some better footage, it flys quite nicely in the house.
nick
ID:	672370   Click image for larger version
ID:	672371   Click image for larger version
ID:	672372   Click image for larger version
ID:	672373   Click image for larger version
micro_builder is offline
Old 04-26-2007, 08:12 AM
  #4991
FERNDALE AIR FORCE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very cool. Tim
Old 04-26-2007, 11:46 AM
  #4992
andrewtexas123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have aa jet gear and i was wondering what the best design is to use. I want to make the plane out of stuff from the house.
Old 04-26-2007, 12:20 PM
  #4993
trroadster
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://richard.ferriere.free.fr/3vues/3vues.html#m
Have a look here. I've made three planes by tracing a three view on depron or egg carton lids.
Old 04-26-2007, 07:52 PM
  #4994
propbreaker-delete
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I took a little circuit board from a small rubber ball. It has three LEDs, different colors, that flash, has a little on/off button. I cut into a Acrojet and used it for front weight. It is buried inside, it looks pretty cool. It looks normal outside but depressing the foam turns the light on and off. I should hog out a bit more foam to make it brighter though. There are tons of cheap toys with flashing LEDs these days, I even found one in the lid of a kids mouthwash - all mine when the mouthwash is gone!
ORIGINAL: PrkFlyrRic
I'd be more interested in some wing lights made from the little flashing light from a Havoc/Picoo-Z.
I have an idea but not enough know how to make them myself.
propbreaker-delete is offline
Old 04-26-2007, 11:20 PM
  #4995
gorcpnd4pnd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any one know where I can get some LEDs around Huntington Beach? Was hoping to get the kind with on\off switch that can just be taped on the wings. I found some on a fish bobber website, but dont want to pay for shipping. Thanks
O ya I just got the green and yellow biplane. Does anyone know how well that one works, or do the all perform the same
gorcpnd4pnd is offline
Old 04-27-2007, 12:02 AM
  #4996
Tim Taylor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I tried the mail order and got the wrong planes.
Yes I can fly the AA in Rawlins. In fact I flew it for about two hours in between flights of my big planes on Wednesday. It'll handle a slight breeze pretty well. Most of the time though it's indoor flying for the little planes.
Tim
Tim Taylor is offline
Old 04-27-2007, 12:12 AM
  #4997
Tim Taylor
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That little Bipe is way cool. I agree on the F-16. It's a thumbs down. Not completely down but mostly down. And I served 6 years Air Force, got out in 79 as an O3. I regret getting out when I did but money called.
I think I'm going to be seeing a lot more AA's in my area. Everyone is impressed the the AA Jet and the Bipe.
TimT
Old 04-28-2007, 08:00 PM
  #4998
FERNDALE AIR FORCE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Timt, I think the bipe design is the best one ever. There are many mods for it, and it protects the battery and gear so well. I recently lost one for, I think, 10 days, it could be longer. It blew down from it's hiding place last night or this morning. It is a mono single stir stick mod. The auto cut off saved the battery, and the construction of the plane saved the rx. It rained on the plane, and heavy fog and drizzle have been regular this week. I stuck it on the charger, it did not need much, and flew it around the yard. I would recommend buying a second to modify.
Have Fun,
Tim
Old 04-28-2007, 08:42 PM
  #4999
FERNDALE AIR FORCE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Double post
Here is the deal on the new batteries. So far they are great. My lighted ace has the 135mah battery and it flies much better, I'm thinking about a bit more wing and then some ballast, or doing a double stir stick mod on it.
Here is where you guys get a vote. Should I set up the plane with the 100mah battery as a bipe or as a double stir stick? I will continue to charge from the tx for a while. So far these smaller, lighter batteries have been better than the full river batteries. I'll check in later. No votes will mean double stir stick. Tim
Old 04-29-2007, 09:31 AM
  #5000
Green1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
very cool Tim.ok i would say the bipe in original form first..was it the chicken or the eggs that came first.....lol G1
Green1 is offline
