aeroace mods
#52
RE: aeroace mods
This is my stock AA, the Canard
Thread here-
http://www.rcuniverse.com/forum/m_6605702/tm.htm
This is all from the original plane except the vertical stab. Its flys very well and Looks GREAT!
My own design
Thread here-
My own design
#53
WA
RE: aeroace mods
I think the best mod for the aero ace jet it to simply put a dime under the nose. The climb rate is amazing. I get up to about 200ft in about 45seconds.
#57
MN
RE: aeroace mods
Not sure if anyone's tried this, but I use speed and low drag to combat wind. It's real easy to do; just cut 1 1/4 inches off your wingtips. This only benefits the mono as far as I know. Careful, though; you'll need almost full throttle just to stay up.
P.S. My personal opinion is that you can remove about half of any Air Hogs plane's wingspan and it'll still fly. I cut 6 inches off my Rolling Fury and it flies just fine.
#58
TX
RE: aeroace mods
for anyone needing spare parts -
PicooZ/Havoc main and tail motors
X-Twin/Aero Ace motors and props
PalmZ/Nano Hawk motor/gear/prop assembly
they'll soon be available:
http://www.rcgroups.com/forums/showthread.php?t=825953
Michaels shop:
http://www.indoorflyer.co.uk/
i've ordered from him on more than a few occasions and shipping is always quite fast, his prices are good too.
nick
Michaels shop:
nick
#59
RE: aeroace mods
Hello all I have a question about the AA charger in the TX.
There are a pair of 4.7k resistors (R41,R42) in parallel on the output of the charging circuit. I would think that if one of these were removed that the charging current would drop from 3C to about 1.5C which would hopefully increase the life of the Lipo.
Has anyone done this?
Does it work ok?
If it does work would a 10k Variable Resistor trimmed to allow only a 1C charge work?
Oh I just noticed that they are 4.7 ohms not 4.7k.
Does it work ok?
#60
CA
RE: aeroace mods
BGR, the lipo only achieves nominal charge (3.7v) from my testing. My testing way back when idicated that I was getting a 2s/1c or 7.4v 100mah charge. I did just open up a new tx and found new stuff inside. You'll usually get a quicker response on the aeroace thread.
Tim
Tim
#61
AB, CANADA
RE: aeroace mods
Hello again boys and girls. The depron bandit has been squirreled away in his workshop and it's time for show and tell...
The C-119 flys very scale like and resonates quite loudly. Kinda like the original. The super connie took some time to trim but now is an excellent flyer. The CF-100 is untried (maiden tomorrow). The 737 is a remake of one that flew ok on AA bipe guts until it had a wingtip chewed off by a larger plane. I resurrected it to try JetScream fans...WOW...up in the rafters at the lowest throttle setting. (I,m thinking of calling it "Dogpatch Air" for obvious reasons.
The A-26 was a slingshot glider that I modded with Minium motor gearboxes and the brick from an MCX heli (2x esc) Maiden tomorrow.
#64
AB, CANADA
RE: aeroace mods
Sorry man, don't get back here very often as it has gone quiet. The plans are in the AA toolbox. There is a link on page one of this thread
ORIGINAL: Aircraftfreak15
trrod can you send me the plans for the f-15 plz
#66
AZ
RE: aeroace mods
Thank you the jet cat is one of my favorit desighns might inlarge it to a 18 inch span and try to use parke zone gear in it. iam going to make and aa one frist.
