Vapor Electronics
PA
Vapor Electronics
Anyone try putting the ParkZone Vapor board in another micro sized plane?
I was thinking about building a micro flying wing and using elevon mixing with it. According to the BNF manual, it sounds like the rudder & elevator servos are on the aileron and elevator channels, so elevon mixing with the DX6i or DX7 should work.
PA
RE: Vapor Electronics
Maybe use the Centurion/Citabria motor/gearbox/prop with it. Stick it on the back of a small foam flying wing, mount the prop backwards, flip the motor wires to spin it backwards for a pusher prop setup.
PA
The Cessna and Ember electronics can't be bound to a DSM2 transmitter, so there's no way to use elevon mixing. I did a search on the Vapor and found nothing on this topic.
My Feedback: (81)
VA
Oh yes, I forgot about that. I should have read your original post more clearly.
I was mostly thinking about the Cessna board. There have been alot of people that have put that board in another small plane.
The new ember board will work.
PA
I found a monster thread (1200+ posts) over in RCGroups that mainly talks about putting the Cessna board in other model planes, but a few guys hacked the Cessna transmitter and added a mixer board to do elevon mixing:
http://www.rcgroups.com/forums/showthread.php?t=720179
