I NEED MORE POWER!
My Feedback: (81)
VA
RE: I NEED MORE POWER!
Maybe not, but I know it will support the BSD motor.
Here is the one I used on both my Citabria and Cessna.
http://www.bsdmicrorc.com/index.php?productID=848
Vid
http://www.youtube.com/watch?v=kUHW0y5SA1A
Vid
I upgraded my batteries to the Hobbycity 138mah ones. So that is taken care of.
Is there a noticeable amount of difference in the upgraded motor and prop?
Could you link me to everything I will need? Also would this be able to fit on the ember and how long of runtimes would I get on a 138mah battery? I am getting around 20-25 min of flight time right now.
My Feedback: (81)
VA
Here is the prop.
http://www.bsdmicrorc.com/index.php?productID=788
Ask Bob at BSD about the prop saver. I think the motor/gearbox comes with it.
Sorry, but not sure about the flight times. I never worried about it, as long as I had enough fun before the battery ran dead. If you have more than one battery, don't worry about it.
Thanks for the help. I have 7 of those batteries so I am all set. haha I will order that stuff soon. What does the prop saver do and how do you hold in the motor?
My Feedback: (81)
VA
The prop saver helps save the prop from breaking in the event of a crash. It screws onto the shaft.
As you can see in the picture, the prop is held on with a rubber band.
TX
ORIGINAL: FERNDALE AIR FORCE
Nick, do you know if the kyosho brick will support the SU-26 motor?
Tyler a battery upgrade wouldn't hurt either.
Tim
Tim
If its got the same FETs as the PZ bricks, it should be OK (but dont hold me accountable if I'm wrong )
Nick
