New PZ Sukhoi and Vapor
My Feedback: (81)
VA
RE: New PZ Sukhoi and Vapor
Cool, so now I can get a replacement motor from the new Sukhoi and put it in my original Sukhoi and it will be better. I just won't have the larger control surfaces. But I can fix that with some foam
MD
I'm glad I took a look at this post today. I was just about ready to buy a new Sukhoi now that I can fly it better. The old one is getting a little beat up. I wonder how long it will be before it is availible. Horizon shows "coming soon".
AZ
http://searchrc.horizonhobby.com/ind...=5913+753+8064
iam thinking these new ones went strate out to the public because of what i see here.
My Feedback: (20)
ORIGINAL: Wheelnut
My Feedback: (81)
VA
The specs says it has "Larger control surfaces" maybe not much but larger.
ACF, that is the way it looks when they first release a plane. They will post the ad and It will show out of stock even when it hasn't made it over the seas yet.
My Feedback: (20)
ORIGINAL: Wheelnut
The specs says it has ''Larger control surfaces'' maybe not much but larger.
I believe it is the same fuselage
they say mid may for delivery
My Feedback: (20)
ORIGINAL: Wheelnut
Interesting, I wonder if they meant what they said?? The older plane could be adjusted to larger throws also by moving the connector to a different hole.
Figures.......
Just bought a Sukhoi this past week.
Should have procrastinated more better. Will practice.
So what motor and prop in the latest version?
Same gear reduction and battery?
While on the subject what are the differences between the P-51 and Sukhoi motor and gear reduction?
Are they the same?
I have to ask as the Sukohi has been a trouble free excellent flier right out the box so it has not been "Opened up"
1/2 throttle gives good climb rolls and loops.
David
Are they the same?
David
AZ
i was hopeing buy the end of next mounth so i could get it as a b-day presnt oh well.
horizon is bad about ther dates so ill expect it in june or july insted of may.
