Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Pentathlon Evo - Electric
Reply
Old 01-31-2011, 02:38 PM
  #101
Fixed Wing
Fixed Wing's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Pentathlon Evo - Electric
Quote:
ORIGINAL: mtcarey
Why not mount the motor directly to the firewall without the metal mount?
Not sure what you're referring to as a metal mount? The Q60 comes with arearmount that is attached directly to F1.
Fixed Wing is offline
Old 01-31-2011, 06:02 PM
  #102
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is it ok to mount AXI F3a directly to the firewall?
mtcarey is offline
Old 01-31-2011, 07:00 PM
  #103
Fixed Wing
Fixed Wing's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe someone else can chime in here. I am not familiar with the AXI F3a motor.
Old 01-31-2011, 09:00 PM
  #104
jarvis johnson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes the AXI mount will work, just fine. My electri Pentathlon, had the AXI 5330 f3a motor, had more power than needed
jarvis johnson is offline
Old 02-03-2011, 11:16 AM
  #105
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mtcarey is offline
Old 02-03-2011, 02:38 PM
  #106
RC_Pattern_Flyer
RC_Pattern_Flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes... but the fire wall it too far back. i have not used standoffs to mount a motor.... I built a new firewall and put it in at the correct distance.
Chuck
RC_Pattern_Flyer is offline
Old 03-26-2011, 05:58 AM
  #107
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I need help with this rudder
Ive tried 4 times to make it stright. Anyone give me some detailed building info and pictures?
mtcarey is offline
Old 03-26-2011, 06:03 AM
  #108
MarkGrabowski
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: mtcarey
If I may suggest, take a look at the "Viper build" thread on this forum... Jeff has photos showing how he built his rudder, which at first glance, seems similar in construction...
MarkGrabowski is offline
Old 03-26-2011, 11:37 AM
  #109
RC_Pattern_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the one on the left looks like the rudder out of the kit. what part is not straight? the leading edge where you have the ruler?
Chuck
Old 03-26-2011, 08:14 PM
  #110
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The trailing ede is bowed..
mtcarey is offline
Old 03-27-2011, 04:52 PM
  #111
flyintexan
flyintexan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MT,
Sorry you are having some much trouble.
The rudder design is not typical as the thickness tapers from the top and bottom and peaks at the 4th rib from bottom (largest chord). If you attempt to build and/or sheet with the structure laying flat on the table, it will result in a bowed shape. The frame can be dry fitted in the jig. By fitting sheeting between the frame structure and the jig, it can be ca'd together while in the jig under slight pressure (sandbag, etc.). Without removing from the jig, the second side of sheeting can be applied. Afterwards, the TE sheeting can be gently sanded back to the rib TE's and capped with scrap balsa.
Hope this helps a bit.
Best Regards,
Mark
ID:	1585103   Click image for larger version
ID:	1585104   Click image for larger version
ID:	1585105   Click image for larger version
ID:	1585106   Click image for larger version
ID:	1585107   Click image for larger version
ID:	1585108   Click image for larger version
ID:	1585109   Click image for larger version
ID:	1585111   Click image for larger version
ID:	1585112   Click image for larger version
ID:	1585113   Click image for larger version
flyintexan is offline
Old 03-27-2011, 06:01 PM
  #112
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great this is what I needed. Got to get busy. Want to be done in two weeks. Anyone fiberglassing the fuse?
mtcarey is offline
Old 04-02-2011, 08:39 AM
  #113
maustin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mtcarey
I glassed my Pentathlon and it came out light. I used 3/4oz cloth and Zpoxy finishing resin. I also watched Don Ramsey's cd on doing a light finish and also used the microballoons brushed on before the epoxy it setup. First time I've tried this method over using polyester resin and not sure I like it as it seemed the epoxy took a longtime to fully cure hard. As I later found out the trick may be to use Acetone as the thinner vrs alcohol. Also I covered all the tail surfaces with med silkspan and nitrate dope to keep the tail light. K36 primer brushed on and ALL sanded back off, then Concept paint from Radio South. Good luck, you will love the way the plane flies.
maustin
maustin is offline
Old 04-03-2011, 04:01 PM
  #114
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds good... Where can I get the CD? Can you post pictures?
Can you elaborate on the microballoons
mtcarey is offline
Old 04-03-2011, 04:55 PM
  #115
maustin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Use this link http://pages.suddenlink.net/donramsey/ and click on the how to video link for ordering info. He also covers the microballoons technique in the video. Good luck with your project.
maustin
maustin is offline
Old 04-04-2011, 08:37 AM
  #116
KGSS28
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mtcarey . You can find all the info in the video on the Black Magic thread . I have put a link below, it will get you right in the middle of the surface prep and glassing . I am about to give it a try on my Pentathlon also.
http://www.rcuniverse.com/forum/m_61...12/key_/tm.htm
KGSS28 is offline
Old 04-04-2011, 10:16 AM
  #117
Doug Cronkhite
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hmm.. Maybe a Pentathlon Evo fuse with Dave Snow's Spark wings and stabs? That could be an interesting combo...
Doug Cronkhite is online now
Old 04-24-2011, 06:20 PM
  #118
RC_Pattern_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is my newest ride.
10 lbs 10 oz with 2600 mah Fromeco, Rhino 4900s, Airtronics SD 10 for guidance. Hope to maiden this week!
Chuck Hochhalter
Old 04-24-2011, 11:43 PM
  #119
Fixed Wing
Fixed Wing's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice Chuck! Give us more details. What motor, etc.? Keep us posted on the maiden. Bringing it to Houston?
Old 04-25-2011, 04:18 AM
  #120
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More pictures!!!
mtcarey is offline
Old 04-25-2011, 12:28 PM
  #121
RC_Pattern_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am running a pletty Evo 30-10. Castle 85HV. Rhino 4900.
Airtronics SD 10 FHHS3 w 10 channel receiver and dual elev servos.
Chuck
Old 04-25-2011, 12:33 PM
  #122
RC_Pattern_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will have it in Houston. Dont want to risk the Beryll if the wind picks up too much so I can still fly with a good plane.
Chuck
Old 04-28-2011, 11:17 AM
  #123
RC_Pattern_Flyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Off to MAIDEN wooo wooo.... reports tonight.
Chuck
Old 04-28-2011, 11:37 AM
  #124
mithrandir
mithrandir's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hope it all goes Stellar'ly!!
With a name Like Pentathlon... I hope you get 5 flights!!
lol
mithrandir is offline
Old 04-28-2011, 07:18 PM
  #125
Fixed Wing
Fixed Wing's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: RC_Pattern_Flyer
Chuck
Well ????
Reply
Display Modes
