Pentathlon Evo - Electric
#126
TX
RE: Pentathlon Evo - Electric
It flies!
And, well, its not the perfect plane with no mix and flies 10's.... alas.
BUT.... it really does fly well. I used a 22X12 APC and although at times I liked the pace it was zoomy? Meaning, pace was good add throttle, a little more and ten whoosh it would accelerate. yes, I know, I need a throttle curve etc but I want to play with a couple of props first.
I got 3 decent flights in but realized that a swept gear is not a good combo on this plane. I have since replaced swept with straight gear.
I really cant say too much, I have trimming and mixing to do.
As most Pentathlons, it wants to roll onto its canopy in knife edge and it barely goes to the canopy in downlines.
Chuck
Chuck
#131
Can anyone help with the location of the c of g for the Pentathlon Evo please?. I'm currently building a Pentathlon and hoping to power it with the OS 33GT.
Many thanks Bob V
Many thanks Bob V
#134
CA
I have been speaking with Mark this week have decided to build this plane myself, im excited. I also just moved to Indiana so I'm in the process of setting up my new indoor shop! I'd like to take this opportunity to setup a really nice, straight and flat building table, a necessity for building this plane. Can you give be recommendations on what you are using?
Thank you in advance for your help!
Bob
Bob
#135
CA
The fuse portion of the wing socket was installed using the flat table as a reference and equal height blocks to ensure level placement. In addition, the wing tube was installed through the socket with equal lengths protruding on each side of the fuse. The tube tips were then triangulated with the center of the back of the fuse using a marked string. Once everything was verified and triple checked for being properly square the socket was left alone to cure. 30 minute epoxy was used with milled fiberglass for added strength. Once cured the excess socket material was sanded flush with each of the fuse sides.
Separately, sockets were installed in each of the foam wing cores. The cores were placed in their shucks and temporarily joined together with the wing tube in place under moderate weight. Having the wing tube in place during this process keeps the socket from compressing out of round when the weights are applied. The weights were used to ensure the sockets are actually level and flat with each other so they are properly aligned vertically when installed on the plane. Distances between the core leading edges and trailing edges were measured to make sure the sockets weren't misaligned in the cores front to back so that the root ribs will still flush with the fuse sides. You can't see it but there is a subrib installed that each wing socket protrudes through near its end. Poly glue was used to secure the sockets and sub ribs in the cores.
Thank you,
Bob
#136
My Feedback: (23)
I bought a HD table but the surface wasn't perfect so I built I reinforced a solid core door and put it on top. I've been building a 40% Dalton 300 on it and it didn't bend when I was sheeting the wings.
These pictures are a little old and I've moved twice since I built this. It is still straight and if it warps, I just go get a new solid core door.
#137
This is my work bench from a couple three years ago. http://www.rcuniverse.com/forum/kit-...tos-added.html
If I were to change anything I would add one more rail and would add some cross bracing between the rails. I would also make the top and bottom stressed skins out of 3/8 ply and still use the removable/replaceable working surface top. It is a little too wide but that is not the worst thing in the world. It turned out to be very stable and shake free when sanding. No further bracing of the legs is needed. Overall I'm very happy with the bench. OH... On advantage of the removable working surface is the ability to remove it and use sheets of paper to ship the top perfectly flat if you need to remove a built in warp. I did just that with mine. For some reason the front edge only was about 1/32 low in the middle. I use typing paper for shim stock. It is now flat and true.
Ken
Ken
