If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 276 to 300 of 347
  1. #276
    Join Date
    Jan 2012
    Benalmadena CostaMALAGA, SPAIN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: New Krill Spark Evo I- Build Thread.....
    Hi Jason....On the following flights will check if this is enough.
    Probably due to aileron deflection is much to get good snaps ... in this case, the mechanical strength is higher.
    I will show the results, of course.
    good reflection of yours.
    regards
    Andres Girabel
    Home web video
    http://www.youtube.com/user/andresgirabel
    https://vimeo.com/groups/f3a
  2. #277
    Jason Arnold's Avatar
    Join Date
    Aug 2005
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Andres,
    I remember you and Andrew using big servo horns in order to get snaps the way you liked. Perhaps this extreme throw has caused an issue.
    Are you using the new wings on your EVO? I believe the ailerons were increased in size to help with snaps on subsequent kits. If I'm not mistaken, it even looks like the outboard end of the aileron is larger than the root end. May just be an optical illusion....
    For what it's worth, I have found that kevlar can become very brittle to the point of breaking when CA is used. I found this on F3P models with kevlar pull, pull cables. By using epoxy there is some degree of flexibility.
    Cheers,
    Jason.
    Precision Aero Products
    http://www.precisionaeroproducts.com.au
    Your Australian/New Zealand source for the Allure by CK Aero, Ralph Schweizer CRS and MKS Servos.
    Ph: +61-0478909530
    E-mail: sales@precisionaeroproducts.com.au
  3. #278
    Join Date
    Jan 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Jason..
    Correct your appreciation and very logical.
    Yesterday I was talking with Krill Models and the conclusion is do the same as in the large ailerons, a small hinge on the ends.
    There are, how you know, micro hinges from Robart, for example.
    I will pics about this..
    Of course, Jason... great aileron deflexion is the cause of all this...
    However, our final approach, this configuration is for acceptable snaps,and the model for the rest of maneuver, works beautifully..really.
    Here in Spain, fought the F3a Nats podium with pilots who have OXAI models only,...heheheheh !!!!.... you know.
    Thanks for yours comments....
    regards
    Home web video
  4. #279
    Join Date
    Jan 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Already done....
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1741206   Click image for larger version.
    Home web video
  5. #280
    rgreen24's Avatar
    Join Date
    Jan 2002
    Omaha, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I decided to seal my aileron, and elevator hinges on the Evo. a few noticeable differences, i observed. The snaps were better without the awful screech, i also noticed i had more elevator authority, so needed to add more expo to down elevator. Did not notice a difference with rolling left or right still seems pretty axial. Will let you know if anything else positive or negatives happens. Was only able to put in three flights, had some weird winds tonight.
  6. #281
    Join Date
    Aug 2005
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How did you seal the ailerons? Photos?
    Cheers,
    Jason.
    Ph: +61-0478909530
  7. #282
    Join Date
    Jul 2006
    Ossining, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rgreen24
    Just to follow up... what method did you use to seal the aileron hinges?
    I have been considering options to do this myself.
    Bob
  8. #283
    rgreen24's Avatar
    Join Date
    Jan 2002
    Omaha, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    [/quote]
    [/quote]
    I used a Mylar hinge tape similar to what many other folks did on thier Integrals to get rid of the screech and seal all the hinges. Here is a picture of my aileron with the gap sealed
  9. #284
    Join Date
    Jan 2012
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    FAI sequence F-13, Jonathan Girabel...with Wing wood from David Snow....another plane !!!!!!...finally, 240 grs out...
    http://www.youtube.com/watch?v=ttTy1...ature=youtu.be
    best regards....
    Home web video
  10. #285
    rgreen24's Avatar
    Join Date
    Jan 2002
    Omaha, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Did anyone find the reference line to zero the stab on there Spark evo? I used the Canopy area, and was just curious was everyone else used? There are no dimples on my fuse to use as a reference like there is on the Dynamic
  11. #286
    rgreen24's Avatar
    Join Date
    Jan 2002
    Omaha, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Also did anyone put a rear bulk head in for stability?
  12. #287
    Join Date
    Jul 2010
    gosport, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hi,
    jig the model and set the wings +1/2 deg , the bring the tail in to zero deg with adjusters on the tail, no need to add any crutch to the spark ,this is a good starting point , the fuzz shape incorporates the strength required.
    rgds
    steve u .
  13. #288
    rgreen24's Avatar
    Join Date
    Jan 2002
    Omaha, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Steve
  14. #289
    rgreen24's Avatar
    Join Date
    Jan 2002
    Omaha, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well after talking with several people about the airplane, i decided to add a ladder system in the fuz for strength and durability. this was fairly easy to do, and only added 7 grams. I also decided to extend the rear horizontal brace where the stab is attached. It made a huge difference in making the more stiff fuz. In the masters sequence- the inverted push with a 2 of 4 and 1/2 outside loop 1/2 roll down. When i pushed it seemed like the plane would want to yaw to the right; not sure if the fuz was flexing when i pushed. After adding the ladder and extending the horizontal brace, the plane no longer does this, i could not be more happier with it now in this maneuver...now to work on the triangle snap. Pictures attached
  15. #290
    Join Date
    Sep 2006
    Indianapolis, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can anyone else not see the pics at the start of this thread?
    Lou
    Don\'t Panic
  16. #291
    rgreen24's Avatar
    Join Date
    Jan 2002
    Omaha, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Can't see them either not sure why
  17. #292
    rgreen24's Avatar
    Join Date
    Jan 2002
    Omaha, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey guys quick question for you. Those that are flying the Spark, did you leave your wing at .5 degree positive or did you add some more positive to the wing incidence? Reason I ask is that I have almost 2 degrees of down thrust and on uplinks the plane is still pulling to to canopy. M stab is at 0 degrees relative to the wing, and I am carrying a little down trim. Any insight would be helpful.
    Thanks in advance
  18. #293
    woodie's Avatar
    Join Date
    Jun 2002
    Placerville, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How is the knife edge, pulling either belly or canopy? If pulling to the belly, even a little, I would suggest moving the cg forward a bit until the tuck goes away. You will probably find the pull to the canopy will also go away. I am flying my Evo with the cg close to the back of the wing tube and I added a tiny bit more positive incidence. Knife edges straight on both sides and vertical up straight.
    Woodie
    There is nothing so simple it can't be messed up by someone....
  19. #294
    rgreen24's Avatar
    Join Date
    Jan 2002
    Omaha, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Woodie, this is the weird thing on knife edge it does not pull to canopy or gear. This is why I am baffled with the long up lines pulling to canopy
  20. #295
    woodie's Avatar
    Join Date
    Jun 2002
    Placerville, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yeah, the Evo seems to be surprisingly insensitive to incidence/cg changes when it comes to knife edge tracking. I would try moving the CG forward a bit and try the uplines, easy test.
    Woodie
  21. #296
    Join Date
    Apr 2003
    Vikersund, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi
    Just got my Evo , have just take a smal look at and so fare it looks wery nice!
    But I noticed that its no wing adjusters in the kit but its a extra hole in the root off the wing , is it ment only to be the 2 bolts to secure the wing from rotate??
    I'm thinking about adding a adjuster to have the possibillity to adjust , what have you others done?
    Rune Gjelsnes
    email: rungjels@gmail.com
    Norway
  22. #297
    woodie's Avatar
    Join Date
    Jun 2002
    Placerville, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rune, My Evo did not have adjusters, only the two bolts on each side. However, the incidence/ wing alignment was very good, my aileron trim was very close after the test flights. I have increased the incidence slightly but did that by elongating the holes and filling back in with CA. I changed the incidence less than 1/32". Very easy, maybe not as convenient, but only takes a few minutes.
    Woodie
  23. #298
    Join Date
    Nov 2012
    , AUSTRIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi,
    i'm planning to build an Q80 into my Spark Evo. Does anyone know how much right thrust and downthrust the plane needs?
    it seems as if there were no right thrust and down thrust were build in.
    thanks
    björn
  24. #299
    woodie's Avatar
    Join Date
    Jun 2002
    Placerville, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My Spark Evo did not have any right or downthrust in the nose ring relative to the wing and centerline. I ended up with about 1 degree right and .5 degree down in my Evo.
    Woodie
  25. #300
    crazyf3a's Avatar
    Join Date
    Oct 2004
    Klagenfurt, AUSTRIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi to All
    Today, I've measured my spark. When I set the left Wing to zero the right wing has a incidence of -0.4 degrees or so.
    What have you done. Wing adjuster are possible. Have you measured the same. Three of my Friends Spark have the same. When I do nothing i Thing I must trimm the Ailerons. And they will Not stand at O Position.
    SR
    Andreas
    The Ground is the Limit. Not the sky.
    Andreas
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
