If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 14 of 14 FirstFirst ... 4121314
Results 326 to 347 of 347
  1. #326
    Join Date
    Apr 2003
    Vikersund, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: New Krill Spark Evo I- Build Thread.....
    I started with the cg as Jesky adviced, stab 0 cockpit is zero , wing 0,5.
    this is a good starting point , I added some more right thrust and moved the battery about 1,5 cm back .
    So fare no mixes exept idle to 2% down.
    Rune Gjelsnes
    email: rungjels@gmail.com
    Norway
  2. #327
    awry's Avatar
    Join Date
    Sep 2009
    Sandnes, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have my CG at 220mm from leading edge.I think Jesky has his CG at 215mm.My stab is 0 incidence and main wing at 0.7 positive. I've added more downthrust. About 1 degree down and 1.5 right. My plane is about 4820g RTF.
    You should at least have 0.5 positive on the main wings or the plane will fly tail low unless you have your cg quite far back.
  3. #328
    awry's Avatar
    Join Date
    Sep 2009
    Sandnes, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    All three Sparks in our club.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1880741   Click image for larger version.
  4. #329
    Join Date
    May 2008
    Quito, ECUADOR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just finish my Spark Evo and did my first flight. The plane is awesome. CG is at 220mm and both my wings are +.06 stabs are 0. Added a little of down trust and right thrust. Flying weight is with TP4400 G6 4785g and with TP5400 G6 4930g.
    My setup is:
    Hacker Q80 13XS F3A
    Falcon V2 20.5 x 14.5
    Jeti Spin99 Pro
    Futaba 18Mz
    Futaba R7008SB with telemetry on the receiver battery and motor battery
    6.0V system
    Ail BLS551
    Ele BLS651
    Rud BLS352
    Thank you Ivo for your help and fast delivery. This is a great flying plane. Finish quality is awesome. [8D]
    My throws are:
    Pattern Flying:
    Ail 12 degrees Ele 14 degrees and Rub Atvs 65%
    Stall
    Same as pattern but Rud Full movement
    Snap
    Ail 35 degree Ele 6 degrees and Rub Atvs 42%
    Have a question for Spark Evo owners: What throws are you using for the different condition we have in F3A??????
    Regards,
    Ney
    [img][/img] [img][/img] [img][/img] [img][/img]
ID:	1881905   Click image for larger version.
ID:	1881906   Click image for larger version.
ID:	1881907   Click image for larger version.
  5. #330
    Join Date
    May 2008
    Quito, ECUADOR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here are some pics of my 2 SparkΒ΄s. Final setup:
    Hacker Q80 13XS F3A
    Jeti Master Mezon 95
    Futaba 18Mz
    6.0V system
    Ail BLS551
    Ele BLS651
    Rud BLS352
    All I can say is that they are great flying planes. No problem at all for P-13, P-15 F-13 and F-15 . Looking foward for the new F3A plane by Krill
    Regards,
    Ney
  6. #331
    Join Date
    May 2008
    Quito, ECUADOR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sorry forgot to put the pics.
    Ney
ID:	1886148   Click image for larger version.
ID:	1886149   Click image for larger version.
  7. #332
    woodie's Avatar
    Join Date
    Jun 2002
    Placerville, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    namancheno
    Nice looking pair of Sparks.
    What is the difference between a Spark Evo I and a Spark Evo II?
    Woodie
    There is nothing so simple it can't be messed up by someone....
  8. #333
    Join Date
    May 2008
    Quito, ECUADOR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Woodie:
    Nothing only is the sticker, honest mistake and had the stickers made wrong. [&o]
    Only thing I change are the wheel pants ( I think they look much cooler this way + 34g less) , wheels and put 3 reinforcement on the back of the rud servo tray.
    Regrads,
    Ney
  9. #334
    woodie's Avatar
    Join Date
    Jun 2002
    Placerville, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks namancheno
    Thought I had missed a model change announcement.... ;-)
    Woodie
  10. #335
    desertrat65's Avatar
    Join Date
    Jan 2010
    Dubai, UNITED ARAB EMIRATES
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi All,
    I am slowly putting my Spark Evo 1 together. Can someone that has experience building this model please post the correct method of installing a Hacker Q80 14xs into the model? Particularly how to go about setting up the correct right and down thrust into the firewall and how to achieve the best gap between the spinner and the fuselage.
    I have the Krill supplied firewall for the Q80.
    Any help would be greatly appreciated.
    Thanks, Adam.
  11. #336
    Join Date
    Jun 2006
    vern sur seiche, FRANCE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello Ney!
    Don't you think that a Falcon 20.5 x 14.5 is too much load for a Q80-13XS?
    I have this motor, with Spin 99: very powerfull, and no problem with an apc 20x13.
    If I put an Ulsamer 21x13 W or an Apc 20.5 x14, there is a risk of the motor screeching (loss of synchro) if the battery is a new one and fully charged, even with the throttle limited (-100% - + 60%)
    Have you ever had this problem? Or have you reduced the timing? (25Β° on mine)
    Thanks, regards,
    jean-Claude L'Hostis
  12. #337
    Join Date
    Jan 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi all,
    I really need some help here.
    I have loosely fitted the motor and prop parts together for my Hacker Q80 and Falcon 21 x 14 prop.
    1. Firstly do I need to use the Flange washer and spacer that came with the Q 80 as they do not fit with the Krill supplied Q 80 engine mount?
    2. The prop does not seat properly on the spinner back plate. Do I space the prop up - or do I cut the spinner back plate to suit the propellor?
    Thanks for any help.
    Regards, Adam.
ID:	1890507   Click image for larger version.
ID:	1890508   Click image for larger version.
  13. #338
    Join Date
    Feb 2008
    Dubai UAE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Matt Hoyland has the answer : http://www.gbrcaa.org/smf/index.php?topic=2444.0
  14. #339
    Join Date
    Jan 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Guys,
    I kept fiddling with the motor prop assembly.
    I realised I had the prop on backwards. Oops!!!
    The prop seats properly on the spinner back plate.- Few!!!!!
    I used the flange washer and spacer on top of the Krill Q 80 mount and all, seems to be OK.
    If any body can see an error please let me know.
    Thanks, Adam.
  15. #340
    Join Date
    Jan 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Dave,
    Thanks for the link.
    Will I see you at Lisailli on Friday?
    Regards, Adam.
  16. #341
    Join Date
    Jan 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Deleted.
  17. #342
    Join Date
    May 2008
    Quito, ECUADOR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jean-Claude:
    I agree 100% with you. At low altitude I will used a max of 20x13 prop but where I live (Quito-Ecuador second highest capital in the world) our flying field is around 2830 meters above sea level (9284 feet) so this is why a need just a little extra on the prop. When I go down to lower cities for competition if it is below 1500 meters (4921 feet) I change the prop and some settings.
    My settings for:
    High Altitude:
    Timing 24Β°
    Th Curve is -115% for brake -97% idle (around 1500-1700 rpm) 78% for Full Th.
    Acc time is 1.5 seconds
    Brake is Manual start 38% final 78%
    I used 20.5 x 14.5 and 20 x 14.5 props and get around Β± 6800 rpm and no more than 72 amps
    I fly Ps with TP 4400 and land with Β± 37.5 volts
    I fly Fs with TP 5400 and land with Β± 37.9 volts
    Lower Altitude:
    Only things I change are: Brake much lower starting and final %. Prop to a max 20x13. Timing 25Β°.
    Th Curve setting to achieve Β±6500 rpm and a idle of Β± 1300 rpm
    Only change Snap throws and put around 15% to 20% more Expo on all flight conditions.
    Regards,
    Ney
  18. #343
    Join Date
    Jun 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello Ney:
    Thanks for your response and these very interesting considerations.
    I suppose that you could be of a good advice for lot of people going to the WC in South Africa and who are asking themselves a lot of questions about the settings for flying at 1500m (high?) altitude.
    Yesterday I tried lowering the timing to 23Β° and 24Β° and all seems ok with 21x13W.
    my settings (subject to change...):
    - acceleration: 1.0s
    - brake: 0.2s,18%, 50%, 1,5s
    - timing: 23Β° - 24Β°
    - full throttle travel limited to 60% for a new battery and 100% for my old ones (300+ flights)
    regards,
    jc
  19. #344
    Join Date
    Jan 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi All,
    Just an update of my install of the Q80 into the Spark.
    It is installed!
    All went in very easily in the end. Correction to my last post I have used the Flanged washer and all the parts supplied with the Q80.
    I hope this helps any other newbies installing a Hacker Q80 into a Spark.
    Regards, Adam.
  20. #345
    Join Date
    Jun 2003
    Fort Worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Is there an advantage to using the low profile BLS 551 servos for the ailerons. It looks like a standard size servo would fit in the wing
    thank you, murry
  21. #346
    Join Date
    Sep 2004
    Fremont, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Quote Originally Posted by murry View Post
    thank you, murry
    BLS551 is lighter.
  22. #347
    Join Date
    Mar 2010
    Mendon, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Quote Originally Posted by woodie View Post
    namancheno
    Woodie
    Evo II is a new design...
    New Spark EVO II on the market....
    interesting designed air intake.
    Chief Aircraft will be accepting special order only as soon as they have price and availability info ... Just received email tonight
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
