Lightning Build
#527
MB, CANADA
Is it still possible to request the plans via email?? It is a beautiful looking bird. My email is [email protected]
#530
Hi there,
I also started building a Lightning some time ago. Due to other priorities in life the project had been on hold for a little while but I recently picked it up again.
#546
At the moment I am preparing the parts to build the wing. As I will not be using foam cores I need to create a rib structure. The plans give plenty of detail to realize this, just need to be a bit creative here and there.
#547
#548
IN
Fred,
Your photos are great and will greatly help me with my Lightning build.
The only question I still have is how/when do I install my soft motor mount for my inrunner motor.
Bob
Bob
#549
I took the wingroot from the drawing and resized it in 10 steps. I added some spars and this gave me a set of ribs to build the wing.
#550
I will be fitting an outrunner but the drawing also includes a special bracket for an inrunner motor.
Once this bracket is glued in place you can easily mount your inrunner.
See attached pic from Jeff's build below.
