Russian F3A masterpiece “Europa PRO LT” now produced in Europe
Most of us remember DOSAAF and good times in Soviet Union airfield when flying was free, and basically everyone that had wish could fly.
Travel destination was to building up relationships with the manufacturer to obtain a permit to manufacture the Europa PRO name models in Europe with a further passage to European markets because we do not have additional taxes and duties on exportation of goods to European Union countries.
Mr. Algis (left) and Mr. Sergey Danilov (right):
The factory is located in the small town near Moscow – Orexovo/Zuev, with population of about 200 thousand people. Spent working week went as a day: a very nice communication, information rendering, and pleasant staff.
Finally, a permit to manufacture the Europa PRO name models in Europe was obtained. Models produced in Europe will have two additional letters of the LT at the end of the previous name; the full name of the airplane will be Europa PRO LT.
Next let's talk about a European version of the Europa PRO LT aircraft and its production process.
The new Europa PRO LT was designed by Great Russian aerobatic pilot, Sergey Danilov (Master of Sports, F3A Champion of Russia, since 1996 participated in the European and the World Championships) and produced in Europe using top quality German made epoxy resin and glass/carbon fiber.
One of Russian Europa Pro planes:
Plane Specifications:
Wing Span – 1900 mm;
Length Including Spinner – 1960 mm;
Weight (empty) – 1880 grams;
Weight (RTF) 4400 – 4900 grams;
Recommended power system: AXI 5325/24 Gold line Brushless motor plus JETI Spin 99 controller.
This professional Europa PRO LT kit is the result of Sergey’s 20 years experience in F3A world and his research in best F3A performances. This innovative design combined with the extremely lightweight structure, the full composite fuselage, wings and stabs, give the Europa PRO LT an impressive precision and smoothness at any airspeed and flight condition.
The plane is a total novelty in the 2010 – 2011 F3A seasons: the new fuselage is wider; wing area lower; the stabilizer has now become larger.
Let’s briefly review the model production technology in Europe:
Europa PRO LT all-composite professional F3A aircraft completely made using Total Area Vacuum Sandwich technology.
Fuselage (note carbon fiber in the motor mount area):
More photos of fuselage internal structure. Lots of carbon fiber inside:
Nose:
Chassis mounting plate:
Additional carbon thread on the fuselage frames:
Stabs:
Wings (note carbon fiber in the ailerons area):
In order to ensure the highest possible accuracy, all internal components are mounted using templates.
Dual control ensures quality (note carbon fiber in the rudder area):
Just removed from the molds:
Fuselage:
Stabs:
Wings:
Impeccable quality and perfect lines after the final trimming:
Two masterpieces met – white F3A “Europa PRO LT” and new Donatas Pauzuolis F3P design “SYMMETRIC”:
Next time I’ll add additional information about model assembling process and much, much more.
Regards
Kyssa
Mark
all the plane (wings, stabs, fiuselage) are made using Airex foam and glass fiber with some balsa and carbon fiber reinforcements.
Regards
Kyssa
Might be a browser setting. The pics are very big and take a while to download.
Cheers,
Jason.
Tom M.
Before describing the assembly process, I would like to acquaint you with accessories that come with the plane.
Stab hardware pack:
Rudder hardware pack:
Landing gear hardware pack:
Motor mount cooling holes in full compliance with the engine cooling channels:
Benefits:
The final look:
Not to insult any designers out there, but recent new designs have left me a bit... well, confused, I guess is the best word. I haven't seen anything new in a while that actually interested me or had 'it'. But I gotta say, the Europa PRO is a nice looking airplane!!! Dare I ask what the projected price is going to be? I know it's out of my range, but I had to ask...
Tom M.
Painted in Molds Series is highly prefabricated for you. Only few hours of work will be needed to get Europa PRO LT ready to fly.
Nice plane...
Any info about where we can buy this nice bird? How to order?
Some stores where this plane is on stock?
thanks
Branko
if any of you want to order this plane, just contact me by e-mail:
[email protected]
we will discuss for completeness, paint scheme and discounts for the first customers.
Best regards
Kyssa
Sounds like a pretty good deal, everything in the package looks amazing!
Too bad I already told my girlfriend how much these things cost [:@]
You said the magic word...girlfriend....she doesn't have a ring, so her opinions should be limited
Arch
Arch
Let's start the collection process.<o></o>
<o></o>
Items Needed To Complete[/b]<o></o>
Personal protective equipment[/b]<o></o>[/b]
The fuselage, wings, stabs, rudder, landing gears and other parts included in this kit are made of fiberglass and carbon fiber, the fibers of whose may cause eye, skin and respiratory tract irritation. Never blow into a part to remove fiberglass and carbon fiber dust, as the dust will blow back into your eyes. Always wear safety goggles or safety shield, a particle mask and rubber gloves when grinding, drilling and sanding this parts. <o></o>
<o></o>
<o></o>
Vacuum the parts and the work area thoroughly after working with fiberglass and carbon fiber parts. <o></o>
Tools<o></o>[/b]
<o></o>[/b]
- Felt-tip Marker or Pencil<o></o>[/b]
- Sander<o></o>[/b]
- Ruler Metric and Standard<o></o>
- Course and Fine Sandpaper<o></o>
- Phillips Screwdriver (small)<o></o>
- Pliers<o></o>
- Dremel Power Tool<o></o>
- Rat tail file<o></o>
- Cut-off wheel<o></o>
- Hobby knife<o></o>
- Paper Towels<o></o>
- Synthetic oil<o></o>
- Soapy water solution<o></o>
- Plastic card<o></o>
Adhesives<o></o>[/b]
- 15 and 30 Minute Epoxy<o></o>[/b]
- Thick CA (cyanoacrylate) glue<o></o>[/b]
- Masking Tape<o></o>[/b]
- Double-Sided Tape<o></o>[/b]
- Epoxy filler<o></o>[/b]
- Thread Locker<o></o>[/b]
- Acetone/Alcohol swabs or Rubbing alcohol<o></o>[/b]
- Paper or plastic caps<o></o>[/b]
- Wooden coffee spoons <o></o>[/b]
- Cotton buds<o></o>[/b]
<o></o>
- Main LiPo pack<o></o>
- Receiver LiPo pack<o></o>
- Receiver<o></o>
- Speed controller<o></o>
- Brushless motor<o></o>
- Carbon Propeller<o></o>
- Receiver voltage regulator<o></o>
- Servo arms<o></o>
- Servo Extension leads<o></o>
- Servos<o></o>
I think a few pictures can say more than a thousand words. Let's start from the aileron assembly process.<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o>
Regards
Kyssa</o>
<o></o>
