Prop size
Prop size
I just went out and tested my Turnigy 230Kv Outrunner using a 10S, 4000 milliamp battery and a 19-10 prop. I was only pulling 45 amps and about 1500 watts, is this underpropped? I haven't charged the batteries yet and they were just in the as shipped charge. This is my first large electric.
My Feedback: (8)
RE: Prop size
ORIGINAL: Jeff-RCU
Definitely charge the batteries, and as you cycle (use and recharge) they will start to give you more power. They probably came at 3.7-3.8V, and at a full charge will read around 4.2V.
What (brand, style) prop are you using?
Let us know what happens after a full charge.
RE: Prop size
thanks, I'll cycle them. I'm heading out of town for a week later today, so won't get it retested before I leave. I was reading 37 volts and they didn't drop down any taking full throttle load. It's a turnigy wood E prop, so it's pretty thin. I did go back and look and a lot of people are using 20 and 21" props with this motor on 10S
My Feedback: (29)
RE: Prop size
Jeff, the specs on your motor are very close to mine. Using the Himax 6330-210 F3Aas a reference, most are running a 21X14 on the himax due to a lower KV rating. For our motors at the slightly higher KV we should lighten the load a bit. I will be starting with a 21X12.
