Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Visa´s ready for WC in Muncie
Reply
Old 04-26-2011, 09:58 AM
namancheno
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Visa´s ready for WC in Muncie
Hi everyone:
Finally everything is ready for the WC in Muncie. Here are some pics of my Visa´s that I will be taking to Muncie. I want to thank Chip and Marcelo for the quality of the airplanes. Chip ones again thank you for all your hard work on my planes. The paint job is outstanding on both planes, you really can´t tell all the details from the pictures. [8D]
Here are my setups:
Hacker Q60
Spin 99
Rasa 20.5x14 prop
TP 4350 mAh
TP 900mAh
Ail servos BLS551
Rud servos BLS651
Ele servos BLS651
Digi Switch 5.5 volts
Weights: Blue Nose 4905 g. Pink Nose 4889 g.
Here are some pics.
ID:	1599493   Click image for larger version
ID:	1599494   Click image for larger version
ID:	1599495   Click image for larger version
ID:	1599496   Click image for larger version
namancheno is offline
Old 04-27-2011, 05:33 AM
smcharg
smcharg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Visa´s ready for WC in Muncie
Two more gorgeous airplanes out of Chip and Marcelo. Very nice sir. Good luck at Muncie. Just out of curiosity, which is your "primary" or do you use one for the P Schedule and one for F? Impressive weights as well.
smcharg is offline
Old 04-27-2011, 06:22 AM
namancheno
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Scott:
Thank you for your post. Marcelo and Chip made a very good job on them. Chip had all the patience to put everything I wanted on both planes. You can´t really see all the details on both plane on the pictures but everyone here love the quality of the paint job.
To tell you the truth both planes fly almost the same, but I think the blue nose is #1 and Pink nose is #2. No difference for P-11 or F-11. Both have the same wing incidence and radio set up. Blue nose Visa has a little right thrust in the motor. As far as mixing both have 2% Th to Ele for down lines. Both have 1% for Th. to Rud when you cut the motor. Knife edge Pink nose Visa has .5% of down on the left side and Blue nose has 0% mixing on knife edge. Both have 1% on Rud to Ail and that is it.[X(]
I was lucky to have Chip test flight the Blue nose Visa in Argentina before he shipped the plane to Quito Ecuador. I just copy everything he did to the Pink nose and from the first flight it was 95% ready.[8D]
Take care,
Ney
Old 04-29-2011, 08:38 AM
Passport1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow Ney those look really sharp together maybe we can set all four of them together at the worlds. Mine are going to be very similiar.
C
Passport1 is offline
Old 04-29-2011, 09:33 AM
namancheno
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Chip:
What´s up. That is a really good idea. The 4 of them will look awesome. Looking forward to see you at Muncie. We have to take the pictures.
Take care,
Ney
Old 04-29-2011, 01:58 PM
apereira
apereira's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Espectaculares Ney!!!
Y que pista...
Saludos
Alejandro
apereira is offline
Old 04-29-2011, 02:13 PM
namancheno
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Que hubo Alejandro:
Muchas gracias. Realmente salieron muy bonitos. Vuelan espectacular, todo lo que dijo Chip en Medellin 100% verdad.
Esa es nuestra pista del Club Quito en Jerusalen a unos 30 min. de Quito, lo unico malo son los 2250 mts de altura.
Si vas a Muncie? Con que avion? CaModel o Oxai.............
Por favor dales un fuerte abrazo de mi parte a todos alla en Venezuela.
Saludos,
Ney
Old 04-29-2011, 03:22 PM
apereira
apereira's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hola Ney,
Pues esta muy bonita y cuidada esa pista, te digo, hemos hablado de la altura en el regreso de Medellin, y de verdad, como vimos alla, los YS andan igual de bien, sea electrico o YS, lo que importa es que sea bonito el campo y el ambiente que hacemos, ojala podamos hacer una alla, no conozco Ecuador
Y si vamos a Muncie, pero solos Tuny y yo, yo me llevo los Oxai, el Axiome y el Amethyst Mod, asi sean glow y electrico, ese Hacker va tan bien que no me costo nada acostumbrarme a uno o al otro, solo espero poder hacer mas vuelos llegando a la Fecha, mucho trabajo, pero eso paga el hobby, jejeje.
A todos les dare tus saludos, e igual para todos alla, seguimos en contacto y nos vemos en Muncie.
Alejandro
apereira is offline
Old 04-29-2011, 04:31 PM
Doug Cronkhite
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Speaking of Visa airframes being ready to go.. I happen to know of a RTF airframe (no equipment) that's for sale for $2000 + shipping. The original purchaser had to back out due to work issues. Just thought I'd pass the word along. It's apparently ready to ship right now.
Doug Cronkhite is offline
Old 04-30-2011, 01:28 PM
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bellos aviones Ney!!
cuando llegan a Muncie? como viajan?
Saludos!!!
TUNY
tuny is offline
Old 05-02-2011, 06:10 AM
namancheno
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Alejandro y Tunny:
Del equipo ecuatoriano solo vamos Santiago y Yo. Lastimosamente Pablo no va a ir al mundial. Yo estoy llegando a Muncie el 20 de Jul. al Day´s Inn que más o menos queda a unos 10 minutos de la sede de la AMA. Santiago creo que llega a Muncie el 21 de Jul. Los dos nos vamos por Lan Ecuador hasta Miami. Santiago va por carro desde Miami a Muncie, ± 19h, que macho!!!!!!! Yo voy donde mi hermana que vive en Fort Lauderdale y mando la caja v*a UPS a Muncie y voy en vuelo interno hasta Indianápolis y de ah* en carro.
Seria hermoso poder hacer un evento Internacional en nuestra pista. Lo único malo es que los aviones no vuelan para nada igual a Medell*n. Hay much*simo menos aire y no vuelan tan lindo como alla. El otro problema que tenemos es que tipo 11h30 hay un viento que da miedo volar, no es constante y muy cambiante, t*pico viento de montaña de la sierra.
Ustedes como se van? Cuando llegan? Ya saben dónde van a ir a practicar? Yo es primera vez en Muncie y no tengo ni idea de dónde ir a practicar.
Un fuerte abrazo,
Ney
Old 05-02-2011, 06:31 AM
tuny
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ney escribeme aqui y te cuento, tuny90@hotmail.com
tuny is offline
Old 05-20-2011, 05:11 PM
Drojasf3a
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Epale Neyyy!!! muy bonitos quedaron los Visa , te deseo mucho exito en muncie que lastima que Pablo no puede ir, bueno yo tampoco puedo jejeje pero para colombia si voy el año entrante si dios quiere.
bueno muchos saludos y les deseo mucho exito en Muncie, estoy seguro que van a realizar muy buenos vuelos un abrazo para ti y muchos saludos a todos en Ecuador
Daniel Rojas
Venezuela
Drojasf3a is offline
Old 05-23-2011, 06:23 AM
namancheno
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Daniel:
Muchas gracias. Espero que nos vaya bien. Si es una pena que Pablo no va. Que lastima que tu tampoco vas. 100% seguro nos vemos en Colombia.
Un abrazo y muchas gracias por tu post.
Saludos,
Ney
Old 06-27-2011, 01:20 PM
Passport1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are a few pics of mine for the worlds. I have been so busy practicing and with the shop I have not had time to get here and post. These have been ready for a couple weeks now. They are all disassembled going in the crates at this moment but I through one together for some pics.
C
ID:	1628456   Click image for larger version
ID:	1628457   Click image for larger version
Old 06-28-2011, 06:55 AM
namancheno
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Chip:
Really nice looking plane. Both planes are the same paint job?
Hope to see you at Muncie so we can take pictures with the Visa´s.
Here are some pics of mine in flight.
Take care,
Ney
ID:	1628775   Click image for larger version
ID:	1628776   Click image for larger version
ID:	1628777   Click image for larger version
Reply
Display Modes
