Dean Connectors
Dean Connectors
OK, here's the problem. The turnigy batteries come with some bullet connectors and everything else I have is set up for Dean connectors. So how do you solder 10gage wire to Dean connectors? I've tried a couple of times without sucess. Is there some good way to crimp them together first?
My Feedback: (58)
RE: Dean Connectors
You need a soldering iron that can put out some heat and maintain temperature....also tin the wire well. I tin the wire and the connector then give the end of the wire a little squeeze with a pair of pliers to make a flat on it. Then its a simple matter of holding the two together and applying heat while feeding in a bit more solder. It sounds so easy doesn't it?
RE: Dean Connectors
Tin the 10G wire and let it cool. Use a dremel cutoff wheel to cut a slot in the center of the end of the tinned wire. Push Dean's tab into the cut slot. Should be a snug fit. Use solder iron to heat and bond. Cover with shrink wrap. Works like a charm.
RE: Dean Connectors
ORIGINAL: Jeff-RCU
Thanks FixedWing, I'll try that one. Did I mention I welded my needle nose to the connector?
RE: Dean Connectors
I've noticed that Deans connectors were getting a warmer than I'd like hauling 80A out of an 8s pack. I've since upgraded to 5mm EC5 connectors.
OH
RE: Dean Connectors
I'll second Pete's recommendation for an iron with a larger tip, a little 25W one like you use on regular electronic soldering just won't cut it. You're heating up a lot of mass.
Scott
Scott
My Feedback: (31)
RE: Dean Connectors
A $25 Weller soldering gun from Lowes or HD works fine. One positive thing about Deans is it's almost impossible to short two batteries together which is easy with the Hobby king connectors. I've done it twice now. Yikes that hurts. On the other hand the deans on the charger end is exposed.
I still prefer the Hobby King connectors and they're only a few grams heavier than Deans with much more surface area.
Tim
Tim
RE: Dean Connectors
I brought the batteries into work and had the controls guy show me how it's done, what solder to use and the resin. He has mulitple sizes of Weller units to choose from. He did it just like Pete said (pre-tin both components and then bring them together). He appears to use the solder to conduct the heat into the part, rather than heating the part and adding solder. Seems like the industry ought to standardize on a connector. Preferably, for guys like me, a connector that you can crimp onto the wire first to make soldering easier!
RE: Dean Connectors
ORIGINAL: petec
+1
'xactly!
My Feedback: (34)
RE: Dean Connectors
I use a Weller 40 watt for most of my larger soldering jobs. It gets plenty hot enough to do the job. I tin the wire, AND put a small amount of solder on the Deans connector tab as well. The idea about squeezing a flat into the wire is good as is cutting a slot. Either will work.
CO
RE: Dean Connectors
The best way I have founf to solder large gage wire to a Deans connector is as follows: (there is a simple picture of this somewhere, but I can'f find it so I will try to describe)
Cut off about a 10mm length of 3/16 brass tubing.
At the midpoint cut a slot half way thru the tube.
Slit half the tube lengthwise.
Now spread the slit end and crimp the 10g wire on
Force the other end over the Deans lug
Gently clamp the connecter with wire attached and solder everything together. (Tinning some of the parts may be a good idea, but it works OK without it.)
After the first one, making the little fittings goes fast and is well worth the trouble.
RE: Dean Connectors
The main thing is soldering iron with enough heat to quickly melt solder on wire/connector. too small an iron will not do. Also use resin core solder.
My Feedback: (25)
RE: Dean Connectors
ORIGINAL: Gulliver
My Feedback: (27)
TX
RE: Dean Connectors
Could go a better way by using the Traxxas plugs which are rated at 100 amps. as opposed to the Deans at only 60 amps. Traxxas plugs are much easier to pull apart and solder.
My Feedback: (50)
RE: Dean Connectors
I found these soldering adapters from Maxx Products to take all the challange of soldering heavy wire to Deans plugs. It's item number 2818 EZ Soldering Coupler for Dean's ultra. Here's a a link: http://www.maxxprod.com/mpi/mpi-5.html
Dave
Dave
My Feedback: (58)
RE: Dean Connectors
ORIGINAL: Lazer
I fail to see just why so many people want to keep using the Deans Ultra plugs when you have to find other after market items to help make it easier to solder.
I spent years soldering wire on a daily basis, aftermarket items are not needed just the right tool and technique. I have a Weller soldering station with an 800 degree tip and have no issues. There are cheaper alternatives to what I use like a Tenma station for $35 from MCM.
RE: Dean Connectors
Many of the helicopter guys are now using Anderson Power Poles. Crimp on, no solder, and apparently the connection is better (their arguement, not mine). Here is a review by Model Airplane News:
[youtube]http://www.youtube.com/watch?v=y8ODI8fAU_k[/youtube]
I still use Deans and have don't have a problem with 10 gauge wire or pulling them apart when connected. But that is all due to the iron... a wide tip that gets hot and stays hot... as with most things, the right tool makes all the difference.
Tom M
Tom M
NY
RE: Dean Connectors
Short answer already given . . . "right tool" meaning an appropriately rated soldering iron, but long answer and my only reason for posting is to second the Anderson Powerpole conversion. 2nd year going with no problems and way easier than soldering
My Feedback: (50)
RE: Dean Connectors
ORIGINAL: Lazer
