Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Extreme Flight Vanquish 2m Build Thread
Reply
Old 01-21-2012, 05:21 PM
  #726
g_mkoch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Extreme Flight Vanquish 2m Build Thread
Anyone has any idea when the red/yellow/blue scheme is going to be back in stock?
Happy Landings
g_mkoch is offline
Old 01-22-2012, 11:48 AM
  #727
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
who makes a good hatch latch, I really dont care for the way the canopy is secured
jetmech43 is offline
Old 01-22-2012, 02:11 PM
  #728
pvogel
pvogel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like my secraft canopy locks, pretty easy conversion to do. Aztech aero has them so you can order from a US distributor.
Peter+
pvogel is offline
Old 01-22-2012, 03:08 PM
  #729
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok thanks
Old 02-04-2012, 10:03 AM
  #730
g_mkoch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
question:
Has anyone tried to do any bafling to better cool the motor?
g_mkoch is offline
Old 02-04-2012, 11:02 AM
  #731
rix
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: g_mkoch
question:
The only thing I have done so far is to cut the cone on the spinner. The cowl does supply good airflow so my motor ESC and batteries are staying cool but I have not flown on 90 degree weather yet. If you mount your ESC underneath in the cowl area it will get good airflow from the cowl openings.
rix is offline
Old 02-04-2012, 11:18 AM
  #732
g_mkoch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what would be a good temperature for the motor? So far my ESC/motor stayscool, but I just want toconsider some baffling for the motorahead of the 4 months of 90-100 degree weather here in Houston. I'll see to geta temperature gauge to measure the real temperature of my motor to know just how good is cooling. I do have a tru-turn spinner with cooling holes.
g_mkoch is offline
Old 02-04-2012, 11:34 AM
  #733
rcpattern
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
130 and below is ideal. Up to 150ish is OK. Shouldnt be too hard to keep it below that. Mine has never gotten above 140, even in 90+ heat and humidity here in southern, MD.
Arch
rcpattern is offline
Old 02-04-2012, 11:54 AM
  #734
g_mkoch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
any temperature gauge recommended?
g_mkoch is offline
Old 02-05-2012, 05:18 AM
  #735
rcpattern
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The IR ones car guys use work great.
Old 02-05-2012, 01:04 PM
  #736
hezik
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No temperature gauge needed. Right after landing, hold your engine. You should be able to touch and hold it for at least 15 seconds. If you can't, it's too hot.
hezik is offline
Old 02-06-2012, 09:54 AM
  #737
rcpattern
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
True, it is not needed, but it is certainly nice to have real data that you can look at and compare.
Arch
Old 02-11-2012, 07:32 PM
  #738
pvogel
pvogel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A nice photo of my favorite plane in flight :-) Thanks to Luke Peng for the shot.
pvogel is offline
Old 02-16-2012, 06:27 AM
  #739
318scott
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
How many are still waiting for a replacement canopy? I have LM and can not get a return phone call. Any one got a back door for info would be great.
Thanks Scott S
318scott is offline
Old 02-25-2012, 02:16 PM
  #740
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well flew my vanquish first time today, have to say power 160 is plenty, first flight it was diving on me pretty bad, I set it up like the manual says .5 on the wing and 0 on stab, what you think, should I play with the incidence, other than that after I got it trimed, it flys great
Old 02-25-2012, 02:27 PM
  #741
rcpattern
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where is your CG. If those setting are correct you should be fine. That is where mine flies perfectly. Something isnt right.
Arch
Old 02-25-2012, 02:34 PM
  #742
g_mkoch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try THIS website
g_mkoch is offline
Old 02-25-2012, 03:02 PM
  #743
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just in front of the wing tube, I thought about the cg, but as bad as it was diving made me think the incidence is wrong there is noticeable up trim on the elevators
Old 02-25-2012, 03:07 PM
  #744
flatlandmike
flatlandmike's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Starting to sound like motor thrust is off?
flatlandmike is offline
Old 02-25-2012, 03:11 PM
  #745
flatlandmike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What length extentions did every one use? I'm getting back to this arf after a small delay lol
Old 02-25-2012, 03:13 PM
  #746
g_mkoch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
fot the tail you need 42-48 inch
g_mkoch is offline
Old 02-25-2012, 03:58 PM
  #747
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well engine is mounted as is with the firewall thats installed, im sure theres side and down thrust built in
Old 02-25-2012, 04:14 PM
  #748
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
im going to put the incidence meter back on and check every thing again
Old 02-26-2012, 05:13 AM
  #749
rgreen24
rgreen24's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jetmech, what are you using for your zero refererence line? May be if we know some of the guys might be able to help a little more
rgreen24 is offline
Old 02-26-2012, 05:18 AM
  #750
jetmech43
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I leveled the fuse, then set my incidence that way
Reply
Display Modes
