Extreme Flight Vanquish 2m Build Thread
#1101
AB, CANADA
RE: Extreme Flight Vanquish 2m Build Thread
ORIGINAL: danamania
Well now you have! Yeah, I learn something new everyday hanging around pattern pilots LOL! Why not try it on your Vanquish and see if landing accuracy improves? The effect is very different from that achieved with the prop at idle (or the effect with ESC braking), and is not so much about slowing the airplane down as dumping a little bit of excess lift. For downlines, I have a 3% bottom throttle to down elevator mix (which is reversed when the air brakes are deployed as I don't want this mix for landings).
P.S. EDF pilots use a little bit of spoileron mix (usually with flaps) to add washout and decrease tip stall risk at high AOA during approach to landing.
I watch guys at our field land on a dime without a mix or modes. Thats why Im confused.
The less modes....the less mixes....the less problems. JMTC
Curious...whats your flight surfaces set at ??
On my Helios I added slight down aileron (about 1- 2 degrees because it's fixed incidence) to reduce pulling to the canopy and it slowed my plane down ...big time. It gave it a very nice feeling in flight too.
#1102
ORIGINAL: Flyer88
On my Helios I added slight down aileron (about 1- 2 degrees it's fixed incidence) to reduce pulling to the canopy and it slowed my plane down ...big time. It gave it a very nice feeling in flight too.
Aileron 12 / 15 / 25 deg (triple AIL & ELErates set-up, but I fly it mostly on low rates for the Sportsman schedule)
Elevator 10-12 / 20 deg
Rudder 25 deg
KE mixing courtesy of some Masters level pilots around here:
Rud - up Ele 5% (correct pulling to the gear)
Rud-Ail 4% / 2%
#1104
ORIGINAL: Flyer88
What about wing incidence ??
I'm curious for my own reasons. Not too be snoopy .
Thx
Flyer
Thx
Flyer
Anyway, I think I posted that a few times before, +0.5-6 deg wing incidence, stabs are zero. The stock adjusters are so fussy its not worth it to me to go a tweakin. Could easily end up worse than I have now. There is no elevator trim needed and the ailerons are fairly neutral as well. How did yours turn out on these parameters? Dana
#1105
AB, CANADA
The same . +.6 and 0 on the stab.
The stab might change later.....after some more flights
Oh yes by the way I love the Red BAron and Snoopy !
#1106
Incidence vs CG: I've read recently that guys are going 0.6-0.8 or even 1 deg on incidence. They are probably opting for a most forward CG. The CG range I've flown mine (last year's batch with the smaller rudder) is 181-186mm. Right now, its at 186 which is probably as aft in the CG range as anyone I've read is going. I suppose I could move the CG forward a bit, but then would probably want more wing incidence and what I don't want is to open up those adjusters. Its all about finding the right compromise for my flying style. I would rather spend time practicing the Sportsman schedule and entering contests this season than spending another season trimming a wooden ARF. I fly year round, winters too, and the climate changes will also have subtle effects on trimming a wood plane, IMO. Right now, at my skill level, my time is better spent flying than trimming. That said, half a dozen Masters level pilots have flown my Vanquish and have wisely counseled me to just fly it and not worry about all the trimming that could still be attempted. Now, I'm off to the airfield for a few flights before dark!
#1107
My Feedback: (282)
One thing to keep in mind about wing incidence, the wing flies level. If you have too little wing incidence, the fue will fly tail down. Too much wing incidence, the fuse will fly tail high. The first 3 flights were at .4 pos incidence on the wing and the tail was down. Now that the wing incidence is at .7, the fuse flies straight. When I first noticed this on the first flight which I was also tail heavy. 2nd and 3rd flight I had moved the batteries forward and the CG was much better, but the tail still flew down. For the third flight, I had 3 other pilots watch the plane to see if they saw the samething I did and they did. IMHO, .6 or .7 pos wing incidence is about right. Now I will work on moving the batteries forward to see if the KE pitching is relieved. It should be according the trimming chart. If not, then I will increase the wing incedence to .8, but I hope I do not have to. Another option would be to increase the incedence of the stab a bit too.
#1109
AB, CANADA
Just got the new spinner today from Truturn.
FAI Turbo type, painted with Krylon paint and baked at 170 for about 2 hours.
The color match is very close, but not perfect.
#1111
AB, CANADA
I didn't weigh it but the spinner feel lighter than my plastic spinner for sure.
When it looks that good, who cares how much it weighs
170F the lowest the stove would go.
#1115
My Feedback: (76)
I installed the gator wing adjusters on the back side. I used 1/64" indreasing drill bits until I drilled out the wing CF locator pins. Then I used 1/4" wood dowl to replace the CF pins. I stepped down the end of the wood dowl 1/8" until the Gator wing adjuster socket fit snuggly on the wood dowl. Need to make sure the socket is straight with the wood dowl. Then mix up some 30 mon epoxy and milled fiber glass and insert the dowl with the end of the adjuster socket flush with the wing root cap. I was able to elongate he Gator mounting holes to match the EF adjuster hold down screw locations. Then I set the canopy at 0-0 deg, the rear stabs at 0-0 deg and the wings at 0.6 deg positive. I left the EF front adjusters stock, although I had to open up the slots to match the screw thread locations.
#1117
AB, CANADA
Ran some numbers with the Silver Bullet and a Falcon 21x14 v2
75 amps @ 6300 rpm and about 2850 watts.
Run times are very good with batteries sitting about 30- 35 percent remaining
For a 7.5 min flight in windy conditions.
Very nice combo. Flight is slow and very steady.
Official weight is 10.87 lbs / 4390.5 grams .
Curious to know what a 22x12 would perform like ?
#1118
ORIGINAL: RC Accessory
Another thing to keep in mind about trimming chart(s), there are steps that address thrust angle that we tend to skip with ARFs. Thoughts?
#1119
ORIGINAL: Flyer88
#1120
My Feedback: (282)
ORIGINAL: danamania
D
Interesting. Say, what was your CG at this incidence if you measured it? Thx.
One thing to keep in mind about wing incidence, the wing flies level. If you have too little wing incidence, the fue will fly tail down. Too much wing incidence, the fuse will fly tail high. The first 3 flights were at .4 pos incidence on the wing and the tail was down. Now that the wing incidence is at .7, the fuse flies straight. When I first noticed this on the first flight which I was also tail heavy. 2nd and 3rd flight I had moved the batteries forward and the CG was much better, but the tail still flew down. For the third flight, I had 3 other pilots watch the plane to see if they saw the samething I did and they did. IMHO, .6 or .7 pos wing incidence is about right. Now I will work on moving the batteries forward to see if the KE pitching is relieved. It should be according the trimming chart. If not, then I will increase the wing incedence to .8, but Ihope I do not have to. Another option would be to increase the incedence of the stab a bit too.
I do not actually know, I did not check it. On the 3rd flight of the day I moved the batteries back some and felt the plane was tail heavy. More work to do. I am not worried about the thrust line yet.
#1121
AB, CANADA
Looks like some solid numbers to me, nice report! I've only flown mine with the 20.5x14.5. What would one be looking for with the other prop?
From my experience, a little more power and a lower gear for the up lines. I do believe that you can keep the throttle reduced a little more with a bigger prop and the good runtime numbers prove it. Seems like most guys at my altitude are running 22x12 at about 3300 watts 90 amps about 6200 rpm and loving the power.
Also........... This plane lands like a butterfly....I hit the center line all but once.
How many of you guys fly with your throttle trimmed up to an idle ?? Curious
#1122
Dana,
Would you please expand on the throttle curve and include throttle end points mentioned much earlier in this thread. Or point me to a site that explains its use for pattern flying.
My apologies for asking this in a build thread but its been on my mind for months and this is the only place I've seen it mentioned.
Je r
Je r
#1123
My experience has been that getting thrust line sorted out (both vertical and horizontal) is one of the essential early adjustments. I check for vertical alighment by trimming the a/c at half throttle and then going to full throttle. If the aircraft climbs, it needs more down thrust and vice versa. For horizontal thrust lines, I pull to the vertical pointing into wind and check to see if the aircraft climbs straigt or if it deviates left or right. If it goes left, I add right thrust and vice versa until it goes straigt up. My Vanquish needed downthrust (3 washers worth) and left thrust (1 washer's worth). Once I have the thrust lines sorted I go on with the other adjustments e.g. CG, incidence etc. What do others do?
#1125
ORIGINAL: JerMilosek
Dana,
Je r
Dana,
Je r
With Castles, I have fixed endpoints set on the ESC and the radio' throttle channe endpoints (ATV) are chosen following the Castle instructions. This does not change with a throttle curve.
A quick way to get a throttle curve on Futaba is to use an Exp1 curve in D/R where advancing the throttle stick produces more power output at the motor than the default linear curve does. Then one can get an idea of how much curve is desired. A custom curve can be defined with a point curve once one has an idea of the kind of throttle response fits the flying style. There does seem to be a trade-off between getting at more power with less stick movement, and the perception of just how much power is commanded, or resolution of stick movement to ESC.
Others may be able to explain it better, I find it to be a very subjective topic really. Hope this helps.
