Extreme Flight Vanquish 2m Build Thread
#1251
RE: Extreme Flight Vanquish 2m Build Thread
ORIGINAL: xrboss
Finally had the maiden flight on Sunday. Very uneventful, zero trim change from my bench setup, not one click of trim change.
Setup much like many here in this thread.
HiMax 210
APC 20.5 X 14
CC HV80 ESC 30% Brake
2x5s5000mAh FlightMax 20C
2xs9650 Elevators
2xDS831 Ailerons
DS8715 Rudder
Stabs 0 degree
Wing 0.5 degree
HiMax 210
APC 20.5 X 14
2xs9650 Elevators
2xDS831 Ailerons
DS8715 Rudder
Stabs 0 degree
Wing 0.5 degree
#1252
OH
I have noticed that many people using futaba servos (9650s for eles; 9551 for ailerons; 9156 for rudder) are using different arms such as the Dubro super strength or aluminum arms. Is there any reason not to use the supplied arms, especially given that generally low rates are used on this plane? I like using the X-type arms so you can rotate it on the servo in order to make sure the arm is perfectly perpendicular to the servo. Just wondering if there is any problem with the supplied arms that I cant think of.
Jon
Jon
#1255
ORIGINAL: JonPa
Jon
Jon
#1257
ORIGINAL: Flyer88
Hey Chad
How many oz's you running on rudder and at what voltage ?
And what the length of the horn.
Thx
Hey Chad
Thx
http://www.gpdealera.com/cgi-bin/wga...pgm?I=FUTM0731
At 7.2V. The arm on the rudder is the big Dubro HD one, but I will go back to the large Futaba wheel as I needed to ATV back the rudder a bit since the large Dubro was too much throw.
I am also going to try one of these, but not sure it will make much difference.
http://www.gpdealera.com/cgi-bin/wga...pgm?I=FUTM0735
#1258
AB, CANADA
Do any Futaba servos use Magnetic Induction for positioning yet.
I know the only Hitec is the 7990m at 630oz .... Kinda overkill for these planes.
#1260
ORIGINAL: Flyer88
Peter+
#1261
AB, CANADA
That's where I was kind of excited about these Hobby King servos because they're fairly lite and very accurate and obviously very affordable.
#1265
OH
Just wondering if people are crossing the rudder pull-pull cables or not? For some reason I cant find any comments on this topic.
#1268
You only need an offset servo arm if the rudder control points aren't directly over the hinge line, since they are, you don't need an offset.
Peter+
Peter+
#1269
HI Arch,
I am working on my vanquish and I have a question. What is the trick of getting the pull pull wires up thru the fusilage? It that one place in the back was not there it would be easy. Up here in the NW the vanquish has been very popular. Also, this was an excellent build thread I fly intermediate (just moved up) and looking forward to getting this puppy in the air.
Thanking you in advance
Wayne Lovett
District 8
Wayne Lovett
District 8
#1270
OH
ORIGINAL: Walfam
HI Arch,
Wayne Lovett
District 8
HI Arch,
Wayne Lovett
District 8
I just used a piece of stiff music wire that I taped to the tip of the pull pull cable. Then I routed it from the back through the slot in the fuselage. You only need to push it about 1-1.5 feet through to be able to grab the cable from the front and pull it through. Not as hard as it looks.
Jon
#1272
Just about to start my build, have people used the mylar hinges or replaced them with pinned hinges, never been a great fan of them and only used them on small planes in the past. Thanks Keith.
#1274
I just got my Vanquish. It came with Robart style hinges. Anyone using them? I was also going to use a Hacker A60-7s but it does not fit - too long and the x mount is too large and the holes do not match those supplied on the fuse. I don't want to start modifying the nose. Any suggestions?
Steve
Steve
#1275
My Feedback: (9)
the plane is designed around the fury torque motor, im useing the eflite power 160 in mine and it fits with only have to move one of the holes in the fire wall I know people have used other motors, im not sure what you have to do to get your hacker to fit, I wouldnt want to modify the nose.
