If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 53 of 67 FirstFirst ... 343515253545563 ... LastLast
Results 1,301 to 1,325 of 1673
  1. #1301
    hovermaster's Avatar
    Join Date
    Jan 2002
    Tooele, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Extreme Flight Vanquish 2m Build Thread
    The Honeycomb is from ACP Composites and measures 11" In span, 4" at root and 2" at the tips. It is also set to the same incidence as the main wing.
    Chris
  2. #1302
    Join Date
    Oct 2003
    Ocala, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ok thanks might just have to give it a try
    smooth pass
  3. #1303
    Join Date
    May 2003
    Spokane, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi
    may I ask what vinyl cutter you have. I been thinking of getting one. any info would be nice.
    thanking you in advance
    Wayne
  4. #1304
    Join Date
    May 2003
    Spokane, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    HI Mike,
    I was very interested in your glue gun idea and bought one and I am impressed. I believe you also hot glued you esc also is that correct? Did the temp of the Glue cause any component problems? Appreciate any help you can give me.
    Thanking you in advance
    Wayne
    Dist 8
  5. #1305
    Join Date
    May 2003
    Spokane, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    HI,
    Thank for talking about shoe glue I have since purchased some and it is great for tying down leads.
    Question have you used it to hold your esc or would the temp of the esc cause it to let loose?
    Thanking you in advance.
    Wayne
    Dist 8
  6. #1306
    Join Date
    Jan 2010
    City
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: barnowljenx
    3rdworld, I did have a Pletti Advance available when Iacquired a used Vanquish. The previous owner had used an AXi 5325/24 (or something like that!) and Itried very hard to come up with a mounting scheme for the Pletti. However, it looked likea fair bit of surgery would be required and then, if I wanted to sell the Vanquish, I'd have to sell the Pletti with it. So, Igot an AXi 5330/F3a and that just bolted into place with no hassle and it has bags of power - rarely do Ineed full throttle. Around 3/4 is all that's needed for good vertical performance with the same speed as the model flys horizontally. On very windy days Ioccasionally use full poke but it is for very limited times.
    Wattsup, you certainly have a point about fitting a Pletti to a Vanquish but, as Isaid, Ihad one available. It is now sitting on the shelf waiting for the next opportunity to upgrade at the end of this season - maybe! If the Vanquish is as good as it is proving Imay wait for a couple of seasons! Regarding excessive current draw, Idoubt it with the Pletti as you only need the power when you need the power! My view with the Vanquish fitted with the AXi 5330 is that the Pletti would require less throttle, and hence similar or lower current draw than the AXi. Ican fly a 6.5 min schedule and then fly a couple more manoeuvres and the 4900 Rhinos I'm using are usually at around 65-70% used and barely warm - OK it was only 5 deg C when Iflew it.
    . For those using the AXI 5330 what mounting method allows the drop in fit? My x mount holes on the F3A are not eve close to the pre-drilled firewall holes.
  7. #1307
    Join Date
    Oct 2003
    Ocala, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Question how did you decide on 11 in. just curious how you came up with that span
    smooth pass
  8. #1308
    Join Date
    Jan 2002
    Tooele, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It came out to 11" because thats all the material I had left! lol But it turns out that it is about half the size of the cantalizers on the Axiome and Episode.
    Chris
  9. #1309
    Join Date
    May 2004
    Whippany, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Doesthecannalizerfix anything specific or is it installed just because.........?
    Regards,
    MattK
  10. #1310
    Join Date
    Jan 2002
    Tooele, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The cantalizer doesn't necessarily "fix" anything but it does improve rudder authority and helps the airplane track better in pitch and yaw...
    Chris
  11. #1311
    Join Date
    May 2002
    Pittsburg, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    no picture going up.
  12. #1312
    Join Date
    May 2002
    Pittsburg, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    does anyone know where this piece of picture goes to?
    It came off a horizontal stab.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  13. #1313
    Join Date
    Oct 2003
    Ocala, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I dont think it goes to anything, dont recall that part one mine, maybe just some added wood
    smooth pass
  14. #1314
    Join Date
    May 2002
    Pittsburg, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It has CA glue make on it. I will see if I can get a hold of Chris at Extremeflight.
  15. #1315
    Join Date
    Oct 2003
    Apache Junction, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I had the same thing show up on my Vanquish! My version is the blue and pink. The part fell out of the left side stab. I sent Chris
    a e-mail with a picture and he replyed that the peice is used to provide a stop for the stab tube to keep the tube from going to far
    into the stab. He thought that everything should be fine without the part. It is a bit hard to see how the part came loose with the keying
    slots in place.
    I also have a red and yellow version and have not found any loose parts within the stab.
    Happy landings!
    Steve
  16. #1316
    Join Date
    Jan 2005
    CALGARY, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: hovermaster
    Thought I would chime in here. I have recently started flying a Vanquish and getting into the F3A Pattern side of competition and am really enjoying it. I replaced the magenta with Cub Yellow and with 5000mah packs it weighs 4930g. I also added an 11'' span T-Cantalizer which has been working very well and really makes the airplane lock in and roll better.
    Chris M.
    I think this color combo is worthy of a production run.
    Nice colors
    Why is there never enough time to do it right, but always enough time to do it over ?
  17. #1317
    pvogel's Avatar
    Join Date
    Jan 2009
    Santa Clara, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Flyer88
    Chris M.
    Nice colors
    Very nice looking colors, but I would invert the blue and the yellow to make the leading edge primarily yellow, blue wings disappear on me during approach if there's a tree line behind the plane, as there often is.
    Peter+
    Team Esprit/JetiUSA
  18. #1318
    Delicious J's Avatar
    Join Date
    Feb 2013
    Hockley, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Is a Landing gear mod a necessity on this plane?
    I hear the gear is the weak point.
  19. #1319
    rcprecision's Avatar
    Join Date
    Jan 2002
    Cypress, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    J,
    There is a father and son I fly with at the Space City RC Club who have logged many hours with a couple of 2M Vanquishes for the last year or so. I'm sure they would be glad to share their experiences with you. We fly in the evenings weekdays after work and Saturdays. Stop by sometime if you are interested in pattern flying.
    Also Space City RC Club's 6th annual pattern contest will be held May 4th and 5th.
    Glen Watson
    http://glenwatson.blogspot.com/ (pattern blog)
  20. #1320
    Join Date
    Oct 2003
    Great Mills, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Delicious J
    I hear the gear is the weak point.*
    I have never seen any issues with the Vanquish gear. I think it is like the rest of the pattern planes out there. If you constantly keep hitting hard, it will knock the gear loose, but as long as you land reasonably smooth, you wont have any issues. I've seen way too many pilots not put the focus on landings. Landings and takeoffs are free points.
    Arch
    Team JR, YS Engines, Morgan Fuels, F3A Unlimited, Team BJ Craft, Thunder Power RC, Castle Creations, Vogelsang Aeroscale
  21. #1321
    Join Date
    Feb 2013
    Hockley, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have been flying a 3DHS Osiris for years, and have always wanted a 2M Ship. I don't compete, but I like going through the sequences every now and then.
    Maybe one day I would like to enter a competition. But for now, it's 4-point rolls, knife edge circles, vertical snap rolls...... The fun stuff
    I read somewhere in this thread, "it taking 250 flights to get a pattern plane flying the way you want it." Uhhh, .........No way.
  22. #1322
    Join Date
    Mar 2006
    Houston, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    J, after some 350 flights on one vanquish I can tell you that the landing gear is not a weak point. Then only time I have to fix it was after a competion when some gusty winds ,due to a storm system forming on the south, slammed the plane on landing causing a CF prop to brake and the motor shaft to bend.
    Kenobi - I think we lost something.
    Skywalker - Not to worry, we are still flying half a ship.
  23. #1323
    Join Date
    Feb 2013
    Hockley, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the info. I am almost there, on deciding if Iwant to go with the EF Vanquish......
  24. #1324
    Join Date
    Jan 2011
    Endicott, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm a touch under 300 flights and the gear even survived a mid-air with no problem.
    Actually, only my spinner was damaged and the landing was normal.
  25. #1325
    Join Date
    Jan 2002
    Tooele, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: pvogel
    ORIGINAL: Flyer88
    Chris M.
    Nice colors
    Peter+
    Thanks Guys! This was a stock Blue, White & Magenta color scheme that I simply stripped off the Magenta and replaced it with Cub Yellow! Im only on flight # 14 now but it is flying very well so far. I just switched to Zippy Compact 4500 35c packs and saved 245 grams from the 5000's!
    Chris
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
