Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Extreme Flight Vanquish 2m Build Thread
Reply
Old 04-10-2013, 06:16 PM
  #1376
pvogel
pvogel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Extreme Flight Vanquish 2m Build Thread
I use bullets
pvogel is offline
Old 04-11-2013, 08:20 AM
  #1377
Delicious J
Delicious J's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool, just wondered about the 10s voltage. Not used to Electric setups with this kind of spark
Delicious J is offline
Old 04-11-2013, 08:49 AM
  #1378
rcpattern
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use 4mm bullets now. At one point I soldered everything, but then if you have to change something it becomes a much more difficult task. The bullets have worked great,
Arch
rcpattern is offline
Old 04-11-2013, 10:53 AM
  #1379
STEVE HOSNER
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use bullets and haven't had any problems at all. I am using the Castle 80 amp HV ESC with a Hacker A60-7S
without any sign of a problem.
Steve
STEVE HOSNER is offline
Old 04-11-2013, 03:57 PM
  #1380
pvogel
pvogel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, I agree with Arch, it's just so much more convenient to rearrange stuff when motor and ESC aren't soldered together. 4mm bullets (especially the ones from castle) are capable of 100s of amps of current, especially for the very short pulses needed for a brushless motor. The big continuous current draw is between the ESC and the batteries and there bullets are also fine, but so are Deans and Anderson Power Poles, etc. The Spark is due to the inrush current going from the battery to the empty capacitors in the ESC, if you want to avoid it it's relatively simple, you just need to "pre charge" the caps through a current-limiting resistor. On my non emcotec equipped planes I use a momentary push button that bridges the posts on my arming switch (which is breaking the + lead from the battery) through some 18AWG wire and a 1.3 K Ohm 3W resistor. Takes a few seconds to hear the beeps from the ESC that tell me its caps are charged and then I put the arming plug in with no spark. Avoids degrading the deans' spring that ensures a secure fit and good contact.
Peter+
pvogel is offline
Old 04-12-2013, 07:25 AM
  #1381
Delicious J
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't speak Portugese
Old 04-13-2013, 04:48 AM
  #1382
doogiehl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi everyone I need to find out the part no. for the darker blue covering on the blue and pink vanquish 2m. I think its ultracote Deep Blue. Need to patch after re enforcing the main gear. I cant find a post on this I am sure its here somewhere.
On the ultracote website it appears to be Deep Blue HANU 873 can anyone confirm this?
Best regards
doogiehl is offline
Old 04-13-2013, 08:01 AM
  #1383
hovermaster
hovermaster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: doogiehl
Best regards
Yes, it is UltraCote Deep Blue.
hovermaster is offline
Old 04-14-2013, 04:03 AM
  #1384
doogiehl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks best regards
doogiehl is offline
Old 04-16-2013, 07:51 PM
  #1385
Delicious J
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As I am just about to install servos, I realize that the recommended JR DS9411 Aileron servos, are too small for the cut outs.
Odd? These are obviously setup for slightly larger servos, and my wings even have pre-drilled holes for mounting.
Iwill obviously glue some wood shims in, just wondering why the cut outs are bigger?
Old 04-16-2013, 08:03 PM
  #1386
Jetdesign
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's annoying. They even recommend those servos and show them in the assembly manual. I had a plane where the cutouts were too big for my stab mounted elevator servos and it was a real chore trying to get the plates in and everything lined up right.
Jetdesign is offline
Old 04-17-2013, 05:06 PM
  #1387
Delicious J
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The one time I go with recommended servos, they holes aren't even cut for them, go figure.
My dremel broke a few weeks ago, so I am going to have to wait at least
until this weekend to install the servos. Looks like the elevator servos will fit with just a little filing.
Old 04-23-2013, 03:46 PM
  #1388
mazjag
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anybody know what size servo extensions are required and how many..I`m using Futaba servos....thx..
mazjag is offline
Old 04-23-2013, 03:50 PM
  #1389
pvogel
pvogel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm using 2 x 36" for the elevator servos (but the JR servos I have have 12" long wires and it's just long enough), 4x6" for the ailerons (one 6" to get out of the wing and the other 6" is plugged permanently into the RX, I join the two when the wing goes on and have an extension clip to keep them connected) and 1 12" for the ESC (actually 2, since I'm using Jeti equipment and need to extend the EXT port as well as the throttle connector). No extension needed for the rudder.
Peter+
pvogel is offline
Old 04-23-2013, 03:53 PM
  #1390
mazjag
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Peter!
mazjag is offline
Old 04-25-2013, 01:59 PM
  #1391
Flyer88
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Vanquish 2m on 6s /5000
Nice video !
http://www.youtube.com/watch?v=O66fLW5BB_k
Flyer88 is offline
Old 04-25-2013, 02:18 PM
  #1392
Jetdesign
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That might be the most unimpressive f3a video I've ever seen.
Old 04-25-2013, 03:07 PM
  #1393
Flyer88
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The flying was not the greatest but I thought it demonstrated the power and duration of the 6s set-up very well.
That's what I meant.....
Flyer88 is offline
Old 04-25-2013, 05:53 PM
  #1394
Delicious J
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm jealous of the (1) battery setup.
I told myself I would never run lipos in series ever again. .....and here I am.
First time I saw the 2M Vanquish was at a show. I asked Chris Hinson, what gas motor they were recommending. He laughed, I was serious.
I had no clue that Pattern guys were flying these electric at the time.
Old 04-25-2013, 10:45 PM
  #1395
Jetdesign
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Attempting to look only at the performance of the airplane in that video, I thought the plane looked under powered and "floaty". The plane did not once appear (to me) to have any kind of authority, whether it was authority in tracking through the wind or pulling itself through a loop segment or vertical.
I know many people say 'lighter flies better' but there is an ideal wing loading for what we are trying to do. The plane was designed for 10S. It probably can fly pretty good on 8S but would be more taxing on the electronics and get reduced flight time. I think that 6S setup is a complete waste of a performance F3A airplane.
3D guys would fly this plane (if they were to fly it) on 6S, 8S tops, but with super high discharge packs, running at very high current, and for shorter flight times. Their goal is max power:weight, and 'floaty' is a good thing in 3D.
If 10s or even 8s setups are too expensive, I would suggest an appropriately equipped smaller plane.
I would have wrote more in the first response but I was not at my computer.
Old 04-26-2013, 10:30 AM
  #1396
Delicious J
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No doubt. If you are going to electrically power this airframe, you need 10s.
Iwould have likeda gas engine though.
Old 04-26-2013, 11:00 AM
  #1397
Flyer88
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Like I said previously " I think it's a good demonstration of the plane powered on 6s"
Flyer88 is offline
Old 04-26-2013, 11:53 AM
  #1398
Delicious J
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any tips or tricks for threading the pull-pull wire through that long thin tail?
Old 04-26-2013, 12:03 PM
  #1399
Flyer88
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use a device that can clamp on and pull it through.
I honestly don't know what you call it ??
It has four little prongs that poke out at the end to clamp on to things.
http://i356.photobucket.com/albums/o...ps85fd05c0.jpg
Flyer88 is offline
Old 04-26-2013, 05:52 PM
  #1400
Delicious J
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That looks neat. I grabbed a tiny hollow brass tube about 36" long.
Ihave an idea, if it works it's going to work excellent, all for a $1
I will post some pics if it works out.
Reply
Display Modes
