Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
10S Cell Pro charger
Reply
Old 08-24-2011, 07:51 PM
rgreen24
rgreen24's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 10S Cell Pro charger
Hello all, i recently bought a 10S charger and it has been perfroming flawlessly until tonight. I just bought it a month ago a noticed that it still had the older software. My issue is i have it connected to an IOTA power supply as well as my 1010C charger, both are four 4 years old. today it keep reading <10 volts, and then it would say as well supply unstable. what i dont understand is that my TP1010C charger works without issue where my 10S will beep and end the charge ubruptly. Is there something that i am doing wrong here? I am hooking it up how i always hook it up. I have a pattern contest the weekend and i really need to get this chager working properly. ANy help would be appreciated.
thanks
rgreen24 is offline
Old 08-24-2011, 08:33 PM
OhD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 10S Cell Pro charger
Disconnect the TP 1010C and see how it works. Make sure you have good connections to the Iota power supply.
Jim
OhD is offline
Old 08-25-2011, 02:31 AM
rgreen24
rgreen24's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Jim, I tried that as well. I have been reading that their Frmware update to help with this problem v 2.29 and I am on 2.24. The firmware came out last August, and I bought the charger in July of this year. It's odd that new chatter would not have the newest firmware update since it was bought almost a year after the new firlmware release.
rgreen24 is offline
Old 08-25-2011, 02:42 AM
jlkonn
jlkonn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Robert!
How's it going?
Did you get the interface cable?
http://www.store.revolectrix.com/Pro...ro-10s_2/FUIM3
If you didn't perhaps someone in your club has one.
With it you can download the firmware updates from FMA's website.
I have two 10s chargers and running them both to charge my 10s packs
off my Iota 55 I will sometimes get the same low voltage messages you're getting.
My solution was to set the chargers at 4.5amp max instead of 5.0.
Good luck!
JLK
jlkonn is offline
Old 08-25-2011, 04:17 AM
ArchNemesis
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Robert,
Check to see if any of your banana plugs are getting warm or hot.  I've had this error on a few occasions and every time it was the result of poor connections via the banana plugs.  If they're not making solid contact, then they just become big resistors and will get very warm.
ArchNemesis is offline
Old 08-25-2011, 04:57 AM
rgreen24
rgreen24's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Charger decided to work this morning. Go figure
rgreen24 is offline
Old 08-25-2011, 05:16 AM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is easy to measure whether the DC input voltage is really under 10v or not, and go from there.
nonstoprc is offline
Old 08-25-2011, 05:28 AM
Chris Moon
My Feedback: (8)
Chris Moon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is a screen where you can monitor input voltage for fluctuations. I have had this error and watched the input voltage jump around just prior to the error. I have traced it back to a loose connector or undersized wire etc. every time and after I tightened up all the connectors again, it would be fine.
Chris Moon is offline
Old 08-25-2011, 06:58 AM
woodie
woodie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You might want to check the clips that hold the fuses are also tight. They sometimes get a little loose and that can lead to increased resistance. If the fuse is hotter than the charger, that is an early indicator the fuse holder is getting loose where the fuse pins plug in the clip.
Woodie
woodie is offline
Old 08-25-2011, 07:03 AM
smcharg
smcharg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also, the current version of firmware available is 2.30.  The firmware is obviously not the issue but 2.30 has been rock-solid for me.  Looking forward to the 10XP coming out next month!
smcharg is offline
Old 08-25-2011, 08:09 AM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the connetion at the DC input side is loosing, the connectors and/or wires can become very hot and the power converter can be at risk of fire.
I always set the output voltage at 12.6v to cap the DC current at 20a. Periodic checking of the temperature of the power unit and the charger during charging is a good practice.
Old 08-25-2011, 03:23 PM
rgreen24
rgreen24's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And the winner that to my dilemma is all the above. The fuse holders were a little loose, so I tightened them up. Alsombought new banana plug connectors, the gold plated kind and it seems to be working with out an use at this point.
Nonstoprc - with you limiting the voltage to 12.6, how long are you waiting for your packs to charge.
Thanks to all of you for your input, this thread will certainly help the person this happens to.
Jlkonn - are we going to see you at any more contest? How is life in Ohio?
rgreen24 is offline
Old 08-25-2011, 06:56 PM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rgreen24,
Since my 5000mah packs are rated at 1c, the charging time is about 30-40 minutes per pack per charger, at no more than 5a of the charging current.
Old 08-25-2011, 09:12 PM
patternflyer1
patternflyer1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had this same problem exactly. Mine was caused by a bad solder joint (actually looked like no solder) where the pins for the fuse are. Pull out your fuse and see if it's melted and burned. Mine was and it was still working but then I started getting the same error.
Chris
Edit.
BTW, mine did the same thing where it started working again, but soon failed again. Did that for a while before I found the problem.
patternflyer1 is offline
