Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
BJCraft Episode
Reply
Old 01-04-2013, 04:10 PM
  #226
rcpattern
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: BJCraft Episode
Quote:
ORIGINAL: shannah
I got a chance to squeeze in a couple flights yesterday. I was trying a 20x13 prop per BJ's suggestion. He recommends a 20'' pitch because he says that the smaller diameter is more compatible with the canalizer. I thought it was a bit less yaw sensitive and rolled more axially (although it was pretty nice on the 21x14). It was faster overall, but not too bad.
I am just about ready to fix the rear anti rotation pins in place since I think my incidence is OK. I made a very slight thrust adjustment that I want to test before I do that however.
I still think this is a real solid flying airframe. It takes more work to fly it as smooth in P13 as the Nuance but it clearly excels in the more difficult FAI maneuvers. I hope to get out and do some more serious sequence flying over the next few weeks. I'll post my updates and progress.
Steve,
I'm curious as to whether it truly rolls more axial, or if it appears like it because of the canalyzer. It definitly looks odd in some attitudes, but I think part of it is the color scheme. i have almost 150 flights on the one I have now, and I have tried the smaller props. as well as the larger and the only thing I really noticed was the speed difference. I was happer with the 20X15, than I was the 20X13, but have settled back on the 21X14 which i started with, and is the same prop that I run on my Nuance. I do love how the plane flies through the F sequence though. It is amazing how little rudder is needed for the knife edge loop and such.
Arch
rcpattern is offline
Old 01-04-2013, 06:34 PM
  #227
shannah
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll play around with prop selections some more and see if I can tell the difference. Roll performance may just be due to the higher speed I was flying it at. Not sure.
I did try a 20x13W and liked it better than the standard 20x13 and 20x15 but I may end up going back to the 21x14 that I started with, just like you. I hope to get some more time on it tomorrow. The field has been pretty busy lately and with daylight loss time being in effect I haven't had a lot flying opportunity.
Overall, I'm still impressed with the way it flies.
shannah is offline
Old 01-05-2013, 05:59 AM
  #228
mups53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine is due in today. I can't wait to get a look at it. Mike
mups53 is offline
Old 01-05-2013, 04:57 PM
  #229
shannah
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I went back to the 21x14 and I prefer it overall. I liked the speed and downlines for sure. I still think that it rolls a little better with the small prop, perhaps it is due to rudder sensitivity and higher flight speed that I tended to use on the 20" props.
shannah is offline
Old 01-11-2013, 10:20 PM
  #230
ematech
Hi all Just received my Episode today Thanks to the great folks at F3A Lightning fast shipping, less than a week to Arizona!! thanks Chris!! ( Santa was really good this year!) have it unpacked! Just like my Nuance the packing included the masking newspaper from painting, Just makes me smile, nothing wasted! I have about 500 + flights on my Nuance and am looking forward to Flying the Episode. Any ideas on the rudder speed? on the Nuance I have slowed my rudder servo to about .18 sec travel speed. Any thoughts on setup for snaps and spins would be appreciated as well as just general throws to start. Thinking about a Hacker Q80 14XS for power. Thoughts?? Is there a BJ website that has builder notes like the Nuance? Any help is appreciated
John Bentley
ematech is offline
Old 01-12-2013, 09:34 AM
  #231
shannah
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi John,
I discussed motor options with BJ and he recommends staying away from the large outrunner like a Q80 on his designs. He feels that the long nose moment causes some yaw stability issues due to the large spinning mass of the outrunner . He tried a Himax outrunner and didn't like it as much as the inrunners he had been using.
I am VERY happy with the Pletty Advance on this airframe. I strongly recommend it.
As for control throws, be aware that the Episode rudder is very sensitive. You shouldn't need to slow down the rudder speed on the Episode but you will drastically reduce your throw.
Start by copying your Nuance program across the board. Then, take your rudder and cut the throw in half for normal flight. I don't know what kind of expo you were running on the Nuance but you will be about the same expo on the Episode, perhaps a bit higher. For spins, I boost the rudder throw up but it is still about 30% less than what I had on the Nuance.
Spins are done by rudder and elevator. I sometimes use aileron input as I am crossing over on the reverse 2-1/2 spins but aileron is not needed in the spin. It spins very slow.
I use a snap condition which has a high aileron throw and reduced elevator (on the Nuance I also reduced the rudder).
Construction of this is the same as the Nuance. The control arms are identical, landing gear setup is identical, wing attachment is identical. Check out the build info on this thread.
My CG is set forward from where it was with the Nuance. I believe I am around 275mm.
You will find that this airframe will probably take more work to set up than the Nuance did. It will feel completely different in the air.
shannah is offline
Old 01-12-2013, 11:11 AM
  #232
ematech
Thanks so much Steve, I just ordered the Pletty. Do you have the stab fences installed and if so did you use the 90Degree or 95 Degree angle? Do you think the wing adjusters are necessary? On the Nuance I used your recommendation and just used the factory fixed setup. Thanks for all your help, Hope to see you at a contest soon.
John
ematech is offline
Old 01-12-2013, 04:43 PM
  #233
shannah
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi John
My stab fences are set at 90 degrees. That's the recommendation from BJ. If you check his website he explains how to install them. You might want to do what he suggests and mount them on tape and try out both the 90 and 95 to see what you like. I didn't try the 95 degree setting.
As for Incidence Adjusters, I put them on mine. My guess is that you probably don't need them but they are easy to install. I just got a set of the HobbyKing adjusters and they are nice. They work with the 8mm CF tube so you could use them with the tubes that are included in the kit (his tubing is just slightly over 8mm but you can sand them to fit I think).
shannah is offline
Old 01-14-2013, 08:15 AM
  #234
mups53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys after a pretty lengthy time to get the Episode ARC versions are finally inand shipping to customers today. I now know what a slow boat from China means.
Thanks, Mike Mueller
mups53 is offline
Old 01-14-2013, 11:13 AM
  #235
Doug Cronkhite
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: shannah
I went back to the 21x14 and I prefer it overall. I liked the speed and downlines for sure. I still think that it rolls a little better with the small prop, perhaps it is due to rudder sensitivity and higher flight speed that I tended to use on the 20'' props.
Smaller prop = less spiral slipstream force. More likely that's the reason for better rolls.
Doug Cronkhite is online now
Old 01-15-2013, 02:56 PM
  #236
rcpattern
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One advantage of where I live is that F3A Unlimited is right up the road. I was able to go up and raid the trailer full of Episodes last night and i just unpacked the ARC I picked up. Here are some pics and weights. I'm not listing everything weight wise as the gear and such is the same as all the other BJ Craft planes. There is a seam in the fuse to fill, but certainly not bad. Wood work is excellent. Very little sanding if any will be required for covering.
Will start on it in a week or so. Have to get Tara's Monolog together first. Fortunately, I'm not in a rush on this Episode as the other one is still in the garage ready to fly (thanks Chris!).
Weights are as follows:
Right Wing - 242 grams
Left Wing - 248 grams
Canalyzer - 64 grams
Fuse with Canopy - 990 grams
Left Stab - 42 grams
Rudder - 48 grams
Right Stab 44 grams
Pics attached.
ID:	1840821   Click image for larger version
ID:	1840822   Click image for larger version
ID:	1840823   Click image for larger version
ID:	1840824   Click image for larger version
ID:	1840825   Click image for larger version
ID:	1840826   Click image for larger version
ID:	1840827   Click image for larger version
Old 01-15-2013, 05:22 PM
  #237
svrcp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Arch should I resevre a paint slot for you? I got one going now,along with mine plane. lol
svrcp is offline
Old 01-15-2013, 05:41 PM
  #238
rcpattern
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Absolutely JR. Gotta finish Tara's bird first. Probably mid Feb timeframe.
Old 01-16-2013, 08:11 AM
  #239
AmericanSpectre505
AmericanSpectre505's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very Kewl,....
bholsten
AmericanSpectre505 is offline
Old 01-26-2013, 06:42 AM
  #240
Zi-Chun Lin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am going to test my episode tomorrow..The plane without battery was 3.54kg
WOW..........It's light
Will have some pic very soon!!!
Zi-Chun Lin is offline
Old 01-29-2013, 03:50 AM
  #241
Zi-Chun Lin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some detail pic.I use Pull-pull system inseat original design
ID:	1845495   Click image for larger version
ID:	1845496   Click image for larger version
ID:	1845497   Click image for larger version
ID:	1845498   Click image for larger version
ID:	1845499   Click image for larger version
ID:	1845500   Click image for larger version
ID:	1845501   Click image for larger version
Old 02-16-2013, 07:54 PM
  #242
shannah
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been using the Falcon V2 21x13.5 lately. I really like this combination. Good speed, nice downlines. Power utilization is good as well. I used 3600mah flying a big F13 in the wind today. It really slows down quickly when you throttle back, so you have to work the throttle a bit more than with the 21x14 APC but its worth it. I had to shove my batteries forward to compensate for the big weight difference between the APC and the Falcon V2.
I love flying F13 with this machine. All in all I'm pretty happy with it. My only concern so far is that I'm carrying a bit more low throttle to down elevator mix than I like. Other than that, its looking good.
I hope to be able to make it to the PHX contest next week. I always enjoy flying at the Sun Valley Fliers field.
shannah is offline
Old 02-18-2013, 08:17 PM
  #243
sc204
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone care to comment on what sort of work it would take to fit a Contra Drive into this aircraft?
Stuart
sc204 is offline
Old 02-18-2013, 08:50 PM
  #244
Jetdesign
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like that Tara's getting a Monolog
Jetdesign is offline
Old 02-18-2013, 09:27 PM
  #245
TonyF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm putting together an Episode for the Contra now. Mine has the fuselage built for the Contra, with the right size spinner and zero side-thrust. These are now available from BJ Craft as is the Nuance and the Prologs. Other then having to come up with the bulkheads to mount the unit it has been no problem. Hoping to get it flying next week.
TonyF is offline
Old 02-19-2013, 02:48 AM
  #246
fehringer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Tony,
I am really interested in any feedback on the Episode's flightperformance with the contra, if you could share once you had a few flights that would be great.
Also, from some of the pictures the landing gear mount seems to be built very light, there doesn't seem to be any carbon re-enforcements, do you think it will stand up to flying off grass?
Many thanks,
Gerhard
fehringer is offline
Old 02-19-2013, 03:43 AM
  #247
ram_z
ram_z's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gerhard,
There should be no problem on grass since it is the same mount as the Nuance / Prolog.
I flew my Nuance for more then 300 flight which were all on grass.
Ram
ram_z is offline
Old 02-19-2013, 04:03 AM
  #248
f3a05
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: fehringer
Hello Tony,
Many thanks,
Gerhard
The landing gear,and the mount, are very well designed, and you should not have any problems with them on grass.
Like the previous poster, I've had quite a bit of experience with them ( on the Episode in my case).
What you do need to watch, though, on the sort of heavy lumpy sodden ground we have here. at present, is the risk of nosing over/wheels digging in on take-off.
The resulting prop strikes can be expensive.
Prevention is not too difficult, of course, once you've noticed the tendency. Just more up elevator to begin the take off run, or buy the later gear with less backward rake.
f3a05 is offline
Old 02-19-2013, 04:04 AM
  #249
rcpattern
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: fehringer
Hello Tony,
Many thanks,
Gerhard
I have over 200 flights on the Episode off grass with zero problems.
Arch
Old 02-19-2013, 05:04 AM
  #250
sc204
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: TonyF
Well that would certainly make it easier
sc204 is offline
Reply
Display Modes
