If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 9 of 26 FirstFirst ... 789101119 ... LastLast
Results 201 to 225 of 648
  1. #201
    Join Date
    Nov 2007
    wexford, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    Hi Tony,
    Sounds like it might be worth trying a cannalyser on the Nuance first.
    Are the canopies interchangeable ?
    Brian
  2. #202
    Join Date
    Jan 2002
    Hoffman Estates, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    ORIGINAL: serious power
    Hi Tony,
    Brian
    Brian I think they may be interchangable. The Nuance and the Prolog are. The basic fuse is the same on all 3 models. I have no idea what effect it would have. Mike
    Mike Mueller
    Gator-RC.Com F3aUnlimited.com
    1800 380 9373
    mike@F3AUnlimited.com
    mike@gator-RC.com
    Distributor and Retailer of TopRCModel Airplanes
  3. #203
    Join Date
    Dec 2001
    Rosamond, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    As Steve mentioned earlier, the wing location, stab location and the layout of the area of the rudder are different between the Nuance and the Episode. A canalyser on the Nuance might work, but I'd rather just try the Episode.
    TonyF - Team Horizon, Team Contra Drive, Neu Motors
  4. #204
    Join Date
    Oct 2003
    Great Mills, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    The canopies do fit, however the Episode uses different attchment method, but they do fit on the fuse.
    Arch
    Team JR, YS Engines, Morgan Fuels, F3A Unlimited, Team BJ Craft, Thunder Power RC, Castle Creations, Vogelsang Aeroscale
  5. #205
    Join Date
    Jan 2002
    Hoffman Estates, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    Right Arch Chris said the attachmenet system on the Episode is like the Wind Pro and the Oxai's. They have the buttons. Mike
    Mike Mueller
    1800 380 9373
    mike@gator-RC.com
  6. #206
    Join Date
    Jan 2002
    Hoffman Estates, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    Mini version
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Mike Mueller
    1800 380 9373
    mike@gator-RC.com
  7. #207
    Join Date
    Oct 2003
    Great Mills, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    Very nice. I want one of those.
    Arch
  8. #208
    Join Date
    Jan 2002
    Hoffman Estates, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    I'm thinking they may be coming with the new planes. The first shipment is in Sidney Australlia today. Mike
    Mike Mueller
    1800 380 9373
    mike@gator-RC.com
  9. #209
    Join Date
    Apr 2003
    Katy, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    Mike
    What route do these things take in their travel for mfg to F3AU?
    Earl
  10. #210
    Join Date
    Jan 2002
    Hoffman Estates, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    Hey Earl. They travel south thru the Indian Ocean and come thru the Suez canal. Then west thru the Rock Of Gibraltor. Ending up in New York and then into Baltimore. The ships make many stops along the way. It takes about a month. I think there in pirate sea's for a little bit too. Mike
    Mike Mueller
    1800 380 9373
    mike@gator-RC.com
  11. #211
    Join Date
    Oct 2003
    Great Mills, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    Thanks to Chris Moon, I was able to get some flights on the "Company Episode" before mine arrives next month. I put 2 on it yesterday and 6 on it today. I really like this plane. I still think the Nuance flies P a little better, but the Episode is incredible for F. Snaps are very quick and easy to stop. The rudder is as effective as most foamies I've flown. You can actually loop the plane tighter knife edge than you can upright. Great flying plane.
    Arch
  12. #212
    AmericanSpectre505's Avatar
    Join Date
    Mar 2007
    Fayetteville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    I'm jealous,.....LOL
    bholsten
    Bill H.
    FAI/F3A District 2
    Hayes Hobby House, DuraLite batteries, YS Parts and Service, Team Low Life Graphics.
  13. #213
    Join Date
    Mar 2005
    Saffron Walden, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    ORIGINAL: shannah
    ORIGINAL: f3a05
    My canalyzer is set at 0.3 degrees negative ( i.e.trailing edge raised) relative to the wing.
    The wing incidence, measured on the ''non-aileron'' part,near the aileron root, is itself set (by the factory settings on my example), at 0.8 degrees positive relative to the tail.
    You might want to recheck your incidences again. I found it pretty difficult to get an accurate measurement on the wing at the non-aileron section. That section is swept fairly deep and it was hard to keep the incidence meter on the wing properly.
    I checked with B.J. on this topic and he says that the wing and canalizer factory setting is +1.5 relative to the horizontal stabilizer. Set the horizontal stab at zero trim and verify its center with the neutral elevator jig template (be careful because there is a bit of play in that, not much but a bit). Then measure the wing incidence relative to the stab. The wing should be +1.5 positive in relationship to the horizontal stab. The canalizer is not adjustable but is set to match the wing incidence at the factory setting. Make sure that your canalizer is fitting flush in the mount and that the TE is not raised.
    This +1.5 wing incidence is a starting point for the airframe. Adjustment may be necessary depending upon final CG setting and preference. Moving the CG may require adjustment to the wing incidence to restore elevator trim to zero.
    If you are indeed at +0.8, this might explain why you had some pitching on knife edge. Try bumping up the incidence and see. I think I am at +1.3 so I'll dial in a bit more on mine.
    Hope this helps. I'll update as I get more info on mine and verify where I am at. I think it's probably a good idea to install adjusters on this one, especially if you move the CG around.
    Rechecked the wing incidence relative to the tail, and yes, still 0.8 positive.
    So, returned the elevator to 0 relative to the stab using the supplied jig, used the wing incidence adjusters to eliminate the (right) aileron trim, then set the wing to 1.5 positive.
    Set the c of g at 270 mm from the back of the canopy floor, and voila ! no k/e mix, to pitch or roll, vertical uplines fine ;no pitch or yaw.
    Power-off vertical downs still need a fair bit of the usual throttle to elevator mix, more than I'm used to at 5% on a JR Tx, but flyable.
    Needs more fine tuning, but all-in -all the c of g at 260-270,and the decalage at 1.5, definitely suits the model.
    Many thanks for the advice!
  14. #214
    Join Date
    Nov 2007
    wexford, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    Hi,
    Have you reset the cannaliser or is it now at -1.0
    Brian
  15. #215
    Join Date
    Mar 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    Hi,
    Brian
    It is at -1.0 relative to the wing, thus + 0.5 to the tail.
    Photos just now, meter left on between shots:
    Tail:
    Uploaded with ImageShack.us
    Wing:
    Canaliser:
  16. #216
    Join Date
    Sep 2004
    placentia, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    I finally got a chance to go put in a few more flights yesterday. I am still fine tuning the incidence, thrust, and subtle mixing. I'm liking the way it flies. I LOVE the snaps. It really does the opposite snaps in F13 nicely. I'll fly again this weekend again and do some more trimming. I had a bit of a pull to canopy on upline so I put another shim for down thrust and we'll test that next time out. I found that my elevator throws weren't quite aligned so I tweaked that setup a bit as well. My canalizer and wing are pretty close, my latest measurement shows that my wing is +0.2 relative to the canalizer.
    I started setting up my new DTFS wings on the Nuance so I'll be interested in seeing how it compares to the original wings and the Episode. My thoughts from yesterday were that the Nuance has a slight edge for P13, but we'll see how that holds up as I get the Episode dialed in.
    Team BJCraft
  17. #217
    Join Date
    Jan 2004
    Galway, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    Hi shannah, I would be very interested to know how the DTFS wings operate on the Nuance as I may purchase a set. Post ASAP please
    Paul Houlihan
  18. #218
    Join Date
    Sep 2004
    placentia, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    Hello Paul,
    I will try and get those wings installed and tested shortly. I saw a set fly on Kris Fitzsimmons' Nuance at our District 7 meet recently. It looked very good in the air. I'm anxious for some side by side comparison on mine. I have a round of travel coming up for work so hopefully I can give it a shot next week, otherwise it will be later in December.
    FWIW, on the topic of the Episode, I was able to do some real sequence practice with the Episode today. It flies really well. I still need to get used to the rudder as it is sensitive, but I am getting that dialed in. It feels very solid in the air overall.
    Steve
    Team BJCraft
  19. #219
    Join Date
    Sep 2004
    placentia, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    Hi Paul,
    Sorry, I got the wings fitted to the Nuance but it has been raining for the past couple days. I'll post on the Nuance thread when I get a chance to fly it. Probably won't be for a couple weeks due to work commitments.
    Team BJCraft
  20. #220
    Chris Moon's Avatar
    Join Date
    Dec 2002
    Leesburg, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    The ship with the Episode ARFs arrived today in port, once they clear Customs and are delivered to us we will get them back out to everyone who ordered one. That should occur within a week barring any Customs delays.
    F3A Unlimited
  21. #221
    Join Date
    Sep 2004
    placentia, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    I thought I would post this link to a good cheap 70mm CF spinner. There aren't a lot of good 70mm spinners to choose from out there. I cut my own cooling holes (I'll post a pic when I get home). It's fairly light and looks good. A bit on the pointy side, but for the price ($25) it's great.
    http://sdshobbyusa.net/index.php?mai...oducts_id=3103
    Team BJCraft
  22. #222
    Join Date
    Sep 2004
    placentia, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    I got a chance to squeeze in a couple flights yesterday. I was trying a 20x13 prop per BJ's suggestion. He recommends a 20" pitch because he says that the smaller diameter is more compatible with the canalizer. I thought it was a bit less yaw sensitive and rolled more axially (although it was pretty nice on the 21x14). It was faster overall, but not too bad.
    I am just about ready to fix the rear anti rotation pins in place since I think my incidence is OK. I made a very slight thrust adjustment that I want to test before I do that however.
    I still think this is a real solid flying airframe. It takes more work to fly it as smooth in P13 as the Nuance but it clearly excels in the more difficult FAI maneuvers. I hope to get out and do some more serious sequence flying over the next few weeks. I'll post my updates and progress.
    Team BJCraft
  23. #223
    ram_z's Avatar
    Join Date
    Feb 2005
    Ness-Ziona, ISRAEL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    Hi Steve,
    Thanks for the info.
    Since I will set up my Episode with contra drive, I wonder which prop and gear ratio I sould start with...
    Any ideas?
  24. #224
    Join Date
    Sep 2004
    placentia, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    I am not sure which prop and gear set would be best. Perhaps Tony F. can chime in on this. He's flown mine and has some thoughts as to the contra drive application on the Episode. Tony?
    Team BJCraft
  25. #225
    Join Date
    Dec 2001
    Rosamond, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: BJCraft Episode
    I would start with the 10.16 ratio gears and a 22x20 on the front cut to 21.5 length. On the rear I would use a 22x22 cut to 21 length. I've run that a lot on the Nuance and it seems a good way to go. I doubt if the Episode wants to be flown any faster then the Nuance. It might even want to be flown a little slower. If so you can run the same props with either the 10.33 ratio or the 10.56.
    I'm supposed to be getting an Episode soon so I'll know more after I get a chance to fly it with the Contra.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
