Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
New OXAI CITRIN by Wolfgang and Roland Matt
Reply
Old 01-18-2013, 02:10 PM
  #101
andreyengin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New OXAI CITRIN by Wolfgang and Roland Matt
Another photo of Citrine with a brocken nose, happened on the world cup in a Chech Haven,on line 45 upwards a motor fly out from fuse and flew away,motorwas without back support Motor is Q-80
andreyengin is offline
Old 01-19-2013, 07:32 AM
  #102
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: andreyengin
Another photo of Citrine with a brocken nose, happened on the world cup in a Chech Haven,on line 45 upwards a motor fly out from fuse and flew away,motor was without back support Motor is Q-80
In my opinion the is no need for a rear support to the Q-80.
In some modeles you my need to reinforce the nose like I did in my Xigris, see post 300.
http://www.rcuniverse.com/forum/m_93...12/key_/tm.htm
Best regards,
Isaac Najary
najary is offline
Old 01-19-2013, 11:33 AM
  #103
andreyengin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes,the best way to reinforce nose with carbon for Q-80 they have a lot power and gyroscopic efekt ,but with rear suport better.For Hacker С-50 sufficiently thickness nose.
I am looked in threemy friends, the same situation nose of airplane(other f3a models) with Q-80 brocken,after of strengthening of nose and install of back support fly until now.
Old 05-14-2013, 07:53 AM
  #104
adrielmesias
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys,
I just finished my Citrin and maidened it. It is really a great flying plane, nice and relaxed flight but the aggresive side is there when you need it. The only issue I have is that it is quite a lot tail heavy, if I use batteries such as the lightest TP4400, it surely won't balance out. I'm usinh the hacker C50-13XL. Any suggestions?
Regards,
Adriel Mesias
adrielmesias is offline
Old 05-15-2013, 10:03 AM
  #105
cartercg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Adriel,
That is not surprising. With a light motor, spinner and prop you will struggle to get the CG forward to the recommended spot using a light flight battery. You need to get everything as far forward as you can. That is all you can do, and if the CG is still too rearward then consider using a heavier prop.
I installed my Rx and switch as far forward as I could, and have the Rx battery right next to the motor. Even with a 1130g flight pack the end of the pack is within 3cm of the back of the motor.
Regards
Clint
cartercg is offline
Old 09-23-2013, 03:21 PM
  #106
Pablo Kuri
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Second Flight Motor Q 80 ..........
Pablo Kuri is offline
Old 09-23-2013, 04:00 PM
  #107
GlennO
GlennO's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry to hear another one has failed. Did you use the supplied ply motor mounting?
cheers GlennO
GlennO is offline
Old 09-23-2013, 04:07 PM
  #108
Pablo Kuri
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That plane is from a friend of mine and I think he used the supply motor mount.
Old 09-24-2013, 09:52 AM
  #109
Anthony-RCU
Anthony-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is terrible! Was the rear of the motor supported?
Anthony-RCU is offline
Old 09-24-2013, 03:53 PM
  #110
Mvelez
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anthony: no.
Mvelez is offline
Old 09-24-2013, 05:04 PM
  #111
GlennO
GlennO's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine was well supported at the rear and still blew the front off.. My feeling is that the ply ring and mounting plate which is made of ply is the problem. IMO they should be
replaced with a carbon set. I have since brought a new fuselage and fitted a pletty advance with carbon mounting. Its now done about 600 flights without any problem.
Quote:
GlennO is offline
Old 09-25-2013, 07:32 AM
  #112
Mvelez
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is what I did with mine:
first I took out in a piece of paper the outer geomoetry of original plate from Oxai and then threw it to the garbage.
Then I took two 1/8" midwest ply (not lite ply) and made five layer: carbon - ply - carbon - ply - carbon which ended with a little bot more than 1/4" thickness. Then passed the outer geometry, and then drew the holes of the engine directly to this plate, so no intermediate cross or any plate in between the firewall and the motor so only one piece from the fuse to the motor. the only downside of this is that it will be hard to put a new motor different than a Q80 in the future. Even using the original geometry as you can see in the picture, i had to trim it a lot.
then I glued the firewall using 30 min epoxy and very little microballoon.
then i drew the rear suport and my firend Federico drew it in autocad for me. We laser cut the support in normal 1/8" ply and had it laminated with 2 oz carbon on both sides. i used a solid carbon rod to put inside the motor and 4 mm metric screws with washer, locknut and loctite. this is not the lightest setup, but i had enough weight to spare and i am not a big fanof super light biplanes. I now have a final weight of 4920 which is fine for me. On the other hand this is the last place on a Citrin Id play to save weight.
Here are some pics of the set up if somebody wants the cad or pdf on scale 1:1 drawing, I can share it no problem, just email me marcelovelezuribe@gmail.com
i have now around 150 flights with the citrin from January 20th this year with absolutely no problems.
Marcelo
ID:	1924726   Click image for larger version
ID:	1924727   Click image for larger version
ID:	1924728   Click image for larger version
ID:	1924729   Click image for larger version
ID:	1924730   Click image for larger version
ID:	1924731   Click image for larger version
ID:	1924732   Click image for larger version
Mvelez is offline
Old 10-03-2013, 06:47 PM
  #113
adrielmesias
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys,
I have a Citrin that i bought earlier this year and due to other activities, it's not getting the attention and flight time that it deserves. I'm thinking of selling it and giving it a better home and using the money for a dire need right now. I have two flights on it and it's equipped with nothing but the best components, everything is top of the line. No scratches no nothing, everything is perfect. I still have the purchase invoice for this model, email me if you're interested and I'll inform you about the equipment on it and maybe agree on a price.
Contact me at: ams1497@yahoo.com
Best regards,
Adriel Mesias
Old 03-10-2014, 04:35 AM
  #114
awry
awry's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got my Citrin finished recently. This is the first bipe I've flown and so far I'm happy. It is very different from my Spark so I'll need some time to get used to it but it flies beautifully and I really like how it feels in the air.
My equipment are:
Hacker Q80-14xs
Hacker MasterSpin 99
Mejzlik 20x13 3-blade
82mm Marquet spinner with cooling slots and marquet insert
Futaba 7008 receiver
6x Futaba BLS 173SV
1x Futaba BLS 171SV
PowerBox SmartSwitch
MK axles
MK 55mm wheel
Original Oxai links and servo tray
3mm Carbon Herex sandwich plate for battery tray
.6 mm rudder wire
800 mAh 2s lipo
10s5000 mAh main pack
Total weight with everything except the main pack is 3740g. I'm running SBUS on all the servos except for the rudder which plugged straight to the receiver channel. The power is unregulated 2s lipo.
I've flown about 6 flights on it and haven't settled on the CG yet. It pulls to the canopy on KE but there is no need for a rudder-aileron mix. I have my CG on the recommended 115mm. It seems to be a good starting point. I've tried a more forward CG but it seems to pull more to the canopy so I think I'll fly on the recommended CG a bit more. I didn't have any issues with getting enough weight on the nose. Actually the opposite. I could use a tad more weight on the tail. I will try a lighter pack.
Here are some pics during install, measurement and testing. I have changed some of the parts since these was taken so I'll post the final build pictures later.
ID:	1976672   Click image for larger version
ID:	1976673   Click image for larger version
ID:	1976674   Click image for larger version
ID:	1976675   Click image for larger version
ID:	1976676   Click image for larger version
ID:	1976677   Click image for larger version
ID:	1976678   Click image for larger version
ID:	1976680   Click image for larger version
ID:	1976681   Click image for larger version
ID:	1976682   Click image for larger version
ID:	1976683   Click image for larger version
ID:	1976684   Click image for larger version
ID:	1976685   Click image for larger version
ID:	1976686   Click image for larger version
ID:	1976688   Click image for larger version
ID:	1976689   Click image for larger version
ID:	1976690   Click image for larger version
ID:	1976691   Click image for larger version
ID:	1976692   Click image for larger version
awry is offline
Reply
Display Modes
