Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
New Falcon props and spinners
Reply
Old 07-09-2013, 06:33 AM
tschmidt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New Falcon props and spinners
Anyone know what size the little screws are on these spinners. One of mine was buggered up and I had to slot it to remove it from the spinner. I'd like to buy some extra's to keep on hand.
Todd Schmidt
tschmidt is offline
Old 07-09-2013, 06:42 AM
mups53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Icall them the lil bugger size Todd:
http://www.f3aunlimited.com/webstore...roducts_id=661
Having spares of these is essential.
Mike
mups53 is offline
Old 07-09-2013, 06:55 AM
Dave Harmon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: tschmidt
Todd Schmidt
Hi Todd.....I use a little Never-Seize on the threads to keep the screws from galling....so far so good!
Dave
Dave Harmon is online now
Old 07-09-2013, 07:31 AM
mups53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Falcon was putting them on too tight for a while and we have asked them to loosen up a bit. I've had a few that we stripped the heads trying to get off. I found side cutters used carefully works to get off the stripped ones. The CF gives a little and you can if careful get a bite on the head and remove. Mike
mups53 is offline
Old 07-09-2013, 09:11 AM
Portlandflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike,
I just cut a slot in one with a Dermal cut off wheel and used a straightscrewdriver....it came right out.
Portlandflyer is offline
Old 07-09-2013, 09:22 AM
  #31
mups53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've had that work work and I have had it fail. A few times I made the dremel slot and the head broke on one side. That left me with a bigger problem.
This new way I discovered works great.
I just went thru our whole inventory and fixed about 20 stuck screws so I feel confident that this way works easily.
Mike
mups53 is offline
Old 07-09-2013, 09:30 AM
  #32
tschmidt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks everyone, I'll get some replacements ordered..
Todd
tschmidt is offline
Old 07-09-2013, 09:31 AM
  #33
Jetdesign
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I still can't get the spacer out.
Jetdesign is offline
Old 07-09-2013, 10:22 AM
  #34
PatternFlyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
2.6mm x 5mm button head.
PatternFlyer is offline
Old 07-09-2013, 10:26 AM
  #35
Anthony-RCU
Anthony-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pressed mine out in a vice. Found a short bolt that was the right size and placed some large washers behind. Popped out pretty easy and then a light sand to fit the Neu prop adapter. They are 2.5mm x 5mm which is used in some of the r/c car stuff.
Anthony-RCU is offline
Old 07-09-2013, 10:29 AM
  #36
Jetdesign
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Anthony, forgot about the drill press lol.
Old 12-16-2013, 07:37 AM
  #37
g_mkoch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
can someone suggest how to install a 22X12 mezjlick prop on a falcon spinner
g_mkoch is online now
Old 12-16-2013, 07:46 AM
  #38
mups53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tell me what size spinner and what motor and I'll tell you. Mike
mups53 is offline
Old 12-16-2013, 07:49 AM
  #39
g_mkoch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
75mm spinner, Q80-14XS
Old 12-16-2013, 08:19 AM
  #40
mups53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just checked. The hub on the prop is too large to fit without some modification to the spinner. It just needs a tad of cutting but be careful not to invade the mounting holes on the side of the spinner or the cooling slots.
The shaft on the Q80 tucks in nicely. The 8mm inserts sometimes need to be shaved down to fit the 8mm shafts. I do it with a taper reamer.
Caution: The 70MM spinners come with or without cooling holes. This is because with some of the larger props cutting them to fit will go into the cooling slots.
All of the stock falcon props fit any of the Falcon spinners.
I hope this helps. Mike
mups53 is offline
Old 04-14-2014, 12:29 PM
  #41
Jetdesign
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I finally got around to measuring the Falcon spinner adapter and the Pletty Advance shaft. Shaft is 7.98mm, spinner adapter is something like 7.6mm.
What are you guys using to hold the little silver adapter when you ream it? What pita
Old 04-14-2014, 02:00 PM
  #42
Dave Harmon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Joe....don't ream the adaptor.
Mount the Advance motor, connect it up and run it slowly while holding a strip of 400 wet/dry with some oil to take the shaft down just a bit.
It will not take much....keep trying to fit the adaptor as you go but clean the shaft before you trial fit it.
The adaptor does not want to be loose....make it a just-right fit.
Dave
Old 04-14-2014, 05:33 PM
  #43
OhD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave
You guys just ruined my day. I recently bought a Falcon spinner for a Neu with an 8 to10 mm prop adapter. Am I going to be able to ream the spinner adapter to 10mm? Do they sell a 10mm adapter?
By the way my 8mm reamers fit perfectly in the Falcon supplied adapter.
Jim O
OhD is offline
Old 04-14-2014, 07:20 PM
  #44
nonstoprc
nonstoprc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jim,
I took out the insert originally installed in my copy of the backplate. Not sure if there is an insert in yours.
nonstoprc is offline
Old 04-14-2014, 07:22 PM
  #45
Dave Harmon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jim O
Hi Jim....oh boy....I'm not sure there is enough meat on the spinner adaptor to ream it to 10mm.
it is pretty small so I don't know how you would hold it to ream it anyway.....as far as getting a 10mm adaptor...I suggest calling Jarvis at Maxx Products and ask him. (847) 438-2233
You could also contact Lockhart and see how he does it.
Dave
Old 04-14-2014, 07:24 PM
  #46
Jason Arnold
Jason Arnold's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave
Don't think I'd be sanding a precision drive shaft over reaming an alloy bush. I'd be pulling the bush out and either reaming it or machining it in a lathe. You could also make a new bush if you have a lathe...
From my experience, the Falcon spinner I had fitted the Advance perfectly.
Cheers,
Jason.
Jason Arnold is offline
Old 04-15-2014, 12:02 AM
  #47
Dave Harmon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cheers,
Jason.
Hi Jason.....
I've done it.....three times....with no problem.
The measurements in a previous post clearly indicate that the Falcon bush/insert/adaptor I/D is undersized and there have been several people in the past mentioning this problem.
Perhaps you got the only spinner with the correct bushing....I have 2 of those spinners and a friend has had 2 more of the Falcon spinners and all had undersized inserts.
I don't have a lathe....and if I did I would not make another insert after paying $72 for it....hahah
Old 04-15-2014, 01:37 AM
  #48
Jason Arnold
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Jason.....
Hi Dave,
Respectfully I disagree. Paying $600+ for a piece of precision German engineering and modifying it over a $72 Chinese (Sacrificial) item makes no sense to me. Everyone to their own though.
Cheers,
Jason.
Old 04-15-2014, 05:56 AM
  #49
Dave Harmon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Dave,
Cheers,
Jason.
Look....you need to understand that the motor(s) belong to me....I paid for them so I am going to use them as I see fit and there is nothing you can do about it.
It is not just me doing it either.
You need to direct your comments towards Jarvis at Maxx Products.
As far as the tone of your comments are concerned.....I can't say on here what I really want.....
Old 04-15-2014, 06:20 AM
  #50
mups53
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys since I have everything in front of me I looked into this just now.
What I have in stock with the Falcon spinners fits the Pletty Advance shaft perfectly without modification.
I think Falcon may have opened up the tolerance a tad.
Here are some pictures to back up my claim.
Also the Falcon backplates are made with a 10mm hole. They add an 8mm insert that can easily be punched out.
Thanks, Mike
Name:	2014-04-15 09.09.36.jpg
ID:	1987227   Click image for larger version
Name:	2014-04-15 09.12.54.jpg
ID:	1987228   Click image for larger version
Name:	2014-04-15 09.13.29.jpg
mups53 is offline
Reply
Display Modes
