burned 2 ESC in few days, help me solve my problem
Need your help in solving my problem, Burned 2 Castle 80HV2 ESC’s in few days. My setup is Pletty Advance with 20.5x14.5 Falcon V2 on JL Neptuno using Rhino 4900Mah batts. I have been using the CC 80HV2 for more than 50 flights suddenly deadstick, when I land the plane it has burning smell and no power. ESC looks normal but it has a strong burned smell. Plug my new CC 80HV2 the next day and flew 6 flights on my 7th flight motor skeech after few minutes of flying. I landed and check the temp of the ESC and Motor, temp is normal. Restored the settings to factory setting and reprogramed the ESC again, flew the plane 4 mins and plane got deadstick again. The ESC has no burned smell and has normal temperature. My settings was 10 degress on the timing and 8khz on the PWM. My friend told me that timing should be 20 degress and PWM should be on the outrunner mode.
I already ordered Futaba MC9100A ESC, but I wanted to fix this problem before installing the new ESC’s.
Thanks guys.
I don't remember ever seeing an inrunner/outrunner selection on an /esc. Number of poles, yes. I've has some problems in the past with pole count on Hacker/Pletty motors.
Walt
Typical settings for a Castle ESC and pattern flying use are for LOW timing (5 degrees) and Outrunner or 8khz on the PWM.
The Castle ESC WILL AUTOMATICALLY ADJUST TIMING as it sees fit. When you set the timing to low, this is not an absolute setting. If the ESC sees opportunity to run at 20 degrees efficiently and effectively, it will do so.
I was talking to a guy at a contest a few weeks ago who had problems with screeching and operability, and people were telling him to ADVANCE his timing. If you read the Hacker motor specs, it says something like 20 degrees for the timing. THIS IS NOT THE PROPER SETTING FOR CASTLE ESC's. You should start with LOW timing and adjust from there, if need be.
Adjust your settings to LOW timing, 8KHZ pwm, 20% brake, SOFT motor start, LOW throttle response.
The Advance is technically an in-runner, but it shares some similar operating parameters as an outrunner.
<style type="text/css"></style>
5 | ||||||
# Graph Data - 6 Sessions - Saved Sunday | July 22 | 2012 | ||||
# Start Of Session - Sample Time: 1.000 | ||||||
# Reset Source (Cause of reset): Normal Boot-up Sequence | 255 | |||||
# Idle Times: | ||||||
Throttle | Power-Out | Voltage | Ripple | Current | Temperature | Speed |
True | True | True | True | True | True | True |
0.9702 | 0 | 41.2 | 0 | 0 | 84.1 | 0 |
0.9702 | 0 | 41.2 | 0 | 0.8 | 84.1 | 0 |
1.2837 | 0 | 41.2 | 0 | 0.8 | 84.9 | 0 |
1.4796 | 37.647 | 41.2 | 1.268 | 6.4 | 85.7 | 30610 |
1.2837 | 0 | 41.2 | 0 | 0 | 86.4 | 6168 |
1.3385 | 9.02 | 41.2 | 0 | 0 | 86.4 | 2673 |
1.4874 | 38.431 | 41.2 | 1.268 | 6.4 | 87.2 | 31028 |
1.5893 | 58.431 | 41.41 | 2.113 | 16 | 87.9 | 41582 |
1.7225 | 85.882 | 40.36 | 2.113 | 44.7 | 89.5 | 57512 |
1.7147 | 83.137 | 40.15 | 2.113 | 46.3 | 93.4 | 56556 |
1.7147 | 83.137 | 39.94 | 1.268 | 39.1 | 96.6 | 57030 |
1.699 | 80.392 | 40.15 | 1.69 | 32.7 | 98.2 | 55936 |
1.699 | 80.392 | 40.36 | 1.69 | 32.7 | 99.1 | 55936 |
1.699 | 80.392 | 40.36 | 1.902 | 29.5 | 100.7 | 56871 |
1.7147 | 84.706 | 40.15 | 1.69 | 31.1 | 100.7 | 57190 |
1.6912 | 80 | 40.15 | 1.69 | 29.5 | 102.4 | 56400 |
1.699 | 80 | 40.15 | 1.057 | 30.3 | 102.4 | 56244 |
1.699 | 80 | 39.94 | 1.057 | 29.5 | 103.3 | 56400 |
1.699 | 80 | 40.15 | 1.057 | 28.7 | 104.1 | 56400 |
1.6755 | 75.294 | 40.15 | 1.69 | 23.9 | 105 | 54156 |
1.6442 | 70.196 | 40.36 | 1.69 | 20.7 | 105.9 | 51688 |
1.6442 | 70.196 | 40.36 | 1.268 | 18.3 | 105.9 | 51427 |
1.6442 | 70.196 | 40.36 | 1.902 | 18.3 | 105.9 | 51427 |
1.6285 | 67.451 | 40.36 | 1.479 | 14.4 | 104.1 | 51042 |
1.6285 | 67.451 | 40.57 | 1.057 | 16 | 105.9 | 49919 |
1.652 | 70.98 | 40.36 | 1.268 | 18.3 | 105.9 | 51688 |
1.7147 | 84.706 | 39.94 | 1.902 | 34.3 | 105.9 | 58838 |
1.7382 | 89.02 | 39.94 | 1.69 | 40.7 | 105.9 | 60764 |
1.7696 | 94.51 | 38.46 | 0.634 | 51 | 106.8 | 62057 |
1.7852 | 98.039 | 37.82 | 0.423 | 59.8 | 108.6 | 63209 |
1.7696 | 94.902 | 37.82 | 0.845 | 58.2 | 111.3 | 63209 |
1.2837 | 0 | 39.94 | 0 | 0.8 | 113.2 | 31802 |
1.2837 | 0 | 39.94 | 0 | 0 | 112.2 | 26899 |
1.2837 | 0 | 40.15 | 0.211 | 0 | 110.4 | 30337 |
1.3699 | 14.51 | 40.15 | 0.211 | 0 | 108.6 | 37739 |
1.5344 | 47.843 | 40.36 | 1.057 | 4.8 | 106.8 | 46720 |
1.605 | 62.353 | 40.36 | 1.268 | 9.6 | 106.8 | 50662 |
1.652 | 71.373 | 40.36 | 1.479 | 16 | 106.8 | 53307 |
1.652 | 71.373 | 40.36 | 1.69 | 16.7 | 106.8 | 53030 |
1.652 | 71.373 | 40.36 | 1.268 | 16 | 107.7 | 53307 |
1.652 | 71.373 | 40.36 | 1.268 | 15.2 | 107.7 | 53728 |
1.6598 | 72.941 | 40.15 | 1.479 | 17.5 | 107.7 | 54012 |
1.6598 | 72.941 | 40.36 | 1.268 | 18.3 | 107.7 | 53870 |
1.6598 | 72.941 | 40.15 | 1.69 | 19.1 | 108.6 | 53307 |
1.6598 | 72.941 | 40.15 | 1.902 | 20.7 | 108.6 | 52756 |
1.699 | 80 | 39.94 | 1.902 | 29.5 | 109.5 | 55631 |
1.699 | 80 | 39.94 | 1.268 | 33.5 | 109.5 | 54590 |
1.699 | 80 | 39.94 | 2.324 | 35.9 | 111.3 | 54012 |
1.7382 | 89.02 | 39.09 | 1.902 | 44.7 | 112.2 | 58002 |
1.7382 | 89.02 | 38.88 | 0.845 | 49.4 | 114.1 | 58167 |
1.7382 | 89.02 | 39.09 | 1.902 | 48.6 | 116.1 | 57838 |
1.7147 | 84.706 | 39.09 | 1.69 | 42.3 | 118 | 55631 |
1.699 | 80 | 39.51 | 2.113 | 35.9 | 119 | 53447 |
1.6755 | 75.294 | 39.94 | 2.324 | 31.1 | 121.1 | 51819 |
1.652 | 70.98 | 39.94 | 1.479 | 21.5 | 121.1 | 50041 |
1.4639 | 33.333 | 39.72 | 0.845 | 4 | 121.1 | 40509 |
1.2837 | 0 | 39.94 | 0 | 0 | 119 | 37054 |
1.2837 | 0 | 39.94 | 0 | 0 | 117 | 39414 |
1.2837 | 0 | 39.94 | 0 | 0 | 115.1 | 44192 |
1.5815 | 57.647 | 40.15 | 1.268 | 8 | 112.2 | 49435 |
1.5815 | 57.647 | 40.36 | 1.268 | 8.8 | 111.3 | 47591 |
1.6755 | 75.294 | 40.15 | 1.902 | 23.9 | 110.4 | 54012 |
1.7225 | 84.706 | 39.94 | 1.902 | 37.5 | 112.2 | 57512 |
1.7617 | 92.549 | 38.67 | 1.479 | 52.6 | 113.2 | 60226 |
1.7617 | 93.725 | 38.03 | 1.479 | 54.2 | 116.1 | 60404 |
1.7617 | 93.725 | 38.03 | 1.268 | 52.6 | 118 | 60404 |
1.7382 | 88.627 | 38.88 | 1.902 | 46.3 | 120 | 58838 |
1.6677 | 74.118 | 39.94 | 2.113 | 28.7 | 122.1 | 51951 |
1.6285 | 66.275 | 39.94 | 2.113 | 18.3 | 122.1 | 47702 |
1.2837 | 0 | 39.51 | 0 | 1.6 | 124.2 | 38377 |
1.2837 | 0 | 39.72 | 0 | 0 | 121.1 | 38889 |
1.2837 | 0 | 39.94 | 0.211 | 0 | 119 | 43625 |
1.2837 | 0 | 39.94 | 0 | 0 | 117 | 47043 |
1.5344 | 47.843 | 39.94 | 0.845 | 4.8 | 114.1 | 48844 |
1.6285 | 66.667 | 40.15 | 1.479 | 12 | 114.1 | 50914 |
1.6677 | 75.294 | 39.94 | 1.268 | 20.7 | 113.2 | 54156 |
1.699 | 80 | 39.94 | 1.479 | 25.5 | 114.1 | 56556 |
1.699 | 80 | 39.94 | 1.902 | 27.9 | 114.1 | 56400 |
1.6912 | 80 | 39.94 | 1.268 | 27.1 | 115.1 | 56400 |
1.699 | 80 | 39.94 | 2.324 | 32.7 | 116.1 | 54444 |
1.6912 | 80 | 39.94 | 2.536 | 35.1 | 117 | 53447 |
1.6912 | 80 | 39.94 | 2.113 | 36.7 | 119 | 53307 |
1.8087 | 100 | 36.34 | 0 | 65.4 | 121.1 | 63014 |
1.5815 | 56.863 | 39.72 | 1.902 | 19.9 | 121.1 | 41163 |
1.4326 | 27.059 | 39.51 | 0.845 | 3.2 | 122.1 | 27114 |
1.3464 | 10.196 | 39.51 | 0.211 | 0 | 122.1 | 17585 |
1.3699 | 14.51 | 39.72 | 0.423 | 0 | 120 | 16873 |
1.2837 | 0 | 39.72 | 0 | 0 | 119 | 3872 |
1.2837 | 0 | 39.94 | 0.211 | 0 | 118 | 6961 |
1.2837 | 0 | 39.94 | 0 | 0 | 116.1 | 24076 |
1.5344 | 48.235 | 39.94 | 1.057 | 4 | 113.2 | 50041 |
1.6285 | 66.275 | 39.94 | 1.268 | 12 | 113.2 | 51298 |
1.6755 | 75.294 | 40.15 | 1.902 | 19.9 | 113.2 | 53168 |
1.6755 | 75.294 | 39.94 | 1.902 | 23.9 | 114.1 | 53870 |
1.6755 | 75.294 | 39.94 | 1.479 | 23.9 | 115.1 | 53447 |
1.7147 | 84.706 | 39.51 | 1.902 | 32.7 | 116.1 | 58167 |
1.7147 | 84.706 | 39.3 | 1.057 | 34.3 | 116.1 | 58167 |
1.7147 | 84.706 | 39.3 | 1.057 | 32.7 | 118 | 58333 |
1.7147 | 84.706 | 39.09 | 1.268 | 31.1 | 118 | 58838 |
1.7225 | 84.706 | 39.3 | 1.902 | 35.9 | 118 | 57190 |
1.8087 | 100 | 38.03 | 0 | 60.6 | 121.1 | 63603 |
1.8087 | 100 | 36.13 | 0 | 62.2 | 122.1 | 63209 |
1.8087 | 100 | 35.92 | 0 | 62.2 | 123.1 | 63014 |
1.8087 | 100 | 36.34 | 0.211 | 63 | 125.3 | 62628 |
1.8087 | 100 | 35.71 | 0 | 62.2 | 125.3 | 62628 |
1.7852 | 97.255 | 37.82 | 0.423 | 60.6 | 123.1 | 61496 |
1.6677 | 74.902 | 38.88 | 1.268 | 29.5 | 126.4 | 50536 |
1.652 | 70.98 | 39.09 | 2.324 | 22.3 | 126.4 | 48496 |
1.6677 | 75.294 | 39.09 | 1.479 | 26.3 | 126.4 | 51170 |
1.6677 | 75.294 | 39.3 | 1.902 | 25.5 | 127.5 | 51427 |
1.6677 | 75.294 | 39.3 | 2.113 | 24.7 | 127.5 | 51819 |
1.6755 | 75.294 | 39.3 | 2.113 | 23.9 | 126.4 | 52217 |
1.6912 | 80 | 39.09 | 1.268 | 28.7 | 126.4 | 54884 |
1.6912 | 80 |
