If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 8 of 8
  1. #1
    Join Date
    Apr 2006
    istanbul, TURKEY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Question about charger balance connectors
    I got a new Thunder Power 1430C charger to charge 8 cells batterries for my Wind S Pro. I am a little confused about 2X4 cells balance charging. Normally I use I-Charger 1010B and have no problems with it but the TP balance board really confused me. It has a red wire going in on the right side but the cell numbers on the balance board starts from the left side for TP batterries (but they start from left for the other adapters on the right side of the board.). I get confused even while writing [&:]
    Anyway, my question is:
    As you see in the photo what port (A or B) should I use for the balance adapters (1 or 2)?
    I don't want to short circuit my batterries.
    Thanks a lot in advance...
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. #2
    Join Date
    May 2002
    Pittsburg, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Question about charger balance connectors
    I believe the balance board says 4s+4s right below those two 6-pin connectors.
    one on the left should say 4 - 5S.
    Your balance plug 1 should plug to A, #2 plugs to B.
    Thunder power blance plug is totally opposite of JST XH. Your packs have the same way Thunder Power uses. Are those Flight Power? If so, they are exactly same way as TP except it only shows 1 red wire.
  3. #3
    Join Date
    May 2002
    Pittsburg, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am sure I am right, but who knows.
    I haven't got my 1430 yet. still using 820.
    My answers are based on picture of the 1430 balcing board and 820 balancing board + the way we connect two packs on 1010C.
    http://thunderpowerrc.com/html/contact-us.php
    contact the Thunder Power if you want to make sure.
  4. #4
    Join Date
    Jul 2003
    lebanon, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just hope that the balance board is better quality than the ones used with the TP820CD.
  5. #5
    Join Date
    May 2002
    Pittsburg, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What is wrong with balance board in 820CD?
  6. #6
    Jetdesign's Avatar
    Join Date
    May 2008
    Mason, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A really quick way to find out - just try charging one of the two packs. The balance tap will not recognize the pack if it's not in the right slot. Then you will know which is the NEGATIVE terminal.
    Whatever battery goes into the negative power lead MUST go to the negative balance tap. The other pack follows in series.
    I learned this the hard way
    Joe Marri
    Enjoying all things aviation.
  7. #7
    Join Date
    Jul 2003
    lebanon, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: PatternFlyer
    Wiggle out ,with the GREATEST OF CARE , the battery balancer connector from the board hundreds of times since Jan. 2011 like I have and you'll find out why.
  8. #8
    Jason Arnold's Avatar
    Join Date
    Aug 2005
    Sydney, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: F.Imbriaco
    It's more likely that the battery balance connector is worn out. The spring contacts will spread over time causing bad contact. One can usually squeeze the contacts back together but this will only be a temporary fix. The other problem is the plating wearing off and then you get corrosion or poor contact. Most (if not all) connectors have a limited number of insertions. Once you exceed this number the contact resistance is just pot luck.
    Having the balance boards external to the charger is good. It's a sacrificial item! Looks like yours has a burnt male connector too. Once they go like this it's time for a new one.
    Regards,
    Jason.
    Precision Aero Products
    http://www.precisionaeroproducts.com.au
    Your Australian/New Zealand source for the Allure by CK Aero, Ralph Schweizer CRS and MKS Servos.
    Ph: +61-0478909530
    E-mail: sales@precisionaeroproducts.com.au
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
