Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
10 AWG vs 14 AWG
Reply
Old 10-17-2012, 05:44 AM
KenChoo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 10 AWG vs 14 AWG
Hi guys,
Just noticed today that the wires on my Zippy 5s packs are 10AWG while the battery harness I use to connect the two packs in series to make them 10s, is only 14 AWG (that's the only size they had at HobbyCity). Just wondering if that might cause a problem?
Ken
KenChoo is offline
Old 10-17-2012, 06:13 AM
g_mkoch
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 10 AWG vs 14 AWG
For a 2M I don't use anything less than 12ga. I particulary like the Deans wire since is very flexible.
Happy Landings
g_mkoch is offline
Old 10-17-2012, 08:43 AM
Silent-AV8R
Silent-AV8R's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's an easy way to tell. As soon as possible after landing feel the series adapter. If it feels warmer than the battery wires then it is having trouble with the amperage (that is where the heat comes from). If it is the same as the battery wires, I would not worry about it.
Silent-AV8R is offline
Old 10-17-2012, 03:48 PM
EHFAI
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Temp rise is a good indicator of too light a wire gauge / connection, as Silent suggests. A foot long lenght of 14ga wire will handle about 70A @ 42v - as the load voltage will be less,  the 14ga is a little light - but a couple of inches will likely work.
Here's a link to a handy DC wire size calculator: http://www.solar-wind.co.uk/cable-sizing-DC-cables.html
EHFAI is offline
Old 10-18-2012, 12:46 PM
twoturnspin
twoturnspin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I make my own adaptors for joining up packs in series as I think 14AWG is too light for 10S, very easy to do yourself. Make adaptors up in 12AWG and you will be fine in my experience just make sure the solder flows well with enough heat. All parts available from HC.
I'm curious as to what plugs you are using, HC only shows 14AWG on EC3 connectors, is that what you are using? If so can I recommend you moving up to EC5, they will carry a much heavier load.
twoturnspin is offline
Old 10-18-2012, 02:46 PM
Rendegade
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Ken, what are you flying?
Rendegade is offline
Old 10-18-2012, 03:30 PM
KenChoo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Rendegade,
How're you? I'm flying (or in the process of trimming and learning to fly) a Vanquish 2m, with Himax 210 F3A motor, Castle HV80 and 2 Zippy 5000 (25c) packs...
Cheers!
Ken
KenChoo is offline
