How many rounds at a typical pattern contest?
My Feedback: (9)
NC
I think I read that a D2 contest had 4 rounds on Saturday and 2 rounds on Sunday, is that what is typically done? I have 4 10s packs but havent got a generator yet so I am trying to figure out if that will be sufficient for a pattern contest this weekend. I have a charging box that I can bring with me and recharge at the hotel on Sat. night.
Thanks for any input
Wes Ryman
Willow Spring, NC
Wes Ryman
Willow Spring, NC
RE: How many rounds at a typical pattern contest?
Wes,
At most pattern contests, you'll find a fair number of flyers have generators and most are happy to share extra capacity to run an extra charger or two.
Regards,
Regards,
My Feedback: (45)
Wes,
A lot of guys in D2 have generators and a few of the fields even have power. The Winston-Salem contest this weekend has power at the field, but its very easy to borrow some generator time if you need it. You are always welcome to hook up to my setup. I have a Yamaha 2000W and it can easily handle several setups running at once.
See you this weekend,
Arch
Arch
My Feedback: (9)
NC
Thanks Rob and Dave. Arch I will see you this weekend. Thanks for the responses. Tested amp draw of my charger box when hooked to wall and it only pulls 3 amps while charging 2 5s packs at 5 amps on the cellproXP powered by a 24 volt meanwell power supply. It looks like the 1000 watt yamaha or Honda would have plenty of output to keep up with only 3 amps needed but for 200 or more dollars I can get a 2000w version which would have more possible uses around home.
Thanks guys
Wes
Thanks guys
Wes
My Feedback: (8)
4 flight packs will make it through the day, unless you are an early bird and catch a practice round before 9am. If I had 4 good flight packs I'd probably not even bother bringing my chargers to the field - only need to recharge rx and tx after full day of flying.
Even if you had only one flight pack, you should go to the contest. It's a lot of fun and people will make it work so that you are able to fly. Great group of guys (and an occasional girl) regardless of what district you are in.
Goal (as stated) is 4 flights on Sat and 2 on Sun. Idea is to get people back on the road as early as possible on Sunday. This doesn't always happen if the day is long or there is weather. If 6 rounds are flown, you drop your two lowest scores. If 5 rounds are flown, you drop your lowest score. I forget how many rounds are required for an 'official' contest to count, either 3 or 4. Sometimes if there is spotty rain that's all you might get.
Most people bring canopies, and there are generally extra chairs and plenty of food and drink, so if the weather is not great it is still fun.
My Feedback: (45)
ORIGINAL: wryman
Thanks guys
Wes
Thanks guys
Wes
Arch
Those Meanwell 24 volt power supplies can pull up to 1500 watts on the AC side, so the extra money for a 2000 watt generator is a good investment.
Rob
Rob
VA
Wes come out to the contest this weekend and we'll help you out. Like you said for alittle more you get twrice the power and can be use at home. Most contest we try to fly 4 round on first day when possilbe and 2 on Sunday that way everyone can leave early an drive home. See you on Saturday I'll be there on Friday around noon.
Jr
Jr
