CC Phoenix Ice2 HV80 problems
I have recently purchased a Phoenix ICE 80 HV vers 2 from F3A Unlimited
for use with an E-flight Power 90 on an 8s setup.
I set up 80 HV as per instructions with no programming (Futaba Tx)
Everything worked fine.
I then connected the C-link and set throttle end points and a 24v cut off.
(When disconnecting the motor the white lead came off the connector.
I resoldered the connector).
When I try to power up and arm the esc. I got a 4 beep error.
Followed by a continuous beep.
I reconnected the C-link and set to default factory settings.
Still getting the 4 beep error followed by a continuous beep.
So the only variable I can see here is the motor connector I resoldered.
Perhaps I didn't do a very good job on the soldering and the cable did not seat completely
into the connector?
Could this be the problem resulting in a 4 beep error?
BTW What does the continuous beep mean? Nothing in the manual.
I have contacted CC but any thoughts or tips would be most appreciated.
into the connector?
My Feedback: (8)
RE: CC Phoenix Ice2 HV80 problems
First thing you should do is see what version firmware you are running, and go to Castle's website and see if there are any bugs with that version:
http://castlecreations.com/downloads/frh-phoenix.html
