Covenant lmp-aircraft / hui yang
Hi all,
Many of you may notice Covenant already. Trought this year we have been working on updates and already we are taking orders on updated version of Covenant. (new Wing design and small upgrades) Attached you can see the final design of model. We already flew this season with prototype. Model is manufactured by HUI YANG in quality typical for all his models. Designed by Lukáš Pintér, 4 - time Slovak national champion in F3A.
Thank you!!
About Contra. Not yet, I have flow the production version for one season, Gernot Bruckmann as well, and couple of other guys too. Good results, but motor was still not released officially by JETI.
Maiden flight is done, very happy with performance in combination with Hacker Q80 - 11 PSD senstrol version with 3 - Blade prop from RS ( Stefan Kaiser edition ) Despite the heaviest version of q80 - flight weight is 4997g with Hacker 5100mah. Check out updated web lmp-aircraft for more info
I found the model more calm, Q80 -11 PSD is very powerfull compare to contradrive I used to fly.. and flying with Senstrol is as well a different cup of tea. I like that it is really true to position of your throttle stick regards to power as well to braking effect. Motor is driven by a real sine wave. (By this control the motor can be operated with more power and has a higher efficiency at the same time with less power loss and heat generation.) Thats what HACKER says and I have to agree. So yes I find it different compare to flying with contra drive. Especially no need for gear maintance
Q80 -11 PSD senstrol in combination with RS 3-Blade prop is very effective in terms of braking. It is comparable to contra I have to say, but it all depends on your flying style. Some can fly very nice with constant speed other will by flying different with same set up.
wattsup (08-20-2020)
Alex Voicu (09-18-2020)
