Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
speed controller
Reply
Old 12-27-2013, 08:10 AM
69 roadrunner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default speed controller
Iam building the lightning and putting hacker A60-7 V2 motor it is 28 pole. Is there a speed controller besides the spin 99 that I can use thanks . Steve
69 roadrunner is offline
Old 12-27-2013, 08:11 AM
69 roadrunner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It will run on 10s
Old 12-27-2013, 03:55 PM
ltc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jeti Hacker Master Mezon?
Do you want BEC or opto?
ltc is online now
Old 12-27-2013, 05:21 PM
69 roadrunner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
don't need bec or opto
Old 12-28-2013, 12:28 AM
ltc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm a bit at a loss.
If you dont need an ESC with onboard BEC or you don't need an Opto version (no BEC, external Rx battery used) ... I don't know of any other types of ESC to suggest.
ltc is online now
Old 12-28-2013, 06:08 AM
Dansy
My Feedback: (53)
Dansy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you don't need BEC then you want Opto
With that motor you can also run Castle Creations ESC
Dansy is online now
Old 12-28-2013, 08:41 PM
KGSS28
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Jeti stuff is outstanding . I am running the same motor with a Spin 77 and a 21x14 Falcon. Over the top power, never pulls over 68 to 70 amps.
KGSS28 is offline
Old 12-28-2013, 08:48 PM
Dansy
My Feedback: (53)
Dansy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes JETI is very good I also have 2 radio's from them and I'm using the Mezon.....but not knowing the level of electric knowledge of the 69roadrunner...I do have to point out that the amps pulled has really nothing to do with the ESC as per say...its a function of the motor / prop and battery combination....it could be a Turnigy it would pull the same Amps, the only difference is how it's working in relation with the motor, some ESC don't play nice with certain motor i.e. CC with Q Hacker motors....
Dansy is online now
Old 12-29-2013, 07:10 AM
69 roadrunner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is opto Dansy
Old 12-29-2013, 08:54 AM
69 roadrunner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dansy Thank you for the help Iam new to big elec. I fly big gas but want to move to elec Iam running the hacker motor on ten cell will run servos on a a123 so dont need bec .What is a opto Thanks Steve
Old 12-29-2013, 09:38 AM
Dansy
My Feedback: (53)
Dansy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Opto for the Jeti line mean no BEC so you need a receiver battery
Dansy is online now
Old 01-01-2014, 11:43 AM
SAB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
69roadrunner - OPTO means optically isolated - so there is no electrical conection from the ESC to the Rx, the throttle signal is received via an opto-coupler - OPTO ESC's are usualy for high cell counts - theory being that the high voltages & currents being switched by the ESC could cause noise interference in the Rx via an electricaly connected path.
Steve
SAB is offline
Old 01-02-2014, 12:12 PM
OhD
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It will run on 10s
That motor has a very high Kv for 10s and is only rated at 1900 watts. Has anyone run that combination?
Jim O
OhD is offline
Old 01-12-2014, 05:18 PM
69 roadrunner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
its rated at 3000 watts
Contact Us Archive Advertising Cookie Policy
