Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Jeti Advanced 90 Pro with Hacker Q80-14XS F3A
Reply
Old 02-02-2014, 01:11 AM
amram
amram's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Jeti Advanced 90 Pro with Hacker Q80-14XS F3A
Hello all,
Does anyone experienced working with JETI ADVANCED 90 PRO with HACKER Q80-14XS F3A?
If yes, should any adjustments are required such as timing, delays etc?
thanks in advanced to all replyers.
Regards
Amram Leshed
HACKER Q80-14XS F3A
http://www.f3aunlimited.com/webstore...roducts_id=649
http://www.singahobby.com/?q=node/13361
amram is offline
Old 02-02-2014, 04:13 AM
schneige
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Amram,
It will work with the motor, but in my mind it is not recommendable for F3A because there is no F3A breake inside the JETI ADVANCED 90 PRO.
Gerhard
schneige is offline
Old 02-03-2014, 05:26 AM
AmericanSpectre505
AmericanSpectre505's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
amram,
I recently tried the Jeti spin plus 90 with my Q80-14xs and it would not work correctly. The timing was way off and the motor sounded very bad in transition, even using the card I could not get it close. I tried the 90 plus after running the CC 80 HV and experiencing similar timing issues and over heating. I went to the Jeti Spin Pro 99, very happy with the spin 99. I will be switching to a Jeti Mezon lite 90 to take advantage of the BEC out put to power my RX and running a small back up battery TP 480 LIPO as a back up in the event of a potential brown out from the ESC via running the flight packs to low. That is programable in the Spin 99, low voltage cut off to prevent that.
Best of luck with it, as I stated......, I could not get the 90 plus to function correctly with the Q80.
Bill
Originally Posted by amram View Post
Hello all,
Regards
Amram Leshed
HACKER Q80-14XS F3A
AmericanSpectre505 is offline
Contact Us Archive Advertising Cookie Policy
