Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
3 Blade props
Old 09-02-2015, 03:42 PM
vatechguy3
Originally Posted by hilson87
If anyone wants to try a 3 blade setup I have a 19.5x13 3B and falcon 3B 80mm spinner I need to sell. Going contra!
PM sent.
Tony
Old 09-02-2015, 08:13 PM
hilson87
My Feedback: (42)
Reply sent. Check your inbox.
Blake
Old 04-08-2016, 07:32 AM
jayjayneri
Hi guys. Any update on which is the better size of 3 blade prop? Am wanting to try either the falcon 19.5x13 or 19x13.5. Any tried both sizes and can tell me the difference in performance? Thanks
Old 04-09-2016, 12:52 PM
Zippi
My Feedback: (10)
Zippi's Avatar
I have the Falcon 20X12.5 3 blade on my new Caelus V2 Lite. Waiting for the bad weather to clear to maiden the plane.
Old 04-09-2016, 07:30 PM
jayjayneri
Please keep me posted especially on the speed of thar prop. Thanks
Old 04-22-2016, 08:44 AM
  #31
big_G
Zippi...did you maiden the Caelus yet? I have a Falcon 19.5X13 on order. I did try a Falcon 19x13.5 this past Wednesday, and I liked it. Nice speed control, especially on the down lines. Prop had a much nicer sound than the PT 22x12 I have on there now. The static max amps were at 93...so I will have to watch my throttle or drop the end point to a safe point. Keep us posted.
Old 04-22-2016, 03:27 PM
  #32
Zippi
My Feedback: (10)
Zippi's Avatar
I went out last weekend for the maiden and had an electrical problem. Ended up being a bad aileron servo extension. Never got a flight in. I'm heading out in the morning for the maiden once again.
Old 04-26-2016, 05:16 PM
  #33
KC8QPU
KC8QPU's Avatar
I was at a contest a few weeks ago and a gentleman had one on his Prolog. It flew extremely well and was so slow on the down lines. I was super impressed.
Old 04-26-2016, 05:39 PM
  #34
big_G
The Falcon 19.5 x 13 came today from Mike. Will give it a go on my Caelus at the D6 contest this weekend.
Old 06-22-2016, 10:30 PM
  #35
Goodie_2_Shoes
Goodie_2_Shoes's Avatar
Hi guys,
I'm interested in trying a 3B prop and the 19.5x13 sounds like a good option but I have one small problem that is holding me back. I fly a Krill spark dynamic and I'm finding it hard to source a 3B spinner that will fit my plane. Its 65mm in diameter and 45mm long. If anyone knows where I can find one can you please let me know? Thanks.
Old 06-23-2016, 01:00 AM
  #36
drac1
drac1's Avatar
Originally Posted by Goodie_2_Shoes
Hi guys,
Could probably get this cut to suit your prop.
http://www.truturn.com/cgi-bin/store...exact_match=on
Or this cut to suit a 3 blade.
Old 06-23-2016, 02:25 AM
  #37
Goodie_2_Shoes
Thanks I totally forget about TruTurn, I was only researching composite spinners. However, a nice little alloy spinner would look good on my Spark.
Old 06-23-2016, 02:33 AM
  #38
drac1
drac1's Avatar
They will custom cut slots to suit any prop as well.
Old 06-23-2016, 04:17 AM
  #39
Jason Arnold
Jason Arnold's Avatar
Hey Ben,
Would you believe I have a spare uncut Spark spinner?
Cheers,
Jason.
Old 06-23-2016, 04:19 AM
  #40
Goodie_2_Shoes
Hi Jason,
Wound you fancy selling it?
Old 06-23-2016, 04:34 AM
  #41
Jason Arnold
Hi Jason,
How does $50 + postage sound?
Old 06-23-2016, 09:01 AM
  #42
vatechguy3
Has anyone compared a falcon 20x12.5 to the 19.5x13, with a pletty advance motor?
Tony
Old 06-23-2016, 04:13 PM
  #43
Goodie_2_Shoes
Sounds alright to me, I'll get in touch with you later today. Thanks Jason.
Old 11-13-2016, 02:56 PM
  #44
Goodie_2_Shoes
So I’ve finally managed to get a three blade prop and I have put around fifty flights on it now. I’m using a Falcon 19.5x13 V2 and so far I love it! I was originally using a Falcon 21.5x13.5 and it was good but I was having trouble trying to achieve a constant downline speed. With the 3B I found it much easier to manage the downline speed. In fact I probably need to adjust the ESC brake and reduce it a little.
Battery consumption has gone up a little by around 200mAh. For the Australian Expert sequence (Advanced A-16), I use between 2800-2900mAh. In windy conditions maybe a little more. Another interesting note about the 3B is the noise or lack of. I thought the two blade was quiet this has taken it to another level.
ID:	2189932   Click image for larger version
