OS OCA-1100HV - can I run a high voltage receiver setup?
Can I use a high voltage (lipo 2S) receiver setup with the OS OCA-1100HV? Setting up my new plane and can't find any specs/limits on receiver voltage to the OS ESC. All my previous planes have had a 6V setup to the receiver so am curious if the 2S lipo to the receiver is OK?
thanks
Woodie
thanks
Woodie
I'm using a regulated HV setup in my Spark EVO 2 with the O.S. ESC. In my case the RX voltage is 7.2 V and it works fine. I have also read somewhere that a direct 2S Lipo is OK. In any case, the ESC is opto which means that the RX voltage is not that critical anyway.
