Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Futaba Telemetry Cable
Reply
Old 02-13-2017, 03:09 PM
jetmech43
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Futaba Telemetry Cable
Would any one know why the telemetry cable all of a sudden stopped working, it still shows receiver voltage but no flight battery voltage, all the connections look secure, I just wired it up to a spin 99 and it was working and now its not. What could possibly be wrong with it.
jetmech43 is offline
Old 02-13-2017, 07:59 PM
PeterP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try reloading the sensor and re-register it in your transmitter.
PeterP is offline
Old 02-13-2017, 10:59 PM
jetmech43
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok and how you do that
Old 02-14-2017, 06:43 AM
PeterP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What radio do you have?
PeterP is offline
Old 02-14-2017, 07:26 AM
jetmech43
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
18sz
Old 02-14-2017, 09:04 AM
EHFAI
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you installed the fuse supplied with it, be sure it's not open.
EHFAI is offline
Old 02-14-2017, 10:28 AM
jetmech43
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It has the fuse installed, was working fine, can you use it with out the fuse or is that not advisable.
Old 02-14-2017, 11:22 AM
EHFAI
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the fuse is blown it did it's job and protected your RX from some unwanted current.
EHFAI is offline
Old 02-22-2017, 03:02 PM
grotto2
grotto2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's funny. I made my own cables and have flown them for years. They don't have fuses.
I'm not sure exactly what the purpose of the fuse would be. If the receiver fails in such a way to start drawing gobs of current, a fuse blow likely wouldn't save the plane. In the other direction, if the input line spikes or overvolts, the fuse probably wouldn't respond quickly enough. The receiver design should employ appropriate protection for that type of scenario, anyway.
A fuse is probably just a design feature that 'seemed like the right thing to do.'
Back to the OP's question, I've found the connector at the receiver to be unreliable and hold it in place with a drop of 5-minute epoxy.
-Ron
grotto2 is online now
Old 02-23-2017, 03:13 AM
jetmech43
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It was the fuse, I believe I blew it when I plugged in the motor batteries first then turned on the receiver after, my bad, live and learn, I put in a new fuse and now works as advertised.
Old 02-23-2017, 09:44 AM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just wonder if high voltage from the power pack is optically isolated from the low voltage at the receiver side.
I probably hesitate to use it otherwise, since all the time each pattern flight is timed and uses fixed amount of energy from the pack.
nonstoprc is offline
Old 02-26-2017, 10:48 PM
grotto2
grotto2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now that you mention it, jet, I have never, ever done that!
Contact Us Archive Advertising Cookie Policy
