Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
drive washer puller
Reply
Old 05-11-2017, 02:51 PM
PatternFlyer
My Feedback: (182)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default drive washer puller
Can anyone suggest a good drive washer puller for Hacker?
PatternFlyer is offline
Old 05-14-2017, 02:33 AM
bem
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Do You mean something like this (it is for Hacker A50/A60) as an example:
https://www.hacker-motor-shop.com/Br...ge&rdebox=box1
/Bo
bem is offline
Old 05-14-2017, 11:58 PM
PatternFlyer
My Feedback: (182)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will need to check the diameter of the drive washer, but i am looking for to use on Q80.
Old 05-15-2017, 09:44 AM
Anthony-RCU
Anthony-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't have any pictures but let me see if I can explain how I did it on a Neu. I used to used drill and tap the drive face of the drive washer for two 6-32 holes 180 degress apart. Then drill two coresponding clearance holes in the prop washer. To use remove the prop and screw the prop nut about half way down. Slip the prop washer in front of the nut and slip 6-32 bolts through the holes and thread them into the drive washer. A little pressure on these and the drive washer will pop right off.
Of course this all has to be set up before install.
Anthony-RCU is offline
Contact Us Archive Advertising Cookie Policy
