Sebart Wind 110
#1626
RE: Sebart Wind 110
One more interesting motor that would fit in without any modifications I guess:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=18126
Velco
#1627
RE: Sebart Wind 110
Has anyone tried mounting the new Hacker A50-16L V2 into a Wind 110s?
I have just received a V2 motor today for my Wind 110 and the v2 no longer has a shaft out the back for the original support bearing as did the A50-16L v1 motor.
Anyone with a Wind 110s should also ensure that there is adequate glue around the engine mounts, mine was a little lacking in this area.
Easily fixed with some hysol fillets where it was needed.
regds,
Dale
regds,
Dale
#1628
My Feedback: (8)
RE: Sebart Wind 110
Many of us have mounted large outrunners without using the rear support, and not had any issues.
While mounts are made for front/rear support, the motors do not require front and rear support. Many of these Hackers are firewall mounted with nothing but the prop at the other end. I just got the A50-14L for my Yak - supported at the front by 1.5" standoffs and the X-mount rear support.
People have talked about the A50-16L running hot on 18x12. I would try it with the new V2 motors; if it's still hot, try adding some more cooling (open up the passages).
It seems like the majority of issues with Hacker motors this size are in the Wind, and I personally believe the issue lies in either the rear support or inadequate cooling, or both. The rest of the hobby world pushes these motors beyond the tech specs and enjoys it.
I'll try my A50 in the Wind next summer for fun, should be a ton of power with the 18x10 (I got the 300kV motor).
#1629
RE: Sebart Wind 110
ORIGINAL: nichda
Mathias has mounted the new one, look here (Pictures from Post # 13):
http://www.rc-network.de/forum/showt...0-16L-V2-an-8S
Its in german, but the pictures will show you.
#1630
RE: Sebart Wind 110
Guys,
thanks for your comments and the link to the install pics, most helpful.
I have decided to go with a direct firewall mount from the front as the motor is designed to be mounted this way.
I will post a few pics in the coming days.
thanks,
Dale
thanks,
Dale
#1631
RE: Sebart Wind 110
ORIGINAL: Velco
I will continue with my explanations because some extra job was also required on the prop adapter as I could not use the one Axi originally supplied. I wil explain exactly what had to be done once I am back.
I´m very interessted....
Hans
#1632
RE: Sebart Wind 110
ORIGINAL: nichda
regds,
Dale
regds,
Dale
I would second the glue thing. I have a replacement via Area 51/Sebart so thanks for that. But the new ones firewall is dry of glue...
Lost the motor etc but the wind worked very well as a glider with 10oz off the nose...
Cheers
Kris
#1633
RE: Sebart Wind 110
ORIGINAL: Hans S
Hi Velco,
Hans
ORIGINAL: Velco
Hans
http://www.hobbyking.com/hobbyking/s...idProduct=9988
but still had to modify it a bit. I had to shorten the base for couple of mm as otherwise the gap between the spinner and the fuse would have been too big. It was done on a metal lathe.
In theory also the Axi adapter could be used if some kind of a distancing ring for the prop is first put on the adapter shaft and the adapter pulled out a bit. That should not be a problem as the motor shaft would still go deep enough into the adapter to give precise turning.
Once the season is over I will take down the motor to inspect the firewall again, just in case. On that occasion I can make the comparison photo of the modified against the unmodified adapter if necessary.
Velco
#1634
RE: Sebart Wind 110
ORIGINAL: Velco
#1636
My Feedback: (10)
NV
RE: Sebart Wind 110
Guys, some help here please....
I bent my prop adapter as a result of a snap and the firewall letting go. For the life of me I cannot remember where I got the adapter. Did it come with kit? I have the Hacker A50-16L motor and the prop adapter is the collet type. Any help on where to get one would be great. Sorry if this is a stupid question, I am a jet guy and I have the winds as a relax and fly Airplane so I am not up on the latest and greatest electric stuff.
My Feedback: (8)
RE: Sebart Wind 110
Hi Dave,
The Hacker comes with 2 prop adapters - one collet type and one grub screw type. They are quite nice parts, actually.
Looks like Aero-model has the replacement:
http://aero-model.com/Hacker-Brushle...p-Adapter.aspx
#1638
My Feedback: (8)
RE: Sebart Wind 110
More flights with the Neu, 19x12 prop. This time had the throttle curve much steeper, and thus used a lot less throttle; having the power immediately eliminates the need to reach for full power. Thus, regular day of flying and pulling just over 2000W, leaving plenty in reserve.
Batteries are at 3.82v per cell, haven't charged to look at usage, but looks like a drop to 4000 or 4500mah packs would not be an issue.
There is so much power I'm thinking of scaling back to the 18x12 for experiment, maybe will really justify lighter packs, smaller gear, etc.
#1639
My Feedback: (8)
RE: Sebart Wind 110
More flying with the Neu. Great day of practice; started with 19x12 then switched to 18x12 just to see. Used about 2200mah with the 18x12, plenty of power. The 19x12 just gives more authority, better throttle response, and better braking. Either option is a winner. Thus, one can use one of these motors and a set of 3300mah 10S packs for plenty of power and 7-8min of pattern flying.
I like the 19x12. Was debating going with the 18x12 and the smaller gear, much smaller batteries, lighter prop, etc. But, think a carbon prop and 4000mah packs will be substantial enough weight savings to keep the 19x12. The plane handles weight OK; I think it looks a little 'floaty' on the 8S setup. Can see the extra weight when flying very slow but that's probably too slow for a contest anyway. Downlines are fine with braking and the 19x12, or with the 18x12.
So, flying with the 19x12 and proper throttle curve is pulling 2000W in the air, up to 6600rpm, maybe peaking at around 60A but really flying less than that. GOBS of power in reserve; easy to find acceleration in up lines or into stiff winds.
VERY happy with this motor.
#1640
RE: Sebart Wind 110
Just a quicke for you guys out there today.
We've had discussions about the rear engine brace on the hacker motors, some like it with, some like it without.
I had problems with mine constantly coming undone and when it came time to send my recalled ESC back to castle, I removed the rear brace, and threw it away.
Oh how stupid I was.
When I finally got my ESC back I went back to practice, and within 3 flights I heard a big BRAWWWWWW noise at full throttle and touched down quickly. it appears the motor developed bit of a speed wobble or prop flutter or something but damn near tore the front off.
I then set about making a carbon replacement, but in the process added servo grommets to the corners, and everything is back to normal. If you're running a hacker, there's a reason it has that brace in the kit!
#1641
My Feedback: (42)
RE: Sebart Wind 110
Just finished mine.
SETUP:
Motor: Scorpion 4035 250KV
Prop: APC 20x12WE (Switching to 20.5x14.5 Falcon as soon as it arrives in the mail)
ESC: CC ICE 100
Servos: AIL+RUDD=Spektrum 6040/ ELEV= FUT S9551
REG.: Duralite 7.5amp to 6V
Custom 12mm Sheeted SFG's: 2x the area and weigh a combined total of 1.3oz's. .1 oz off of the stock ply included SFG's
REC. Power: 450 2 cell
Flight packs: 8S 4000mah 40C
REC.: AR7000
AUW: 8lbs 10oz.
Getting 2600 watts at WOT pulling 80 amps at 4500 ALT. Hoping the 20.5x14.5 Falcon will put me in the 90-95amp range at around 2800watts.
Awaiting cold front to move through for maiden.
SETUP:
ESC: CC ICE 100
REC.: AR7000
AUW: 8lbs 10oz.
#1644
RE: Sebart Wind 110
That Scorpion will not last long at those power levels. Mine died at mere 2kW.
And for the correct airflow, ratio between in and out holes should be at least1:3 !
Velco
#1645
My Feedback: (8)
RE: Sebart Wind 110
ORIGINAL: Rendegade
#1646
My Feedback: (42)
RE: Sebart Wind 110
ORIGINAL: Velco
Velco
Velco
In my opinion I have good clearance with a 20-20.5 prop. Just about an inch of clearence/plenty to me.
#1648
My Feedback: (42)
RE: Sebart Wind 110
And no im not taking anything seriously i really do appreaciate constructive ctiticism. But im done with NEU's for now, i have flown alot in the past and just didnt really like the amount of maintenance required and the amount of time i had to wait everytime i sent it in to have the gears either replaced or the motor just blew up or the stator just let loose. I love NEU dont get me wrong theres no motor out there that can match there power output and effeciency. I just wanted a simple outrunner to eleminate finicky problems.
