Turnigy Sentilion 100Amp ESC
Hi
Thinking about using a Turnigy Sentilion 100Amp ESC in my next plane. Does anyone have any experience of this unit good or bad. Seems to be a good unit with a meaty heatsink and the blurb ticks the boxes but advertisng is advertising and reality is another thing.
Mike
Mike
RE: Turnigy Sentilion 100Amp ESC
A friend of mine is useing this ESC with a Turnigy 63-64 motor and 2x 5s Rhino 4900 20C LiPo (all chineese stuff) with goos suxess. He don´t put too many flights on it, about 30. After a 9 minutes flight on a CA Model Genesis 4.80 Kg all stuff is only warm, 20-22ºC (consider that we are in winter, about 10ºC) Do not espect to have many set up posibilities. If you see the program card you will noticed that you can choose from 3 different options in aceleration, voltage cut of, etc. If you set the brake on the motor start to make an owfull noise in down legs so he disable the brake. For me is a good deal, simple and cheap.
Hope this help.
Hope this help.
Hi
I think for all the weight a heatsink is i would prefer to have it. The Castle Creations seems to have more features al be it for slightly more money. So i think i will go with it.
Mike
Mike
TX
Earl, are you flying the Neu motor now? Every time I've used the HV-85 with a Hacker C50 standard or Competition I've gotten the rough start issue where for a moment it isn't sure which direction it wants to go...clack, clack, clack, back and forth before spinning.
Is this resolved with a new firmware upgrade or is it not an issue on the Neu?
Keith B
Keith B
NC
Funny ...... I run my Hacker C50's with a Jeti Spin, but I got ugly snapping gearbox noises when I put in a Neu. Tried many settings on the Jeti Spin (via the Jeti Box) to no avail. Switching to a CC HV85 cured the probelm.
Seems the motor and ESC must have good chemistry and that Jeti + geared Hacker or Neu + CC are the best partners.
Ed
Ed
ON, CANADA
trunigy 100amp hv esc is very good i have four all work great after 2 years it takes 90amps just to get them worm just put in good air flow and have fun
ON, CANADA
very good esc have four bin running 2years run great it take 90amp just to get them worm on 10 cell just put in good ir flow and have fun
Probably good for many other applications though, but not pattern.
Magne
Hi, I got one of this sentilion 100A esc. I like to use LiFe 2S for powering my spektrum recievers/servos, but in this case, will the 7.2V life charged voltage be a problem to the Turnigy ESC?
Thanks!
Gustavo.
Thanks!
Gustavo.
ORIGINAL: gsp.aero
Thanks!
Gustavo.
Thanks!
Gustavo.
Regards - Paul
