If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 19 of 23 FirstFirst ... 91718192021 ... LastLast
Results 451 to 475 of 560
  1. #451
    Join Date
    Jun 2003
    chino, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Sebart Wind S Pro
    Hey
    Kenny did great finishing job, mybe Arch can chim in, an help with throws
  2. #452
    Join Date
    Jul 2003
    new jersey, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks, Kenny did a nice job. Just trying to finish it off. This is my first 2m Pattern plane. I've flown Mostly IMAC the last 6 years and wanted to try something different.
  3. #453
    Join Date
    Oct 2003
    Great Mills, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I do normal flying of about 12 degrees on aileron and elevator. About 16 degrees on elevator for spins, and about 22 on ailerons for snaps. With 16 up and down on the elevator the plane will spin beautifully after you enter with just aileron and elevator. I've never actually measured the distances of travel, I've always used a degree meter.
    PS, your Wind looks awesome.
    Arch
    Team JR, YS Engines, Morgan Fuels, F3A Unlimited, Team BJ Craft, Thunder Power RC, Castle Creations, Vogelsang Aeroscale
  4. #454
    Join Date
    Oct 2003
    Eindhoven, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jarvis johnson
    Hey
    That is indeed a great looking plane. Congratulations!!
    Volkert
    Club Saito member #371
  5. #455
    Join Date
    Jul 2003
    new jersey, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rcpattern
    Arch
    Thanks for the help, I really appreciate it!
  6. #456
    mdjohnson's Avatar
    Join Date
    Dec 2009
    Willow Point, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Arch
    Thanks for that info Arch! I am just at the juncture of setting up throws. I assume the rudder should be as much travel as you can get. I had to sand some of the fiberglas and bevel it at the rudder post on the fuselage. OtherwiseI would only be getting about 20 degrees of travel. I am now just under 40 degrees. I went with your recommendation of putting the rudder servo just aft of the wing tube with the pull-pull arrangement and it all worked out fine! I am just waiting for the CC 80HV to arrive so I can finish the project. Should be able to maiden shortly after the ESC arrival. I can hardly wait!!
    Cheers
    MJ
    Never left one up there yet.......
  7. #457
    Join Date
    Apr 2004
    EmpangeniNatal, SOUTH AFRICA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok so how do you upload pics here [X(] [&o]
    Thanks for the help with uploading pics Volkert, I dont know how you learnt that but wow well done!! It is really unclear with uploading pics on RC Universe.
    Anyway here is my new baby
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1703522   Click image for larger version.
ID:	1703523   Click image for larger version.
ID:	1703524   Click image for larger version.
  8. #458
    Join Date
    Oct 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: talk the torque
    [img]IMG_7916[/img]
    I first type my message and post it. Then I edit the message and add the pictures.
    Volkert
  9. #459
    Join Date
    Oct 2006
    Vodskov, DENMARK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Where to buy Futaba BLS 153 servos in Europe or, if the price is good, in the US?
    Thanks in advance
    Jens
    DK
  10. #460
    Join Date
    Oct 2003
    Great Mills, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tower Hobbies has them in stock in the US. 119.00USD
    Arch
  11. #461
    Join Date
    Oct 2008
    Ocoee, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Okay, I've read through this thread 3 times and think I'm ready to stop vacillating and commence with assembling mine. Decided to go with the pull pull rudder system since Sebart went to all the trouble hiding the aileron and elevator servos. Planning on alot of measuring before cutting any exit holes/slots in the fuselage. Two questions come to mind: 1. Does the rudder have a hard point for installing the horns? 2. How has the kit supplied tail wheel assembly been holding up.....any issues?
    Steve
  12. #462
    Join Date
    Jun 2007
    Newport Beach, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Planeclaims
    Steve
    Yes. Hold the rudder up to a strong light source and you can see where the reinforced area is. (I'm embarrassed to admit that I discovered this after missing the reinforced area when cutting slots for the rudder control horn.)
    Chuck
  13. #463
    Join Date
    Nov 2005
    Adelaide, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You are not the only one to have missed the hard point on the first go, Only then did I think about using a light!
  14. #464
    mdjohnson's Avatar
    Join Date
    Dec 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Steve
    I used four of the horns provided in the kit for my pull-pull setup. As Arch said, the cables exit just aft of the forward stab alignment pin. It was actually very easy to set up. For your second question i used the provided tailwheel but had to fabricate a "U" bracket and attach it to the rudder for the tailwheel wire to float in. If you hard fix the wire to the rudder it will bend and will not work well. I just cut a small piece of thin aluminum and bent it in a U shape and drilled a small hole for the wire to fit into. I drilled into the rudder from the bottom and epoxied a small piece of dowel and cut it off flush with the bottom of the rudder. Attach the U bracket upside down to the dowel and do not snug it down as it will have to pivot. So far after 4 flights it is good!! If I rememberI will take a pic of it today and post it tonight.
    Cheers
    MJ
  15. #465
    mdjohnson's Avatar
    Join Date
    Dec 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Actually I thought I had taken a picture of the tailwheel and after some sleuthing, found it.
  16. #466
    Join Date
    Apr 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I bought my plane second hand and the builder used a ball link that is epoxied into the rudder. It might also be screwed onto a threaded rod for strength but I cant see that as it is fitted. The tail wheel steering wire passes through the brass ball of the ball link. It works very well and the ball allows for the difference of the tail wheel and rudder angles.
    TtT
  17. #467
    Join Date
    Oct 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi TtT, how do you like the color scheme on your Wind? Does it give you sufficient contrast?
    Volkert
  18. #468
    Join Date
    Apr 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I see it fine in the air but I'm probably the wrong person to ask. I feel comfortable regardless of the colour of a plane, Not sure if thats because my eyes are really good or if they bad and I have learnt to fly shapes better. I hear guys around me talking about colours they find easier and harder to see flying but unless it has something like luminous wing tips I really dont find certain colours easy to see and others more difficult. I will try ask guys at this weekends pattern event if they find it easier or harder to see than the red and also the yellow Wind S Pro's that will be flying as well.
    TtT
  19. #469
    Join Date
    Oct 2003
    Great Mills, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have the blue scheme planes and the scheme has its moments it can be difficult to see when first seeing it. After flying them for 18 months I have gotten used to them and now I have no issues seeing them. I think it is like anything else. You get used to seeing something and when it is different it can be strange at first.
    Atch
  20. #470
    Join Date
    Oct 2003
    Great Mills, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Added the wing fences back on my Wind. At first I put them on and wasn't sure what I thought. I had a contest the next day and it had a different feel. It felt weird in yaw, but after the contest season was over I have installed them back. It seems that after changing a couple of things I like them. Reduced the throttle to rudder mix and took out what little knife edge mix I had left. Has a really cool sound in the air. Definitely has a different feel, but it was really locked in today and I hadn't flown much over the winter. I'm going to leave them on and evaulate some more as the year goes by. Sorry for the heli in the pic, but my picture of just my Wind didn't turn out very nice.
    Arch
  21. #471
    Join Date
    Apr 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the pics Arch. How much weight did all the fences add to the plane? I'm surprised at how heavy my Wind is to what I was expecting. I guess the small amount added to redoing each hinge has added to my total weight. Mine is now 4950g with my lightest 4400mah pack so not sure I'm going to be able to add all the fences on. I find my Wind gets a lot of wing rock flying at my slow flying style in the wind and I'm hoping this mod will help. Please keep us updated with what more you find out the more you test these flow fences. [8D]
    I thought the heli in the pic was part of the fences
    Anyone else with experience with the fences, I'd like to hear some opinions before I take the plunge and order them.
  22. #472
    Join Date
    Apr 2004
    Anchorage, AK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My experience with fences....
    I tried the Wind configuration (2 fences each wing) on an Integral; essentially identical position on wing and size. IMO a net negative. In low cross-wind conditions or wind parallel to the flight path they work great - you think Nirvana - the groove of the airpane and yaw authority are improved quite a bit. However, in a cross wind the extra side area exposed to the wind caused the airplane to move sideways a lot instead of yaw into the wind which the Integral tends to do very well under a wide range of conditions. In addition, the extra mass of the fences and the blocking of airflow off of the wing tip impacted the snap quality a bunch. All this being said, a friend of mine has experimented with similar fences and only uses the inboard fences and likes the results.
    I tried aileron fences (the little fillets at the end of the aileron) on my Wind S Pro. These were made from 1# foam. The aileron fences seemed to add some stability in bumpy air (and at lower speeds), but definitely impacted the snap quality which seemed to confirm my prior assumption related to blocking of air is flowing off of the wing tip during a snap since the added mass was neligible. For me, these are also a net negative.
    Regards,
    Andre Bouchard
  23. #473
    Join Date
    Aug 2006
    VleutenUtrecht, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What works or doesn't work on the integral, can work or not work on the WindS, they are not the same plane
    The WindS without wingfences is not stable around it's roll-axis. This is exactly what the wingfences seem to fix on it. The integral doesn't seem to have this instability.
  24. #474
    Join Date
    Apr 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: hezik
    Explain this further please
  25. #475
    Join Date
    Oct 2003
    Great Mills, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: hezik
    I do not agree with that statement at all. The plane is incredibly stable in roll. I would question the CG location if you are experiencing that. The only thing I have noticed is it smooths out the rudder and it isn't bounced around in the wind as much. It is the best rolling plane I have ever flown, with or without fences.
    Arch
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
