Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Gaudius
Reply
Old 10-18-2010, 08:31 PM
cygnet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
That's great news I just ordered one today looking forward to the build.
cygnet is offline
Old 10-18-2010, 08:53 PM
can773
can773's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
Thats great Dennis, I hope I can take a spin on it
can773 is offline
Old 10-18-2010, 08:55 PM
cygnet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
Chad what mode do you fly? If mode 11 no problem
cygnet is offline
Old 10-19-2010, 06:18 AM
HARRIS-G
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
Thank you all for your replies.
This will be my first electric pattern model and i am thinking to power it with Hacker C50 14XL.
I wanted to know about the quality of the kit if someone find any issues on wing or stab alligment or what is the final weight with batteries and if requires too many mixes to fly KE.
All these quensions made because i am burned with the kit quality of the Carf Integral i fly now and so many hours i spent to fix the problems i find.
Harris
HARRIS-G is offline
Old 10-19-2010, 11:18 AM
wagen017
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
Quote:
ORIGINAL: 4ptrol
If your CG is correct the airplane will trim completely neutral. I believe it presents well and can easily fly all classes. The 1st Gaudius was powered with a Plenty. The new one is powered by the Hacker Q-80. Both fly almost the same. I will say the front of the Gaudius is perfect for the Q-80. Very strong! You do not need to add the firewall if you use the Hacker. In either case you will be very satisfied with the power and by the way no cooling issues.
Larry
D2 VP
Quote:
ORIGINAL: byoung466
Also 7lb 14oz w/o flight batteries. Equipment is Jetti 99, Pletty, JR8611 Rudder, 8411SA Aileron, 3421sa Elevator, LiFe hobbyzone 850mah flight battery.
Quote:
ORIGINAL: HARRIS-G
Harris
I think Larry answered your questions. 7 lbs 14 oz = 3,58kg with above configuration.
I would go for a Q80 or a Pletty as power source.
Volkert
wagen017 is offline
Old 10-20-2010, 01:58 AM
  #31
HARRIS-G
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
Volkert
Yes all my quensions are answered (instead i have more)
My first thought was the Q80 but i will set it with heavy batteries (RHINO 4900)
and i don't think i could be in the weight limit with this setup, thats why i decide to go with C50.
Harris
HARRIS-G is offline
Old 10-20-2010, 07:28 AM
  #32
4ptrol
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
I agree with using a Q-80. You will save weight in the fact no firewall is needed. Remember this airplane is very light yet very strong. You may want to make your decision as to power after you have the kit.(By the way this airplane goes together very fast.) I picked mine up on a Monday and was trimming it on the next Sunday.
Larry
4ptrol is offline
Old 11-19-2010, 06:55 AM
  #33
Hans Meij
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
As requested by Harris some pictures of interior:
Hans Meij is offline
Old 11-19-2010, 07:24 AM
  #34
HARRIS-G
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
Thanks a lot Hans for the photos.
HARRIS-G is offline
Old 11-19-2010, 09:04 AM
  #35
Mike Wiz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
Nice looking radio install you got there, Hans. Thanks for posting the pictures. I'm going to use some of that jacket material for my wires next time.
Mike Wiz is offline
Old 11-19-2010, 09:47 AM
  #36
MarkGrabowski
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
Quote:
ORIGINAL: Hans Meij
Hans, I noticed the built-in side plate where the gear are mounted... seems an efficient way to do this. I see there is a plywood plate covering the part where the gear meet in the middle.... do you happen to have any photos showing the entire gear mounting method?
MarkGrabowski is offline
Old 11-19-2010, 09:58 AM
  #37
Hans Meij
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
Quote:
ORIGINAL: MarkGrabowski
From factory there is only a plywood plate mounted. The gear mounts to the underside of the plate. The carbon re-inforcement to prevent the plate to bend and the bolts to be torn through the wood are my adaptation.
You can find additional info on the Lorenz site:
http://www.f3alorenz.homepage.t-onli...tml#kit-inhalt
Old 12-11-2010, 05:14 PM
  #38
svrcp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
Does any one knows where you can get some strap like the ones on post # 33 ?
Jr
svrcp is offline
Old 12-11-2010, 05:47 PM
  #39
Mastertech
Mastertech's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
http://www.ronlund.com/rcheli-prod/CINCHSTRAP.html
http://www.ronlund.com/mm5/merchant.mvc?
Mastertech is offline
Old 12-11-2010, 06:26 PM
  #40
svrcp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
thanks Tim that what I'm looking for. Are you useing them if so what lenght.
Jr
svrcp is offline
Old 12-11-2010, 06:31 PM
  #41
Mastertech
Mastertech's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
I'm not using them in airplanes but in my heli's. I went with the bolt down battery holder for the Sickle.
Tim
Old 12-12-2010, 12:39 AM
  #42
Hans Meij
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
They come from Lorenz:
http://www.f3alorenz.homepage.t-onli...body-gurte.htm
Main page:
http://www.f3alorenz.homepage.t-online.de/
Old 12-12-2010, 10:55 AM
  #43
HARRIS-G
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
Hans
From the position of the straps i guess that you place the battery at the front part of the tray.
Harris
HARRIS-G is offline
Old 12-12-2010, 11:06 AM
  #44
Hans Meij
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
Quote:
ORIGINAL: HARRIS-G
Hans
Harris
Thats correct.
Old 12-13-2010, 08:31 PM
  #45
cygnet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
I have a question for you guys that have built a Gaudius, how is the servo put into the wing, by that I mean when you look inside the wing do you see the bottom of the servo or the top of the servo?
cygnet is offline
Old 12-13-2010, 09:50 PM
  #46
Hans Meij
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
The opening in the wingsheeting was precut in such a way that I had to mount the servo in a way the bottom is facing outwards. So you see the bottom. I do not know if this was a mistake or intentionally. With my Abbra the had to mount the servo with the top visible.
Old 12-13-2010, 10:18 PM
  #47
cygnet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
I too have build a Abbra and I'm now working on the Gaudius I find it hard to believe that they would make it that way but I guess thats the way it is, what servos did you use? The servo openings for the Abbra fit JR 9411 but the Gaudius seems to take a larger servo.
cygnet is offline
Old 12-13-2010, 10:32 PM
  #48
Hans Meij
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
Servo is JR 8715
Old 12-28-2010, 11:45 PM
  #49
HARRIS-G
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
I got mine before five days and all i can say is that it is a very good constructed kit and very light.
Anfortunately because of my work i will start to build it later. I have some quensions about it.
Where you locate the aileron horns? there is material into the aileron to put those screws or outside it?
And can i polish the color with wax?
Harris
HARRIS-G is offline
Old 12-29-2010, 10:07 AM
  #50
cygnet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gaudius
Hi I have a manual for the Gaudius however it is different than the kit, so on the ailerons you will have to install the servo first, then enlarge the slots for the servo arm, now you will have a reference of where to put the aileron horn. It just glues on inside of the rear wing spar. Be aware that the aileron servos go in backwards by that I mean that you will be looking at the bottom of the servo not the top as one would think, the factory installed slots will have to be made larger also as they seem just to be a reference. Hope this helps.
cygnet is offline
Reply
Display Modes
