Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Gaudius
Old 04-04-2011, 08:13 AM
  #101
wagen017
Default RE: Gaudius
all we need now is a picture of all three planes in knife edge!!
Volkert
Old 04-14-2011, 03:35 AM
  #102
HARRIS-G
Default RE: Gaudius
After about 20 flights i decide to put on the new rudder with thicker TE, the problem was that yesterday we had strong crosswind at our airfield. So from what i was able so see is that the model is now much slower and the rudder authority i believe is better. I will wait for a calm day to see some more details.
The final weight of the new rudder is 65gr instead of 80gr of the original and i can change it in about 15 minutes.( just pull out the 0.8mm steel rod i pass through all hinges and put it back in place).
Harris
ID:	1593766   Click image for larger version
ID:	1593767   Click image for larger version
Old 04-14-2011, 03:36 AM
  #103
HARRIS-G
Default RE: Gaudius
Some more photos...
ID:	1593769   Click image for larger version
ID:	1593770   Click image for larger version
Old 04-26-2011, 03:59 AM
  #104
papaone
papaone's Avatar
Default RE: Gaudius
Hello
Hotflyalex
Is it your video ?
Flights seem very smooth.
http://vimeo.com/22171654?ab
Old 04-26-2011, 04:14 AM
  #105
HotFlyAlex
HotFlyAlex's Avatar
Default RE: Gaudius
Yes it´s my video ;-)
Old 04-26-2011, 03:29 PM
  #106
2Sunny
Default RE: Gaudius
Viel Spass und auch mehr. Danke. Das ist wunderbar!
Joe in NY
Old 04-26-2011, 04:20 PM
  #107
mithrandir
mithrandir's Avatar
Default RE: Gaudius
With a Name like GAUDIUS, it oughta have Chrome, Spinners and Underglow.... with Leapord Skin roll'n'tuck upholstery!!
it is a sweet looking model though!
Old 06-06-2011, 03:14 AM
  #108
Neo02
Neo02's Avatar
Default RE: Gaudius
After having lost my Leviosa for a stupid mistake (one screw...), I received rather unexpectedly a Gaudius instead of a second Leviosa... No problem! The planes flies great and - set up as per instrucrions - needed one click of trim to fly absolutely straight and level. Excellent machine! My setup: Plettenberg Xtra 30-10 EVO on a PT Model 21x13 carbon prop, Yeti Spin 99, Dualsky 5000 mAh 10S, Futaba gear.
Here are some pics!
Fabrizio
ID:	1619574   Click image for larger version
ID:	1619575   Click image for larger version
ID:	1619576   Click image for larger version
Old 01-09-2012, 04:16 AM
  #109
papaone
papaone's Avatar
Default RE: Gaudius
Hello
I 'm building Gaudius with Hacker C14 XL same motor as installed on Harris's Gaudius.
Please have you any photos where are installed batteries ?
Claude
Old 01-09-2012, 09:06 AM
  #110
Hans Meij
Default RE: Gaudius
Hi Claude,
On the pics of my install you can see that i constructed quite a long battery mounting frame.
In the end only the part in front of the landinggear is used.
With a 1200gr battery the backside of the battery is about in line with the center of the landing gear.
CG is just in front of wingtube.
Regards,
Hans
Old 01-10-2012, 04:11 AM
  #111
HARRIS-G
Default RE: Gaudius
Hallo Claude
I will take some photos of my battery tray and my battery location on tray and post them tonight.
Harris
Old 01-10-2012, 05:24 AM
  #112
HotFlyAlex
HotFlyAlex's Avatar
Default RE: Gaudius
My Gaudius with Hacker C50 13Xl and SLS APL 4300mah 20C+. ;-)
Old 01-10-2012, 02:47 PM
  #113
HARRIS-G
Default RE: Gaudius
Photo of my tray and my battery location
Harris
ID:	1712493   Click image for larger version
ID:	1712494   Click image for larger version
Old 01-13-2012, 12:25 AM
  #114
papaone
papaone's Avatar
Default RE: Gaudius
Hello
Thanks to Hans, Alex, Harris. Yours comments and pictures help me.
So my friend gave me nida plate he bought in Modelltecnik-Lorenz to install on his plane.
Batteries are fixed on the plate. The plate will be slipped in slots and screwed (pictures are better than my explanations !)
May be it's quicker to move batteries !
Claude
ID:	1713381   Click image for larger version
ID:	1713382   Click image for larger version
Old 06-18-2012, 08:16 AM
  #115
jbudd
jbudd's Avatar
Default RE: Gaudius
Does anyone have a template of the firewall shape for the Gaudius? I'm putting a Gaudius together for the US Nationals next month in Muncie and it would help speed along the project if I had an existing firewall outline to start from... A PDF file or even a photo would be great. It'll be powered by a rear-mounted Pletty 30-10 Evo.
Thanks, Jerry
Old 06-18-2012, 01:25 PM
  #116
svrcp
Default RE: Gaudius
Jerry I have a template that you can use. I'll try to email to you tonight. I also have a spare new left wing panel along with both stabs. I'm useing a differnt wings on mine.
Jr
Old 12-29-2012, 11:53 AM
  #117
vbortone
Default RE: Gaudius
Hello all,
Has anyone out there has flown the Gadious using the contra? I am finishing mine and I would like to hear some feedback.
Thanks and Happy New Year 2013,
Old 12-29-2012, 03:36 PM
  #118
OhD
Default RE: Gaudius
ORIGINAL: vbortone
Hello all,
I've only got nine flights on mine but it is feeling pretty good. I'm taking out some of the upthrust but everything else is just a matter of fine tuning.
Jim O
Old 12-29-2012, 03:42 PM
  #119
OhD
Default RE: Gaudius
I forgot to mention that I did add the flare to the rudder after the first five flights. Much better.
Jim
Old 12-29-2012, 06:28 PM
  #120
vbortone
Default RE: Gaudius
Hi Jim,
I am very happy to know that we have the same plane. I used to read your RCM articles many years ago. I am planing to add the flare in the rudder too. Planing to get it close to 25-26 mm total. I already took out the upthrust too. Please keep the information flowing as you have chance to finish trimming. I won't be able fly mine since it is too cold here in Kansas.
Old 12-29-2012, 11:05 PM
  #121
jjldk
Default RE: Gaudius
Hi All
What kind/brand of contra and motor are you using ?
Happy New Year from Denmark
/Jens
Old 12-30-2012, 12:11 AM
  #122
TonyF
My Feedback: (92)
Default RE: Gaudius
It's been my experience that you are much better off adding aft lateral area instead of rudder flares. I feel that adding drag to increase stability is not the way to go. Install a set of stab fences instead of the rudder flare. Less drag and better overall performance.
Everybody here who has shown pictures of their Contra is using the Brenner Contra Drive. I think Jim is using a Neu motor.
Old 12-30-2012, 09:26 AM
  #123
vbortone
Default RE: Gaudius
Tony,
Thanks for the comment. I will try your idea. It will be also easier and cleaner in the Gaudious. Yes, using Brenner contra and New motor.
Old 12-30-2012, 11:16 AM
  #124
bondtasha
Default RE: Gaudius
papaone or anyone
Do you have a link for the Neda oplate please for a europe supplier as I cant find it on the lorenz site
Old 12-30-2012, 11:53 PM
  #125
papaone
papaone's Avatar
Default RE: Gaudius
Hello
I did'nt find on Modelltechnik site.
I know my friend bought these plates for the Gaudius.
Send to Wolfgang Lorenz a mail with photos.
Claude
