Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Electric ZN Line Xigris C2 Build Thread
Reply
Old 12-14-2011, 12:34 PM
  #401
Panzi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Electric ZN Line Xigris C2 Build Thread
which material did you use on post #126 to form the wing on the fuselage?
Panzi
Panzi is offline
Old 12-29-2011, 07:41 AM
  #402
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Panzi
Panzi
Hi Panzi,
Sorry for the late answer,
It is epoxy mixed with micro balloon.
Best regards,
Isaac Najary
najary is offline
Old 01-31-2012, 09:03 PM
  #403
Panzi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you isaac!
No problem, after studying your thread again and again i found the same question already answerd
But could you tell me whish matereial you used to build the Accu holder? in #105
Thank you!
Arnold
Panzi is offline
Old 02-01-2012, 08:06 AM
  #404
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Panzi
Thank you isaac!
No problem, after studying your thread again and again[img][/img] i found the same question already answerd[img][/img]
Thank you!
Arnold
Hi Arnold,
The materials are:
2.5 mm Balsa covered with thin fiberglass cloth.
6 mm carbon tubes.
0.6 mm carbon plate.
Best regards,
Isaac Najary
ID:	1721970   Click image for larger version
najary is offline
Old 03-24-2012, 09:00 AM
  #405
J-P
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is your final CG now ?
J-P
J-P is offline
Old 03-26-2012, 09:27 AM
  #406
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: J-P
J-P
Hello J-P,
The CG is now 7 mm behind the wing tube (19.5 mm behind the center of the wing tube).
Best regards,
Isaac Najary
najary is offline
Old 07-08-2012, 05:01 AM
  #407
Panzi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hallo isaac!
When you changed to q80 (#281) you used a cfk 2mm? Material, and plywood for distance. Did you hat any problems only with a front mounting?
Panzi
Panzi is offline
Old 07-08-2012, 06:23 AM
  #408
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Panzi
Hallo isaac!
Panzi
Hi Panzi,
The plane has now 1,100 flights with no problems only with a front mounting.
See post: 289, 294, 300.
Best regards,
Isaac Najary
najary is offline
Old 02-27-2013, 06:52 AM
  #409
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Saving 34.4 gram – (124.2 – 89.8).
The new parts were made by Mr. Peter Haase from Germany, Thank you Peter!!!
The temperatures measured with the original parts were: Min. 24 degrees Celsius, Max. 63 degrees Celsius, warm-up 39 degrees Celsius.
The temperatures measured with the Peter's parts were: Min. 22 degrees Celsius, Max. 67 degrees Celsius, warm-up 45 degrees Celsius.
Best Regards
Isaac Najary
ID:	1856875   Click image for larger version
ID:	1856876   Click image for larger version
ID:	1856877   Click image for larger version
ID:	1856878   Click image for larger version
ID:	1856879   Click image for larger version
ID:	1856880   Click image for larger version
ID:	1856881   Click image for larger version
ID:	1856883   Click image for larger version
ID:	1856884   Click image for larger version
ID:	1856885   Click image for larger version
najary is offline
Old 02-27-2013, 06:57 AM
  #410
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More
ID:	1856887   Click image for larger version
ID:	1856888   Click image for larger version
ID:	1856889   Click image for larger version
ID:	1856890   Click image for larger version
ID:	1856891   Click image for larger version
najary is offline
Old 03-08-2013, 10:19 PM
  #411
Panzi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hallo Isaac!
Very impressive reduction of weight in a small part!!
On your q80 did you fliy with you 20x13 or did you try 3blade propeller?
Panzi
Panzi is offline
Old 03-08-2013, 11:53 PM
  #412
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Panzi
Hallo Isaac!
Panzi
Hi Pazi,
Now I use Q80-14XS with APC 21X13, What was 21X14, see http://www.apcprop.com/v/html/tech_s...ml#replacement
Best regards,
Isaac Najary
najary is offline
Old 03-09-2013, 08:34 AM
  #413
Jetdesign
Jetdesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is that the same heat sink, that you ground down? Amazing.
Jetdesign is offline
Old 03-10-2013, 11:40 PM
  #414
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: gaRCfield
Hi Joe,
It is not the same heat sink.
Mr. Peter hasse produce those two new replacements parts.
I fink he sales the kit for 25 Euro.
http://www.facebook.com/ComputertechnikHaase/photos#!/ComputertechnikHaase
Best regards,
Isaac Najary
najary is offline
Reply
Display Modes
