Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Electric ZN Line Xigris C2 Build Thread
Reply
Old 12-18-2009, 01:49 AM
Andy P.
Andy P.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Electric ZN Line Xigris C2 Build Thread
Hi Isaac,
I found this on the Gorilla web site http://www.gluegorilla.co.uk/gorilla...-cure-24-p.asp which I thought might be useful info for everyone here.
Regards,
Andy.
Andy P. is offline
Old 12-21-2009, 12:46 PM
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Saving 16.5 gram =(207-196)+(207-196)/2(saving the lateral weight)
I tried to equilibrate the wings weight by using the heavy balsa parts for the light wing and vice versa,
and sand the heavy wing slightly more.
ID:	1339019   Click image for larger version
ID:	1339020   Click image for larger version
ID:	1339021   Click image for larger version
ID:	1339022   Click image for larger version
ID:	1339023   Click image for larger version
ID:	1339024   Click image for larger version
ID:	1339025   Click image for larger version
najary is offline
Old 12-21-2009, 04:31 PM
kingfd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: najary
Hi
When you tried to equilibrate the wing weight - I just curious if it's matter if the CG of one wing must be the same as the other wing? I mean that the CG have to be at the same distance from the wing root of each wing.
the build looks great!!!
Daniel, Israel(to) :-)
kingfd is offline
Old 12-23-2009, 12:27 PM
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: kingfd
Quote:
ORIGINAL: najary
Hi
Hi Danile,
No, it doesn't matter where the CG of the wings is.
There are two balances which must be done before you to take off to the test flight:
1. Longitudinal Balance, place the CG according the plan.
2. Lateral Balance, you hold the plane from the prop and the rudder and see if it drops to any side, put some plasticine on the wing tip to balance it, this is the static Lateral Balance.
For the dynamic Lateral Balance see at this Trimming Chart the Tip Weight chapter.
http://nsrca.us/all/flying/177-trimchart.html
Best regards,
Isaac Najary
najary is offline
Old 12-24-2009, 11:53 AM
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More
ID:	1341028   Click image for larger version
ID:	1341029   Click image for larger version
ID:	1341030   Click image for larger version
ID:	1341031   Click image for larger version
najary is offline
Old 12-24-2009, 11:55 AM
  #31
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The maximum deflection of the Ailerons is - 30 degrees up/down
ID:	1341036   Click image for larger version
ID:	1341037   Click image for larger version
ID:	1341038   Click image for larger version
ID:	1341039   Click image for larger version
najary is offline
Old 12-24-2009, 07:02 PM
  #32
jlkonn
jlkonn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Isaac,
What hinge slot locator is that you are using?
JLK
jlkonn is offline
Old 12-24-2009, 07:48 PM
  #33
rcprecision
rcprecision's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tettra Taper Hinge Guide available from Central Hobbies...[link=http://www.centralhobbies.com/Tools/alignment.html#Taper]Hinge Guide[/link]
rcprecision is online now
Old 12-25-2009, 12:47 PM
  #34
wattsup
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Najary, Again I've been following your build as I did the Osmose 2 years ago. I have a question about the thickness of the carbon plates you used to construct the nose ring and mount for your Hacker C50 14 XL motor. Was that 1.59mm/1/16th inch carbon plating? I'm assuming you will construct the same mount, etc. on this plane. Also, were those "lord mounts" you used to isolate the actual mount from the nose ring? I have a feeling that you were able to glean some vibration dampening and the ability to adjust the thrust angle of the motor. I appreciate both the effort you have put into this actual build and updating the RCU forum on a timely basis. Thanks in advance__Everette
wattsup is offline
Old 12-26-2009, 12:14 PM
  #35
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Saving 2.5 gram = (7.0-4.5)
The trick is to saturate the foam with large quantity off CA, about 1CC, together with the gluing of the plywood. that make the foam in this area like stiff block that harden the control surface and prevents flutter.
After I screw the bolts I unscrew them drip little CA in the screwing.
Isaac Najary
ID:	1342031   Click image for larger version
ID:	1342032   Click image for larger version
ID:	1342033   Click image for larger version
ID:	1342034   Click image for larger version
ID:	1342035   Click image for larger version
ID:	1342036   Click image for larger version
ID:	1342037   Click image for larger version
najary is offline
Old 12-26-2009, 12:18 PM
  #36
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More
ID:	1342041   Click image for larger version
ID:	1342042   Click image for larger version
ID:	1342043   Click image for larger version
ID:	1342044   Click image for larger version
ID:	1342045   Click image for larger version
ID:	1342046   Click image for larger version
ID:	1342047   Click image for larger version
najary is offline
Old 12-26-2009, 12:21 PM
  #37
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Saving 6 gram = (260-257)X2
ID:	1342049   Click image for larger version
ID:	1342050   Click image for larger version
ID:	1342051   Click image for larger version
ID:	1342052   Click image for larger version
ID:	1342053   Click image for larger version
najary is offline
Old 12-28-2009, 03:50 PM
  #38
gadperry
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Isaac,
As much as i remember, even the UFO glue is ment to be used with foam, the heat it generates might cause the foam to shrink. Have u checked it out? I also wish to ask, isnt it easier stronger and lighter, to use a round "Dibel" (like in the CAMODEL way)as base for the horns?
Best regards,
Gadi
gadperry is offline
Old 12-29-2009, 05:02 AM
  #39
ram_z
ram_z's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Gadi
Look at the bottle of the UFO, it's "odorless". (Foam safe)
Ram
ram_z is offline
Old 12-29-2009, 10:03 AM
  #40
gadperry
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
odorless is smell free
gadperry is offline
Old 12-29-2009, 12:35 PM
  #41
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: gadperry
Hi Isaac,
As much as i remember, even the UFO glue is ment to be used with foam, the heat it generates might cause the foam to shrink. Have u checked it out? I also wish to ask, isnt it easier stronger and lighter, to use a round ''Dibel'' (like in the CAMODEL way)as base for the horns?
Best regards,
Gadi
Hi Gadi,
As for the UFO glue, I didn't notice any foam shrink, in the future, I would definitely continue to use the UFO glue for gluing balsa to form and gluing balsa to balsa.
As for the round "Dibel", I have used this method few years ago, But I prefer the current method because it is stronger and prevents flutter, the weight is about the same and you don't see any screw on the other side.
Best regards,
Isaac Najary
najary is offline
Old 12-31-2009, 12:45 PM
  #42
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More
ID:	1345783   Click image for larger version
ID:	1345784   Click image for larger version
ID:	1345785   Click image for larger version
ID:	1345786   Click image for larger version
ID:	1345787   Click image for larger version
ID:	1345788   Click image for larger version
najary is offline
Old 12-31-2009, 12:48 PM
  #43
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More
ID:	1345791   Click image for larger version
ID:	1345792   Click image for larger version
ID:	1345793   Click image for larger version
najary is offline
Old 01-01-2010, 12:12 PM
  #44
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More
ID:	1346330   Click image for larger version
ID:	1346331   Click image for larger version
ID:	1346332   Click image for larger version
ID:	1346333   Click image for larger version
ID:	1346334   Click image for larger version
najary is offline
Old 01-01-2010, 12:14 PM
  #45
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More
ID:	1346336   Click image for larger version
ID:	1346337   Click image for larger version
ID:	1346338   Click image for larger version
najary is offline
Old 01-03-2010, 12:17 PM
  #46
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Saving 1.9 gram = (2.1-0.2)
ID:	1348247   Click image for larger version
ID:	1348248   Click image for larger version
ID:	1348249   Click image for larger version
ID:	1348250   Click image for larger version
ID:	1348251   Click image for larger version
ID:	1348252   Click image for larger version
ID:	1348253   Click image for larger version
ID:	1348255   Click image for larger version
ID:	1348256   Click image for larger version
najary is offline
Old 01-05-2010, 11:42 AM
  #47
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Saving 1.9 gram = (6.1-4.2)
Isaac Najary
ID:	1349971   Click image for larger version
ID:	1349972   Click image for larger version
ID:	1349973   Click image for larger version
ID:	1349974   Click image for larger version
ID:	1349975   Click image for larger version
ID:	1349976   Click image for larger version
ID:	1349977   Click image for larger version
ID:	1349979   Click image for larger version
ID:	1349980   Click image for larger version
ID:	1349981   Click image for larger version
najary is offline
Old 01-06-2010, 10:40 AM
  #48
najary
najary's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More
ID:	1350544   Click image for larger version
ID:	1350545   Click image for larger version
ID:	1350546   Click image for larger version
najary is offline
Old 01-06-2010, 03:06 PM
  #49
wattsup
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Isaac, Hopefully you will address my previous question when you get around to installing the "motor mount " in your new Xigris. Again, I find every one of your entries/updates inspiring. For 3 years I've struggled with my electrics making weight. Believe me, all of this helps. Thanks_Everette
wattsup is offline
Old 01-06-2010, 03:10 PM
  #50
Ryan Smith
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Isaac,
My apologies if I've missed it, but how much (maximum) deflection are you using on your elevator?
Thanks!
Ryan Smith is offline
Reply
Display Modes
