New Sebart Wind 50E
There's an indirect relationship though: If using the brake heats the ESC up a lot, the BEC circuits will heat up as well and it's output power may drop as a result. That said, if you monitor the ESC temperature and it doesn't become hot, there shouldn't be any problems with the BEC function either.
Thank you both for sharing this information, appreciate your feedback.
A possible voltage drop is just an assumption, therefore I would like to hear your experience.
Using a 17x10 prop by the way.
OK. Do you have a specific reason for using a separate RX pack on your Wind S50e?
As far as I can see you can do without when using the ICE 100. Just curious...
2. as for the Tx bat there are some points you should consider:
a. somtiems you can pull more Amp than your BEC can deliver
b. my firend didt tied hard his main cells pack and when he was in an inverted fly the lipos just gone through the canopy to mother earth, because he was using a separate Tx bat he could control his plane (no motor)
but without losing it...
BTW, now im flying with the reall thing an OSMOSE 2x2M and i have to admit its another world
cheers
Will make sure to put an extra battery strap around the main lipo so it doesn’t bail out </xml>
Ordered my Wind S50e over the weekend, the yellow version. Should be delivered later this week.
Set up will be as follows:
Turnigy G60 Brushless Outrunner 400kv
APC 17x10E prop
Castle Creations ICE 100 ESC
Turnigy 6S4000mAh 30C Lipo Pack
Futaba 617FS [/i][/b]2.4ghzFasst Receiver
1x Futaba S9202 (Rudder)
4 x Turnigy TGY-390V MG for both ailerons and elevator
http://www.hobbyking.com/hobbyking/s...sec_22_5g.html There’s quite a difference between the reviews of these Turnigy servos but I will give them a try, we’ll see…
Mounted skiis on my Wind S 50E and flew today on a lake - still alot of snow here. Fantastic flying day today - sunshine, no wind at all, warm and comfortable in the sun.
The skiis is Du-Bro plastic skiis but the tailskii (stearable) I have made myself. The skiis have no negative effect on flying as I can notice.
It was a lot of other people out on the lake today also, people walking, dogs, golfers (yes You read right) and people curious about my plane and asked a lot of questions - all that came near said "how quite it is" and I replied "it is electric motor in the plane". Many people are really interested to see the planes flying and ask many questions when they come near. You never know who might be interested and perhaps start flying later.
I flew alot today, about 7 hours with just short brake to eat and to carry more12 volt marine batteriesfrom the car to lake so I could charge more. I consumed 3 marine batteries for a total 240 Ah and I lost track of how many flights I made but I think over 20.
Flew some complete N-13 (Nordic) schedules and after some rehearsalI remembered the hole schedule and made about 5 whole schedules. Rest was just fun flying (breaking in 3 new 6 cell 45C 5000 mAh Gens ace batteries). A friend of mine showed up also with his small foam plane and he flew the 4 batteries he had withhim.
Sun really shined today and I feel a little sunburned in my face now.
/Bo
Thanks for posting those shots, looks like you had a great day in the snow and sun. It's cold and grey over here in England today.....some time to go before I get to maiden my Wind 50S I think. I have fitted larger wheels already to cope with what will likely to be a very rough runway at the club this Spring.
Proven with 300+ flights.
Cheers
... does anyone know what size they are ? nothing in my junk bin seemed to fit. Also, were they plastic or metal ?
Thanks - can't wait to get it in the air
[TABLE="width: 565"]
[TR]
[TD="width: 549"][h=1]Socket Head Bolt 4x30mm (10 pack)[/h]
[/TD]
[/TR]
[/TABLE]
http://www.hobbyking.com/hobbyking/s...0_pack_b_.html
http://www.f3aunlimited.com/webstore...roducts_id=746
http://www.f3aunlimited.com/webstore...roducts_id=815
i bought this one:
http://www.hobbyking.com/hobbyking/s...Search=57%20mm
