Power Set Up Question
I guess maybe I should have put this on the classic pattern forum, but I think it’s more in line with the electric pattern group, so I need a little advice. Back in the day I built several pattern planes and right now I am putting together a Focus II (nitro) to get back in pattern. But I want an electric powered pattern plane. I do not want a 2 meter plane right now, I would like a vintage pattern ship, I would like to have something like my old Phoenix, electrified. The Phoenix in the picture was my first plane to use carbon fiber. If I remember correctly, it only weighed 7.5 lbs, 65 in wing span 730 sq. I think this falls in between the Sebart Wind 110 and the S50. I really would like to stay with one battery pack, is it feasible, because these old pattern birds had small fuselages. I know that you all are bombarded with questions on what systems work the best with what planes, but I sure would grateful for advice on the power system to use, and don’t you all think that plane would look good all sleek and smooth, without the engine and pipe? Thanks Tgreen www.craptech.net
My Feedback: (50)
RE: Power Set Up Question
I built a new electric Phoenix-5 from Early RC models. I used an AXI 4130-16 and 6S Rhino 3700 batteries. It flew very comparable to the old Phoenix 5 from the 70's. The SPA guys didn't like it so they outlawed it. I loaded batterys from the bottom where a retract nose gear would have been,
Good information, how is the performance? I will mostly fly the old sportsman pattern with
the ballistic pattern guys, do you think your set up is up has enought oomp to get thought the sportsman schedule? I don’t care for the SPA format and I want retracts so it will be with the BPA, and personal pleasure. I will keep you posted, Now to find a P8 fuselages, even a broke one, Thanks again. T green
