new axiome ep
1 Attachment(s)
Hello
hir is same pictures of my new axiome ep My setting is: Hacker c-50 14xl +master spin 99 21-14 apc 2 Futaba bls 551 for ale 2 Futaba bls 153 for ele 1 Futaba bls 451 for rad The model is 4.970kilo with 1.200 kilo battery |
RE: new axiome ep
1 Attachment(s)
more
RE: new axiome ep
1 Attachment(s)
more
RE: new axiome ep
1 Attachment(s)
more
RE: new axiome ep
1 Attachment(s)
more
RE: new axiome ep
1 Attachment(s)
This photo is from the building part so the wires are not in the place bat I modified the Rader servo try to 1 servo from 2 like it came from oxai
RE: new axiome ep
Looking good Ohad!! Hows it fly?
RE: new axiome ep
I had the CG like oxai recommend and the model was flying good
My hacker was to hot (the test fly was at 38 degrees with no cooling panels yet to the eng) and my focus was on that . Next week I will in go back to Israel from India (after I was playing with heron uav 1200kilo model) and I will fly it more. And give you better answer Bat from first impression there is no caplling at all and the Rader power is very strong the model is with good stability on bumpiness something that we have a lot in Israel the only mix that I did is to the down line. |
RE: new axiome ep
Hello.
Congratulations on your Axiome EP. We're waiting. How about your flight is, how it behaves, you can tell us more? But did you picture? We will put the new Q80 13S-20 POLE In the part of the tail skid, which has passed the fuselage, would you have opened or are coming this way? good flights. Greetings. Greetings |
RE: new axiome ep
The model flies beautifly, it has excellent rudder control , the same as elevator. There is slight coupling(maybe because the forwardCG which I prefer). The model arrives with the opening in the tail skid as standard although I enlarged it a bit because of the hot weather. In the center of the fuselage at the bottom I have added another opening.
What I dislike about the model is the weight of the wings (420g each not incl. servos) making it 100g more than the standard. And because I put the elevator servos in the tail, the battery tray is haif way under the engine, making inconvenient to access. I think the engine you chose will put the model on it's upper limit with a 1180g battery, take note. You did a good choice, and I wish you lots of enjoyment from your new model. Ohad Zarko F3A Israel Team |
RE: new axiome ep
I love my glow version. It is the finest F3A plane I've ever flown. After a few trips through P & F sequences, you'll see its design features kicking in. Transitioning through any rolling maneuver is outstanding. Rudder and elevator blending during integrated rolling loops is as flawless as you can execute. Stall turns are beautiful. Snaps stay on line. The setup is a little different being there is a fair amount of incidence, downthrust, and negative incidence on the T-can - but all seems to work out great in flight.
Perhaps we can use your thread to share setup tips. Since the fuselage is quite curvy and no straight lines, I'd like to know what others are useing for a baseling. Thanks, Jim W. |
RE: new axiome ep
Ohadzarko Hi, I have photos of the plane, and it comes next week.
I think we've seen global de Pombal in the 2,009, "you flew with Azurite? Why did you put the servos back depth? Is it difficult to mount with 1 servo only deeply. I'm Spanish team Greetings. |
RE: new axiome ep
yes it was me with the Azurite in wc Pombal in the 2009
i think that you can have beter control when every elevator have 1 servo and i didnt like the wire mechanism on the elevator and the elevator have maunt for servo (bls 153). ohad zarko f3a israel team |
RE: new axiome ep
it's axiome or axiome+?
RE: new axiome ep
there is only axione ep in oxai
the + is for glow |
RE: new axiome ep
Hi everyone, <div>
</div><div>If I'm not mistaken, this Axiome is the newer version. There is an older version which has a hatch that is opened from the bottom. I read in F3A Unlimited that this newer version has an updated wing plan compared to the old one, does anybody know the difference in flight characteristics that the new wing plan has on the plane?</div><div> </div><div>Regards,</div><div> </div> |
RE: new axiome ep
1 Attachment(s)
my original axiome was upgrde to axiome+ as you can see in the photo.
i buy new set off wings from oxai that fit excellent to the old model. the model lost alot of weight (150g) and the model is new 4850g flight weight. the snaps are mach better and accurate (probably because the lite weight of the wing). it roll beter and the most important for me that the model is more stable . Thanks ohad zarko |
RE: new axiome ep
Ohad,
Was it only a wing change? how does it enter the spins now? and do the spins stop much better? Any other details on the way the aircraft flies now? Best regards Alejandro |
RE: new axiome ep
Alejo: If I do not remember wrong, CPLR told Donatas in the EC interview that the newest version had also a slightly smaller stab area, besides the evident change in the wings. but this was for the + in GP. not sure if they did the same for the EP version
