RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Electric Pattern Aircraft (http://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   Controller Settings needed for Plettenberg Xtra30-10 and Hacker-Master 90-O-Acro (http://www.rcuniverse.com/forum/electric-pattern-aircraft-385/3420307-controller-settings-needed-plettenberg-xtra30-10-hacker-master-90-o-acro.html)
wvr 10-04-2005 05:08 AM
I recently bought a hacker-master 90-O-Acro to control a Plettenberg 30-10
Can somebody who is flying the same setup share his controller settings?
I'm mostly interrested in the timing and the frequency settings.
Winfried
Adamg-RCU 10-04-2005 02:15 PM
RE: Controller Settings needed for Plettenberg Xtra30-10 and Hacker-Master 90-O-Acro
Winfried, Dez Vaghy should be flying that combo. Try emailing him: dez@f3acanada.org
Adamg-RCU 10-05-2005 02:22 PM
Whoops, should be dezso@f3acanada.org .
wvr 10-10-2005 07:18 AM
For now I'm flying with these settings:
- No Brake
- 30 degrees timing
- 8 Khz freq
- 3.0 volt per cell switch off
using 21x13, 10S6000 TP
:D
