RE: Electric ZN Line Xigris C2 Build Thread
which material did you use on post #126 to form the wing on the fuselage?
Panzi |
1 Attachment(s)
ORIGINAL: Panzi which material did you use on post #126 to form the wing on the fuselage? Panzi Sorry for the late answer, It is epoxy mixed with micro balloon. Best regards, Isaac Najary |
Thank you isaac!
Sorry for the late answer But could you tell me whish matereial you used to build the Accu holder? in #105 Thank you! Arnold |
1 Attachment(s)
ORIGINAL: Panzi Thank you isaac! Sorry for the late answer But could you tell me whish matereial you used to build the Accu holder? in #105 Thank you! Arnold The materials are: 2.5 mm Balsa covered with thin fiberglass cloth. 6 mm carbon tubes. 0.6 mm carbon plate. Best regards, Isaac Najary |
What is your final CG now ?
Thanks J-P |
ORIGINAL: J-P What is your final CG now ? Thanks J-P The CG is now 7 mm behind the wing tube (19.5 mm behind the center of the wing tube). Best regards, Isaac Najary |
Hallo isaac!
When you changed to q80 (#281) you used a cfk 2mm? Material, and plywood for distance. Did you hat any problems only with a front mounting? Panzi |
ORIGINAL: Panzi Hallo isaac! When you changed to q80 (#281) you used a cfk 2mm? Material, and plywood for distance. Did you hat any problems only with a front mounting? Panzi The plane has now 1,100 flights with no problems only with a front mounting. See post: 289, 294, 300. Best regards, Isaac Najary |
1 Attachment(s)
Saving 34.4 gram – (124.2 – 89.8).
The new parts were made by Mr. Peter Haase from Germany, Thank you Peter!!! The temperatures measured with the original parts were: Min. 24 degrees Celsius, Max. 63 degrees Celsius, warm-up 39 degrees Celsius. The temperatures measured with the Peter's parts were: Min. 22 degrees Celsius, Max. 67 degrees Celsius, warm-up 45 degrees Celsius. Best Regards Isaac Najary |
1 Attachment(s)
More
Hallo Isaac!
Very impressive reduction of weight in a small part!! On your q80 did you fliy with you 20x13 or did you try 3blade propeller? Panzi |
ORIGINAL: Panzi Hallo Isaac! Very impressive reduction of weight in a small part!! On your q80 did you fliy with you 20x13 or did you try 3blade propeller? Panzi Now I use Q80-14XS with APC 21X13, What was 21X14, see http://www.apcprop.com/v/html/tech_s...ml#replacement Best regards, Isaac Najary |
Is that the same heat sink, that you ground down? Amazing.
ORIGINAL: gaRCfield Is that the same heat sink, that you ground down? Amazing. It is not the same heat sink. Mr. Peter hasse produce those two new replacements parts. I fink he sales the kit for 25 Euro. http://www.facebook.com/ComputertechnikHaase/photos#!/ComputertechnikHaase Best regards, Isaac Najary |
